Rectangle Tail Lights - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
 12Thanks
post #31 of 39 (permalink) Old 09-27-2016, 05:30 PM
Originally Posted by MPTech View Post
mk351, which lens assembly and which LED bulb are you using?
also, how do you have it setup?
ie:
running lights = upper lens
turn signal = flashing upper lens
brake lights = both lens
thanks
I have the Rodworx lights at the beginning of the thread. I have brake and turn on the same lens. Running on the other. My turn switch is set up that way.
FFR #8758 Build Thread-
mk351 is offline
post #32 of 39 (permalink) Old 10-07-2016, 11:54 AM
Finally got a chance to post pics
[IMG][/IMG]
Tony_G thanked this.
mk351 is offline
post #33 of 39 (permalink) Old 10-16-2016, 01:22 AM
DadofThree's Avatar
Getting my Rectangle Light Mods tested.
This shows the PentaStar XP Module and how it works.
https://youtu.be/bTTHGzgx4zw
Dave
My photos are at:
Videos are at:
Loving the Island Life
DadofThree is online now
post #34 of 39 (permalink) Old 10-17-2016, 12:32 AM Thread Starter
Looks good mk351. I haven't been doing much work on the Cobra lately but still going to use these lights. Thanks for sharing how it turned out.
Tony_G is online now
post #35 of 39 (permalink) Old 10-17-2016, 07:56 PM
Those are definitely bright enough! ...and look nice also.
Stargazer is offline
post #36 of 39 (permalink) Old 03-11-2017, 12:19 AM Thread Starter
Hazard Help
OK I finally got around to hooking these lights up to out. They look pretty bright to me. I have a couple of issues though. Tail lights work, Brake lights work, all blinkers work front and back. But the opposite side in the rear has a very dim flash also. The hazards work in the front, but the rear only works if the brakes are on. I have the Ron Francis harness, Russ Thompson turn signal, Trailer converter to make the 3 wire work and a DPST switch for the hazard.
post #37 of 39 (permalink) Old 03-11-2017, 02:17 AM
Official OLD GUY
Big Blocker's Avatar
Hazard switch
I would suspect the DPST hazard switch . . . not having a "trailer adapter" on mine, I can't say for sure but most "dim on one side" (or the other), is caused by back-feed. A diode or two might be called for, not at all familiar with how the trailer adapter isolates one side from another.
FWIW, the [earlier] trailer adapters are one reason I didn't go that route. The PentaStar module wasn't around when I built mine.
I would disconnect the hazards from the circuit and see if it works normally, then work backwards from there.
Remember, the tail lights are a completely separate circuit and should not have any connections to Brake/TS.
Doc
65_427_COBRA and Tony_G thanked this.
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
post #38 of 39 (permalink) Old 03-11-2017, 03:03 AM
bobl's Avatar
I had a chance to follow behind my car today in bright sunlight. The Haines Hot Rod LED rectangle lights were not as bright as I had hoped. I also realized just how small these lights are, which probably accounts for the lack of brightness. I'm sure they are as bright as the regular rectangle lights, just pretty darned small from 50 feet away.
bobl is online now
post #39 of 39 (permalink) Old 03-20-2017, 06:35 PM Thread Starter
Hazards work now!
OK everything is now working like it should. Rear Hazards work and no slight flash on the opposite side when using the blinkers. It was the trailer module that was causing all the problems. I had to buy a different trailer module than what Rodwokx sold me. Had to upgrade to a powered module. I went with the Tekonsha #119148. Came with a fuse and a power wire to run to the battery feed. Hope this may help anyone else trying this setup.
