Fan temp sensor placement? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 5 (permalink) Old 04-21-2017, 03:20 AM Thread Starter
raceral's Avatar
In my FE motor there are two places you could put the temp sensor. I'm taking about the one that turns on and off the fan. Where do think is the best place to put it.
The reason I ask, after driving, the fan stays on for like 15 min. Seems like a long time.
raceral is offline
post #2 of 5 (permalink) Old 04-21-2017, 06:57 AM
CRZN 427's Avatar
My Thoughts...
On my first build, with an FE 390, and my current FFR with a 5.0, I put the sensor in the radiator right under the return hose. My probe was designed to poke through an opening in the radiator.
My fan will run on for several minutes after shut down, and on warm days, or after parking when driving around town, it will come on a couple times before the temp drops below the set turn on point.
Regards, Rick.
CRZN 427 is offline
post #3 of 5 (permalink) Old 04-21-2017, 11:25 AM
Chepsk8's Avatar
I have mine in the thermostat housing. Has worked great.
In any case that the fan runs off the battery, it will run on after due to the heat soak.
Chepsk8 is online now
post #4 of 5 (permalink) Old 04-21-2017, 11:48 AM
The way around that is to power the relay coil (just the coil) from a keyed source.
CraigS is offline
post #5 of 5 (permalink) Old 04-23-2017, 05:53 PM Thread Starter
raceral's Avatar
I took out the thermostat. It was a 195. Replaced with a 180. That should help.
raceral is offline
