Whats the latest, greatest alignment specs? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 12 (permalink) Old 04-19-2017, 02:07 AM Thread Starter
raceral's Avatar
I just searched alignments specs and its all over the place.
I have a MK4, non power steering rack , what ever comes with the complete kit. Heavy ars FE motor in the front end. Straight axle in the rear., 3 link
What I want is it to go straight... Street car only setup, no racing setup. I don't want the "racing look" tops way in. I don't want it to twitch or jerk all over the road when it goes over an asphalt seam in the road. Just a good simple setup. OH and I have 15" tires.
AL Adkins
Stoneville NC.
raceral is offline
post #2 of 12 (permalink) Old 04-19-2017, 02:15 AM
1/2 degree negative camber, 3 degrees positive caster, 3/32" toe in (in, not out).
JKleiner is online now
post #3 of 12 (permalink) Old 04-19-2017, 02:37 AM
Chuck_Sloggett's Avatar
Does the same apply to power steering only increase the caster to 6-8 degrees? -- Chuck
Mark 4 FFR 8687 3 link, Konis, tubular LCA's, Carbed 347, AFR 185's, Comp HR274XE Roller Cam, T-5Z.
Gas'N stainless headers and side pipes, 3.55 rearend, Hydroboost, SN-95 spindles, 4 wheel disc brakes, Power steering, Classic instruments, Competition style dash, Guardsman Blue w/ Wimbledon White stripes, heated seats, heater, etc.
Chuck_Sloggett is online now
post #4 of 12 (permalink) Old 04-19-2017, 03:57 AM
I think that would be just about perfect.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
Bob Cowan is offline
post #5 of 12 (permalink) Old 04-19-2017, 10:26 AM
Yes. Watch the adjuster sleeve thread engagement.
Al,
I should have mentioned---tire pressure at 24-25 PSI.
post #6 of 12 (permalink) Old 04-19-2017, 11:39 AM
Chepsk8's Avatar
Running 1.5 degrees neg camber, 4 degrees caster, toe straight
More of a track set-up
Do have the electric steering boost
Chepsk8 is online now
post #7 of 12 (permalink) Old 04-19-2017, 12:56 PM
Is this 3/32" total toe in?
Driver_WT is online now
post #8 of 12 (permalink) Old 04-19-2017, 02:23 PM
Seagull81's Avatar
Be sure your frame height is set before the front end setting.
Texas Cobra Club-Austin
FFR3542K, 347 C.I., Holly Systemax EFI, T-5, 3-Link, Miata Front Sway Bar, 4 Wheel Discs, Red with White Stripes
Seagull81 is offline
post #9 of 12 (permalink) Old 04-19-2017, 02:55 PM
Official OLD GUY
Big Blocker's Avatar
X3 or 4
What Bob and Jeff said . . .
My MKII is 100% street / highway driven - SBF - manual steering - 3-link - 17's.
It is set to:
1/2 degree negative camber, 3 degrees positive caster, 3/32" toe in. I run Nitto 555 tires (first generation) and the car tracks like a bullet fired from a rifle.
That 'jerky" feeling going over seams in the asphalt (or any other hard road surface) is called "tram lining". You can align some of it out but it's mostly caused by tread pattern - I originally had BF Goodrich TA KDW's and the car would tram line everywhere. When I switched to the Nitto's, with no alignment changes at all, car road over those same lines like they weren't there at all. Major difference in ride quality too.
Hope that "steers you" (pun intended) in the right direction.
Doc
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
post #10 of 12 (permalink) Old 04-19-2017, 10:27 PM
Baghdad Bob
mcwho's Avatar
Send a message via Yahoo to mcwho
Rear IRS Alignment
There is also an Alignment for those of us that have rear IRS, as I do.
For the rear IRS alignment, (the original IRS)
Camber -1 degree
toe in 1/16 total
Ordered Feb 26 2009
Engine: 331 from Engine Factory, Carburated QF 650
Halibrand 15" Wheels, BFG Radial TA Tires
Build School July 2010
Recieved Kit July 2010, #7287
Adds
Power Steering Rack & Offset Alum Bushings - Breeze, Power Steering Heidt Valve
Power Brakes - Whitby
Hydralic Clutch & Hydralic Brake Master Cyl. Modern Driveline
Modified quiet sidepipes - Breeze
sidepipe heat shields cobrastuff
Trunk Battery Box - FFmetalb
Firewall Forward - FFmetal
Enlarged Passenger Footbox mod Russ Thompson
Russ Thompson accelerator pedal
Tremec TKO600 .64 5TH
Heater and Wipers
As of Mar 2017
Fitting the sidepipes and last will be hood and windscreen fit, then paint.
First start April 2016
First Go-Cart June 2016
Body is being prepped for paint
mcwho is online now
post #11 of 12 (permalink) Old 04-20-2017, 06:54 PM
M DOUGHERTY's Avatar
kleiner nails it again
The Traveling Builder
M DOUGHERTY is offline
post #12 of 12 (permalink) Old 04-25-2017, 11:12 PM
Send a message via AIM to Mark Gearhart
Definitely go with toe in. I went with toe out with power steering and it's way too twitchy. I'm at about 6 degrees of caster with -2 degrees of camber.
FFR Challenge Street Car Build
625hp N/A Coyote, T-56 Magnum, Moser Solid Axle, etc
My Build Thread:
Mark Gearhart is online now
