alignment question - FFCars.com : Factory Five Racing Discussion Forum
 1Thanks
  • 1 Post By Boydster
post #1 of 16 (permalink) Old 01-09-2017, 02:27 AM Thread Starter
DAVE VAN's Avatar
alignment question
Going in for alignment soon. I never have liked the neg. camber look with the top of the tire tilted in and the added wear on the inside of the tire. How would it drive with 0 or +1/2 deg. camber? Will be a street car only. !5" tires. Will it hurt cornering that much?
Dave Van FFR 1406
I intend to live forever - so far, so good.
DAVE VAN is offline
post #2 of 16 (permalink) Old 01-09-2017, 04:15 AM
Sanford's Avatar
Go for 1/2 negative, barely tilted in for best wear. Wont be noticeable to most. 0 to 1/2 positive and the outside will wear out first.
Sanford is online now
post #3 of 16 (permalink) Old 01-09-2017, 11:43 AM
Agree with Sanford. .5 degree negative camber is good for a street car, not really visually noticable and if coupled with 1/16" to 3/32" total toe IN won't wear the tires prematurely or abnormally. Negative camber and toe out will cut the tires (inside) as will positive camber combined with toe in (outside).
JKleiner is offline
post #4 of 16 (permalink) Old 01-09-2017, 12:43 PM
I wouldn't have a problem going to zero camber at all. One thing to note is that the effect of camber on cornering is only felt right near the cornering traction limit. It has no effect on normal cruising type driving other than, as you note, wearing out the tires unevenly.
CraigS is online now
post #5 of 16 (permalink) Old 01-09-2017, 01:19 PM
Chepsk8's Avatar
The look that Dave is noticing is much more an Open Track/Race alignment look. We typically run much more Camber and Caster to help on the track. Typically we have much more suspension compression and tire loads, so the additional Camber actually has the tire footprint level with the road surface in hard cornering. Typically 1 1/2 to 2 degrees is used, with more just in extreme circumstances. We also keep the toe at Zero, or very close. Adding Caster by leaning the centerline of the spindle back slows down the steering action, and makes the cars less "darty" at higher speeds. With Power Steering, I have heard of as much as 8 degrees Caster. Manual, 4 seems to be an average number.
With my set-up at zero toe, 1.5 degrees Camber, and 4.5 degrees Caster, I saw no uneven tire wear, and the car handles great.
The kids in their ricers just go overboard, and it usually produces a car with the look, but handles like crap, and kills tires.
Chepsk8 is offline
post #6 of 16 (permalink) Old 01-09-2017, 03:42 PM
raceral's Avatar
I'm totally with Dave on this... matter of fact that was going to be a upcoming post.
So what would be all the numbers for a good "STREET" setup?15" tires for me also.
AL Adkins
Stoneville NC.
raceral is online now
post #7 of 16 (permalink) Old 01-09-2017, 04:04 PM
Official OLD GUY
Big Blocker's Avatar
Camber, caster & Toe
Al,
I run a bigger tire then most on my fronts (275x40x17) and have many, many miles on my setup: +3.0 caster (no power assist), -1/2 camber, 1/16" toe-IN.
Tire wear pattern is non-existent with even wear all across the tread - tire pressure kept at 23# up front.
These numbers have worked well with my [basically] street/highway driven car.
While I don't track the car at all, I do drive rather "spirited" on mountain roads.
Car handles as expected without anti-sway bars and the factory supplied front/rear tubular suspension with [non-adjustable] Pro shocks all around, rear end is F5 3-Link.
Hope that gives you a starting point . . .
Doc
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
post #8 of 16 (permalink) Old 01-09-2017, 04:15 PM
Pretty much what Doc said although I like a touch more toe in to help with straight line stability.
For manual steering:
3 to 4 degrees positive caster (more=higher steering effort but better tracking and return to center)
3/32" total toe in
For power steering:
7 to 8 degrees positive caster
3/32" total toe in
Cheers,
JKleiner is offline
post #9 of 16 (permalink) Old 01-09-2017, 07:20 PM
FFCobra Captain
Dan Babb's Avatar
Most of your alignment machines have toe measured in degrees...not inches.
What is a good toe setting in degrees?
FFR5857
PS/PB/AC
Dan Babb is offline
post #10 of 16 (permalink) Old 01-09-2017, 07:42 PM
raceral's Avatar
https://robrobinette.com/ConvertToeInchesToDegrees.htm
https://robrobinette.com/DIYAlignmentCalculator.htm
AL Adkins
Stoneville NC.
post #11 of 16 (permalink) Old 01-09-2017, 07:47 PM
Boydster's Avatar
You need the diameter for your size and manufacturer of tire, then use this:
toe inch to degree converter
A Nitto NT05 255/40-17 set at 3/32" toe will equal 1.06 degrees per tire, or 2.12 degrees total toe.
DAVE VAN thanked this.
Boydster is offline
post #12 of 16 (permalink) Old 01-09-2017, 08:21 PM
Thanks Al and Boydster. That calculator is now saved.
post #13 of 16 (permalink) Old 01-09-2017, 09:04 PM
Avalanche325's Avatar
You don't like this??????
MKIV Roadster....FFR7694
Avalanche325 is offline
post #14 of 16 (permalink) Old 01-10-2017, 12:21 AM
Looks like a fish out of water! LOL
Driver_WT is offline
post #15 of 16 (permalink) Old 01-10-2017, 02:49 AM Thread Starter
DAVE VAN's Avatar
Thanks for the input guys. i will probably go with Jeff's power steering numbers. I have new tires and wheels and want to do it right.
Dave Van FFR 1406
DAVE VAN is offline
post #16 of 16 (permalink) Old 01-10-2017, 03:28 AM
I am running Jeff's P/S settings. I do autocross. Tire wear has been nice and even. The only issue is that my rear tires seem to be wearing faster than my fronts. I wonder what that could be?
