Building My Center Console - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 11 (permalink) Old 03-08-2017, 07:39 PM Thread Starter
Classic Format Fan
JJ in Cbus's Avatar
Been doing a little work this winter making the roadster a little more user friendly. I began making a console cover for the trans tunnel.
I began with a piece of 1/4" luan and cut it with 1/4" over hang on both sides. I then cut out the holes for the shifter and the parking brake handle (I did the tunnel top brake handle mod). I then glued two pieces of 1" angle aluminum along the bottom left and right edges.
I covered it with two layers of 1/16" closed cell foam normally used for laminate flooring and then wrapped in black marine vinyl. I made templates, cut out, and sewn boots for the shifter and the parking brake handle. I cut out a trim plate for the shifter and brake out of 3/32" aluminum that I had laying around. I added two stainless cup holders I found on Amazon.com.
It fits snugly over the top of the tunnel and the angle aluminum wraps around the top and covers the top edge of the carpeted sides.
FFR6768 MK3.1 Mountaineer 5.0 Midshift T-5
JJ in Cbus is offline
post #2 of 11 (permalink) Old 03-08-2017, 07:42 PM Thread Starter
Classic Format Fan
JJ in Cbus's Avatar
I have built an arm rest/storage box, but I am still not in love with how it turned out. I have not permanently mounted it yet. I still may make another to see if it works out better.
post #3 of 11 (permalink) Old 03-08-2017, 08:38 PM
nice work. The armrest is a different look than normal but I think it is pretty cool. Would love the additional storage.
wareaglescott is offline
post #4 of 11 (permalink) Old 03-08-2017, 09:12 PM
Master of my Build
cChrisM's Avatar
Looks great. Was not familar with Luan. Do you need to fasten it down? Will the wind blow it off the trans tunnel?
Picked up Kit 6/20/09, Tear down stage complete, Donor 2003 Cobra 4.6L supercharged, 25k miles on engine, IRS, 6-speed. Attended Build School October 08. Mods done, frame powder coated 12/2012, First Start 7/31/13, gocart 8/2/13,
blog:
cChrisM is offline
post #5 of 11 (permalink) Old 03-08-2017, 09:29 PM Thread Starter
Classic Format Fan
JJ in Cbus's Avatar
Luan is 1/4" plywood used as underlayment for vinyl flooring. I have 3 velcro strips underneath it but it tucks in under the carpet along the back of the tunnel and stays put by itself. I was looking for something to use as a cover that would not increase the height of the tunnel too much. I had a few pieces of luan laying around, so that was what I used. I had carpeted the sides of the tunnel but I left the top bare aluminum. I was originally going to just wrap that aluminum piece in vinyl but then I was not sure how I was going to trim out the top edge of the carpet. So I made the top wood cover and then bonded two angle aluminum pieces to the bottom to make two sturdy edge wraps. Then when I covered it all in vinyl. Now the angle wraps around the edges and trims out the top of the carpet.
Problem solved.
post #6 of 11 (permalink) Old 03-09-2017, 12:44 AM
5.8Cobra's Avatar
Nice Job JJ, I like the integrated ebrake and shifter bezels. If you were worried about it going anywhere, you could always run 4 black headed screws through your aluminum angle into the trans tunnel aluminum. Looks great anyhow, well done.
FFR 3107 Built & Sold
FFR 1990 Built & Sold
FFR 7330 Built & Sold
5.8Cobra is offline
post #7 of 11 (permalink) Old 03-09-2017, 12:32 PM
Nice work. What did you use to glue the aluminum to the luan?
CraigS is offline
post #8 of 11 (permalink) Old 03-10-2017, 01:52 AM
FFCobra Captain
Dan Babb's Avatar
I like the cover but not really digging the box on top.
Kinda looks like a cash box that the PTA uses to put your money in at the bake sale.
Something with rounded contours would look nicer.
FFR5857
PS/PB/AC
Dan Babb is offline
post #9 of 11 (permalink) Old 03-10-2017, 11:10 PM Thread Starter
Classic Format Fan
JJ in Cbus's Avatar
CraigS, I used Dap Weldwood contact cement on the aluminum rails and to hold down the edges of the vinyl covering.
Dan, like I said I am not really in love with it either. I do not have it mounted yet so I am not committed to it either. I may have to attempt a more rounded one next time.
post #10 of 11 (permalink) Old 03-12-2017, 02:56 PM
Baghdad Bob
mcwho's Avatar
Send a message via Yahoo to mcwho
JJ, That's a nice Idea, I have been thinking about something like that. Mixed feelings about the cup holders tho, I was thinking a flap to hide them when not in use would help folks not think your Cobra is a SUV.
I do like the leather like vinyl over the console though, I think that a nicer look than the carpeting.
Ordered Feb 26 2009
Engine: 331 from Engine Factory, Carburated QF 650
Halibrand 15" Wheels, BFG Radial TA Tires
Build School July 2010
Recieved Kit July 2010, #7287
Adds
Power Steering Rack & Offset Alum Bushings - Breeze, Power Steering Heidt Valve
Power Brakes - Whitby
Hydralic Clutch & Hydralic Brake Master Cyl. Modern Driveline
Modified quiet sidepipes - Breeze
sidepipe heat shields cobrastuff
Trunk Battery Box - FFmetalb
Firewall Forward - FFmetal
Enlarged Passenger Footbox mod Russ Thompson
Russ Thompson accelerator pedal
Tremec TKO600 .64 5TH
Heater and Wipers
As of Mar 2017
Fitting the sidepipes and last will be hood and windscreen fit, then paint.
First start April 2016
First Go-Cart June 2016
Body is being prepped for paint
mcwho is offline
post #11 of 11 (permalink) Old 03-14-2017, 04:07 AM Thread Starter
Classic Format Fan
JJ in Cbus's Avatar
Yeh, I probably will never use them for cups, but they are darn handy to hold your cell phone and garage door opener when you do not have a glove box.
