Does anyone know of a direct DOT headlight replacement? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 17 (permalink) Old 03-09-2017, 04:27 PM Thread Starter
mjpesky's Avatar
I have a MK1 and the wipac UK headlights. I spoke to the inspector and it seems they will be a problem without the DOT on the lense. I'm really not looking to upgrade right now to LED or anything major. Just a replacement for the stock Wipac's with a DOT listing. Thanks!!!!
mjpesky is offline
post #2 of 17 (permalink) Old 03-09-2017, 04:47 PM
steno's Avatar
Drop in some Wagner DOT lamps for the inspection. Then swap them back when you've passed!
steno is online now
post #3 of 17 (permalink) Old 03-09-2017, 08:04 PM Thread Starter
mjpesky's Avatar
Are they a direct retrofit? If so, why would I swap them back out instead of just leaving them? Is there a difference performancewise?
mjpesky is offline
post #4 of 17 (permalink) Old 03-09-2017, 10:43 PM
5.8Cobra's Avatar
The MK1 headlights have a city light in them that is kinda cool like a dim daytime running light that is usually wired in with the parking lights. Any 7" round hi-low beam (3 prong) headlight will fit right in. Up to you if you want to switch back, if not you could probably sell the Wipacs in the classifieds. Good Luck with inspection!
FFR 3107 Built & Sold
FFR 1990 Built & Sold
FFR 7330 Built & Sold
5.8Cobra is online now
post #5 of 17 (permalink) Old 03-09-2017, 11:51 PM
steno's Avatar
The Euro style headlamps seem to have a better pattern than the typical DOT stuff. I'm running Hella's and love them!
steno is online now
post #6 of 17 (permalink) Old 03-09-2017, 11:53 PM Thread Starter
mjpesky's Avatar
Thanks 5.8. I don't have parking lights wired separately. The parking lights and headlights wired on the first Pull of my headlight switch and the high beams and parking lights wired on the second Pull. Will look for replacement 3 wire lamps.
Steno... do you have a part # for the hellas? I'm sure I would need some relays yes?
mjpesky is offline
post #7 of 17 (permalink) Old 03-10-2017, 04:55 AM
steno's Avatar
I picked them up from a Summit in the Jeep and truck section. The face of the assembly is pretty flat, but I want good light placement on the roadway most of all!
steno is online now
post #8 of 17 (permalink) Old 03-10-2017, 04:55 AM
steno's Avatar
I didn't need relays
steno is online now
post #9 of 17 (permalink) Old 03-10-2017, 12:40 PM Thread Starter
mjpesky's Avatar
Steno.... I picked up these.
mjpesky is offline
post #10 of 17 (permalink) Old 03-10-2017, 01:09 PM
steno's Avatar
THAT'S the ticket! Nice pattern on low, and great long distance pattern on high beam! I'm running standard wattage lamps.
steno is online now
post #11 of 17 (permalink) Old 03-10-2017, 03:12 PM Thread Starter
mjpesky's Avatar
Thanks Steno. Hope you and your family are doing well.
mjpesky is offline
post #12 of 17 (permalink) Old 03-10-2017, 03:52 PM
steno's Avatar
A pleasure to help even a little bit. We're all hanging in there... Thanks!
steno is online now
post #13 of 17 (permalink) Old 03-14-2017, 10:55 AM
Baghdad Bob
mcwho's Avatar
Send a message via Yahoo to mcwho
Great thread,
does anyone know how many AMPS the HELLAS draw. I have the Wagner sealed beams that came with the kit, they were about 1.5 and 2.5 amps on low/hi beam. I don't have relays.
Ordered Feb 26 2009
Engine: 331 from Engine Factory, Carburated
Halibrand 15" Wheels, BFG Radial TA Tires
Build School July 2010
Recieved Kit July 2010, #7287
Adds
Power Steering Rack & Offset Alum Bushings - Breeze, Power Steering Heidt Valve
Power Brakes - Whitby
Hydralic Clutch & Hydralic Brake Master Cyl. Modern Driveline
Modified quiet sidepipes - Breeze
sidepipe heat shields cobrastuff
Trunk Battery Box - FFmetalb
Firewall Forward - FFmetal
Enlarged Passenger Footbox mod Russ Thompson
Russ Thompson accelerator pedal
Tremec TKO600 .64 5TH
Heater and Wipers
As of Mar 2017
Fitting the sidepipes and last will be hood and windscreen fit, then paint.
First start April 2016
First Go-Cart June 2016
Body is being prepped for paint
mcwho is offline
post #14 of 17 (permalink) Old 03-14-2017, 11:03 AM Thread Starter
mjpesky's Avatar
Bulb wattage is listed as 55/60. That would be 4.6A and 5A
mjpesky is offline
post #15 of 17 (permalink) Old 03-16-2017, 12:47 AM Thread Starter
mjpesky's Avatar
Just swapped them out...nice unit. Doesn't have DOT as shown in the photo...but has SAE. Shouldn't be a problem... I hope!
mjpesky is offline
post #16 of 17 (permalink) Old 03-16-2017, 12:59 AM
steno's Avatar
DOT gets their standards from SAE. Call Summit... see what they say!
steno is online now
post #17 of 17 (permalink) Old 03-16-2017, 01:01 AM
steno's Avatar
Sorry JEG's
steno is online now
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
