How much clearence around ex cutouts - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 10 (permalink) Old 02-17-2017, 03:42 PM Thread Starter
raceral's Avatar
I'm doing the unthinkable today... grinding out my cutouts to fit my headers.... I'm about to pee in my pants grinding on my body...
SO, is 1/2 in all the way around good enough from blistering the paint?
I have been reading all the post about the exhaust cutouts don't line up... and they don't . On my FE... I had to jack up the pass side right much to get even close to the same on each side... then I had to grind the top of the cutout about 1 inch... a very little for and aft....
AL Adkins
Stoneville NC.
raceral is offline
post #2 of 10 (permalink) Old 02-17-2017, 03:51 PM Thread Starter
raceral's Avatar
This is the tool I am using. Is this enough clearance?
raceral is offline
post #3 of 10 (permalink) Old 02-17-2017, 04:07 PM
M DOUGHERTY's Avatar
that is plenty Al
The Traveling Builder
M DOUGHERTY is offline
post #4 of 10 (permalink) Old 02-17-2017, 04:57 PM
Avalanche325's Avatar
Mine are much tighter than that and no issues with over 10k miles.
That tool looks pretty aggressive. I used a small sanding drum and it cut pretty fast.
Avalanche325 is online now
post #5 of 10 (permalink) Old 02-17-2017, 05:33 PM
Yes, that is an agressive tool Al. I recommend a 1 1/2" inch sanding drum in your drill running at low speed. Tape around your openings and draw your line then sneak up on it. I've done painted bodies a number of times...you'll be fine.
JKleiner is online now
post #6 of 10 (permalink) Old 02-17-2017, 06:02 PM
lol
I just reread the post
sanding roll is best as stated.
but you have more than enough clearance now when using poly mounts.
post #7 of 10 (permalink) Old Yesterday, 01:06 AM Thread Starter
raceral's Avatar
The carbide tool cuts very fine and just makes dust. Very easy to control. Anyway. These suckers actually lined up and came out good I think. No druping and parallel with the body.
raceral is offline
post #8 of 10 (permalink) Old Yesterday, 05:02 AM
JKolbfleisch's Avatar
I printed to template from the manual, then photocopied it to 110% original size because I got tired of trying to play magic voodoo fitment. Traced it on the body, cut and I don't think it is noticeable at all. I just wanted the 2 sides symmetrical and clean. I also bought 1 3/8" wooden dowels to stick in the header pipes (if not using jpipes) to keep a good of location. I do wish I had the patience to get that exit tolerance ridiculously tight ... but I just want to drive.
JKolbfleisch is offline
post #9 of 10 (permalink) Old Yesterday, 01:45 PM
My old car, now owned by Mark, had less than a 1/4" clearance. In over 5 yrs and 30,000+ miles, the paint didn't even change colors, much less blister.
rich grsc is offline
post #10 of 10 (permalink) Old Yesterday, 06:22 PM
Real time recon's Avatar
Al. Just measured mine.1/2" here.No discolored on 12 years old paint job.And looks like I have the same side-pipes
Real time recon is offline
