Exhaust Flange bolts and clearance to Body - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 9 (permalink) Old 02-16-2017, 03:53 PM Thread Starter
Baghdad Bob
mcwho's Avatar
Send a message via Yahoo to mcwho
This is my continuation of my exhaust cut out, engine mount, and exhaust flange series of issues. I suppose mounting Brackets as well.
Summary:
The engine flange bolts on the DS scrape on the body and are difficult to tighten.
Originally, I thought my only issue was with the cutouts being too small, or the engine not seethed fully in the mounts The cutouts have been enlarged, after I wrestled with trying to get the engine to seat lower in the engine mounts. No luck there. Now I see that the header flnge bolts on the drivers side are dangerously close to the inside of the body so much that there is rubbing.
On the PS there is plenty of room.
If I divide the clearance avail I get about 1 3/16" per side, from the header flange to the body before adding the sidepipes.
Ordered Feb 26 2009
Engine: 331 from Engine Factory, Carburated QF 650
Halibrand 15" Wheels, BFG Radial TA Tires
Build School July 2010
Recieved Kit July 2010, #7287
Adds
Power Steering Rack & Offset Alum Bushings - Breeze, Power Steering Heidt Valve
Power Brakes - Whitby
Hydralic Clutch & Hydralic Brake Master Cyl. Modern Driveline
Modified quiet sidepipes - Breeze
sidepipe heat shields cobrastuff
Trunk Battery Box - FFmetalb
Firewall Forward - FFmetal
Enlarged Passenger Footbox mod Russ Thompson
Russ Thompson accelerator pedal
Tremec TKO600 .64 5TH
Heater and Wipers
As of Mar 2017
Fitting the sidepipes and last will be hood and windscreen fit, then paint.
First start April 2016
First Go-Cart June 2016
Body is being prepped for paint
mcwho is offline
post #2 of 9 (permalink) Old 02-16-2017, 06:43 PM
Splash panels installed?
JKleiner is online now
post #3 of 9 (permalink) Old 02-16-2017, 07:00 PM Thread Starter
Baghdad Bob
mcwho's Avatar
Yes, Splash panels are installed.
Ordered Feb 26 2009
Adds
Heater and Wipers
As of Mar 2017
mcwho is offline
post #4 of 9 (permalink) Old 02-16-2017, 07:43 PM Thread Starter
Baghdad Bob
mcwho's Avatar
My kit came with bulb seal, foam strip and felt strip. The manual stated to install the foam strip on the rails along side the hood. Could it be the felt strip was supposed to go there? Its about 1/2" thich and dos NOT compress like the foam does.
Thnt would account for some of the clearance.
Just spoke to Dan G at FFR, I do have it setup correct and the one side he hays does usually come closer on the DS.
Next, make the cutout bigger !
Ordered Feb 26 2009
Adds
Heater and Wipers
As of Mar 2017
mcwho is offline
post #5 of 9 (permalink) Old 02-16-2017, 11:32 PM
Cobra Colorist
j.miller's Avatar
Yes make the cut out bigger. D side I have to trim above the bolt heads .....makes yours about normal
j.miller is offline
post #6 of 9 (permalink) Old 02-17-2017, 12:42 PM
These could help. Scroll down to 3/8 diameter.
https://www.mcmaster.com/#standard-f...crews/=16e6b93
CraigS is offline
post #7 of 9 (permalink) Old 02-17-2017, 01:18 PM
Dave M's Avatar
I was thinking along the same lines as Craig. Use a hex head bolt or something like what Craig suggested to minimize the thickness the head. Put the bolt through from the out side and lose the gasket which will gain you another 1/8". (I think most of us use silicone sealant, I know I do.) Doing all this you may be able to get away with only having to open up the cut out just enough to get the bolt into the hole. I ended up opening my drivers side up more than it needed to be and I've never liked the looks of it.
Dave
Dave M is online now
post #8 of 9 (permalink) Old 02-18-2017, 06:04 PM
JRT dogs's Avatar
Minimizing DS cutout area
Here's what I did to minimize the DS cutout while providing clear access to bolts, esp the front one.
-norm
Mk4 #8306 Levy 347 w/FAST 2.0 Sportsman EFI; 8.8" (3.55); dual roll bars; 17" Halibrands /Nitto 555s; Breeze front battery; std FFR dash plus a map light (remember them?); Gas'n pipes; seat heaters (no real heater, no wipers, no FB mods, ...), just your basic Mk4 build.
JRT dogs is offline
post #9 of 9 (permalink) Old 02-19-2017, 01:35 PM Thread Starter
Baghdad Bob
mcwho's Avatar
JRTDOgs,
Your solution is one of the options that I am considering plus maybe the top bolt being a buttonhead bolt to eliminate a lot of interference with the body as well.
Ordered Feb 26 2009
Adds
Heater and Wipers
As of Mar 2017
mcwho is offline
