Dash Mounting Ideas? - FFCars.com : Factory Five Racing Discussion Forum
 2Thanks
  • 1 Post By edwardb
  • 1 Post By CRZN 427
post #1 of 10 (permalink) Old 03-09-2017, 07:25 AM Thread Starter
kitcarnut's Avatar
Hey Gang, I'm not a huge fan of putting screws into the dash to hold it in place. I have the new MK4 moulded dash with the glove box.
Has anyone came up with something else they would share with me. I was almost thinking 3M two way tape, but could be an issue if I ever need to remove it.
Thoughts?
kitcarnut is offline
post #2 of 10 (permalink) Old 03-09-2017, 11:14 AM
I am also not a big fan of screws through the front of the dash to hold it in place. So have used hidden mounts on the back of the dash for each of my builds. You can see them in two of the build threads, linked in my sig line. But those were aluminum dashes with screws holding the brackets through the aluminum. That doesn't apply in your case. While I don't have personal experience, I've seen multiple threads where guys have tried to bond brackets onto the back of the aluminum, and even with pretty exotic adhesives didn't hold up. There isn't a ton of experience with the pre-made dash you have, but since it's a plastic material vs. aluminum, getting something to stick is going to be even more challenging IMO. Brackets, tape, Velcro, whatever. I just don't think they're going to stick and adequately hold up the dash once it's loaded with gauges, wiring, etc. My personal recommendation for that dash is screws through the face. I really don't think you have a choice. Even though it's not the look you want, in the end it's going to be solid and more serviceable. I would also recommend adding brackets under the dash tube so that the screws can be lowered enough to be under the body lip. Screws directly into the dash tube would probably be partially or completely covered.
kitcarnut thanked this.
edwardb is online now
post #3 of 10 (permalink) Old 03-09-2017, 04:48 PM
CRZN 427's Avatar
One Idea...
To hide the screw heads you can use screw head covers. Some might think they are more of an eye sore than the screws but it is one alternative.
Regards, Rick.
https://www.mcmaster.com/#plastic-screw-covers/=16oju2h
CRZN 427 is offline
post #4 of 10 (permalink) Old 03-09-2017, 05:33 PM
I really like Bob's method. Just need to plan ahead (as I know he did) to make sure your long screwdriver will fit between the gauges and also any reinforcing brackets you add to the bottom of the dash.
CraigS is online now
post #5 of 10 (permalink) Old 03-09-2017, 10:28 PM
rickscobra's Avatar
I have the composite(AKA plastic) dash, and I tried a number of things trying to get something that would bond to the dash. Even after putting my RF harness on a diet and carefully tying up the wires, I just could not imagine trying to drop that dash. I resorted to the black screws with the confidence that the dash is firmly mounted. If I have an issue down the road, I will deal with it. Hoping the new electronic gauges will be trouble free. Just my 2 cents
rickscobra is offline
post #6 of 10 (permalink) Old 03-09-2017, 11:46 PM
cwrandolph's Avatar
Since my dash is solid aluminum, I couldn't live with any screw heads showing. I have a 10-24 machine screw coming through the hoop on each side which holds the dash (welded to the hoop on the back side). These are where the body curves towards the back of the car so there is room to put a nut on the bolts. They are tucked under the body and you would never see them if you weren't looking for them. There is also some velcro in the center area and I have a horizontal panel on the bottom which attaches to the steel 2 X 2. In the last picture you can see 1/8" aluminum bonded to the dash (engine turned aluminum) with epoxy. No evidence yet of the epoxy letting go. Not sure if this is any help with the molded dash. Pictures aren't the best - sorry.
Chas Randolph Sidney, Ohio FFR 6113, '91 5.0 EFI, TFS heads, Comp cam, GT40 Tubular intake, 24lb injectors T5Z w/midshift, 3-link, SAI Mod, TurboCoupe rear 3:55's, 17" Team III's, Picked up @ FFR on 5/5/07, First start 10/5/08, Go Cart 9/27/09, Licensed & Legal 9/30/10. Painted 6/3/12. Graduation 8/21/12. Engine rebuilt & pumped up May '13.
cwrandolph is offline
post #7 of 10 (permalink) Old 03-10-2017, 05:16 PM
6-32 button head stainless screws look just fine. Same thing I used to fasten the hood scoop. They are in plain sight and even add to the look in my opinion.
Some show more or less since the hoop is not the same curve as the body but really it is not something I even think about.
Mark Reynolds is offline
post #8 of 10 (permalink) Old 03-10-2017, 08:09 PM
SJDave's Avatar
Another vote for exposed fasteners
McMaster has the low profile stainless cap head screws that look pretty nice, I made some black nylon washers for them to nest into on my hobby lathe. I used them for the dash mounting (on the far left and right sides...not that visible...to some billet brackets that mount to the 2 x 2 tube behind the dash.
The bracket slide front to back on the 2" tube and plastic bracket slides up and down that is bolted through the padded dash. Since I had moved my dash mounting frame back 1.5" to gain some arm room, I didn't know quite where things would end up with the body on, so this can adjust about anywhere.
Same fasteners used on center console stack and cover, you can see two of them at each side of the dash.
Billet brackets and plastic sliders.
011.jpg Photo by dalbertalli | Photobucket
SJDave is offline
post #9 of 10 (permalink) Old 03-13-2017, 07:20 PM
CDXXVII's Avatar
Dash Support
I was going to use the hidden mount approach but with my under dash filler panel it was just going to make things difficult.
My dash is supported by the three 6-32 screws visible along the top of the dash and my under dash filler panel. I like the look of the screws and after a while you do not notice them anymore.
Be sure that you have your body mounted before you drill your holes for the exposed screws. Also, for the Mk4 you need to add some brackets for the screws to have them accessible after the body is on. All three of my screws are below the dash hoop. Screwing into the 3/4" dash hoop frame will not give you access later. The shape of the body does not exactly follow the shape of the dash.
First Start 05/23/2015
First GoCart 05/23/2015
CDXXVII is online now
post #10 of 10 (permalink) Old 03-15-2017, 03:29 PM
AdamC's Avatar
not the best pics but....
i too do not like the visible screws so I have three small pieces of angle that i fastened to the arch tube and the dash fits under them. I also have a full lower support from mike everson.
MKIV 7785
coyote 302
tko-600
wilwood brake upgrade
delivered 4/12
engine in 6/14
first start 09/14
go-cart 09/14
paint 6/15
legal 7/15
AdamC is online now
