I am installing my new Dart 363. To get the motor mounts to fit the block proper I needed to install 1/2 inch spacers (Thank you Mr. Fortes). Using the same bell housing and transmission. I have the engine and transmission mounts tight and tried to install the driveshaft. I can't get the shaft to slide on. Any help is appreciated.
Make sure transmission is out of gear and stab the drive shaft into trans and then turn shaft slowly trying to find a position that will allow the ujoint to slip up and in. If this doesn't work loosen transmission and engine mounts and try forcing assembly in, up, and all around to get enough clearance to get shaft in! If that doesn't work you may have to get shaft shorten. Do a ffr google search on the subject as there is a lot of info on the subject.
Thanks guys. I'm going to chalk this one up to being too tired. After a break in work, which included posting my previous post, I went out and put a jack under the pumpkin and raised the rear end and the axel slid right in. The car was on jack stands and the rear suspension was hanging down increasing the angle. :0.
Right rod, right hole, just the wrong angle..... I thought we had spell check?:surprise:
Related Threads
Factory Five Racing Forum
3.3M posts
50.6K members
Since 2002
