5.0 efi - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 5 (permalink) Old 04-18-2017, 03:24 PM Thread Starter
Question 5.0 efi
AT what temp does EFI go into closed loop? I have replaced my 10 year old Ox sensors so I was wondering. I have a new TPS, MAF sensor and ECU coolant temp sensor. My thermostat is a 180 but factory is thermostat is 195. Is my car going into closed loop with the cooler thermostat?
street roadster with under car exhaust, 3 link, coil overs,front and rear sway bars, and no roll bars
Marty D is online now
post #2 of 5 (permalink) Old 04-18-2017, 06:06 PM
150ish.
JKleiner is online now
post #3 of 5 (permalink) Old 04-18-2017, 06:29 PM
Official OLD GUY
Big Blocker's Avatar
X2
What Jeff said (I hate it when he's always right - LOL!)
150 to 160 is the normal range for the EEC to switch control of your spark and fuel.
Running a 195 stat was for the smog requirements in most states and the unleaded fuel. If you are NOT running any smog related equipment, the 180 stat won't really hurt anything.
I don't have a cooling issue with my car so I stuck with the 195 but engine rarely gets above 188 anyway.
Doc
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
post #4 of 5 (permalink) Old 04-19-2017, 03:04 PM Thread Starter
Cool
I'm not running any smog equipment. Thanks for the info, I'll feel better knowing that my gas mileage is as good as it gets.
post #5 of 5 (permalink) Old 04-22-2017, 01:40 AM
Factory Ford 5.0 EFI thermostat is 192 degrees F
Why not just run what Ford installed from the factory?
Mark Reynolds is offline
