Best adhesive for dash vinyl? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 15 (permalink) Old 06-05-2007, 01:31 AM Thread Starter
DFRESH's Avatar
I installed my vinyl dash. The adhesive I used didn't work well and lifted twice. What have you guys used with good results? What's the best out there? Thanks,
1974 351W, Holley 670, Tremec 3550, 95 GT rear w/3.27's and Fox conversion. 4 wheel stock disc brakes. Picked up kit on 10-06, finished 10-09.
DFRESH is offline
post #2 of 15 (permalink) Old 06-05-2007, 01:38 AM
3M Super 77 spray adhesive worked well for me. HTH
In HONOR of Roy, my DAD
WisCobra is offline
post #3 of 15 (permalink) Old 06-05-2007, 01:47 AM
Supreme Cobra Commander
TimC's Avatar
I used Weldwood contact adhesive.
-Tim-
-Welcome to Georgia. We shoot first.
-I'm so broke I can hardly pay attention
~Me~
TimC is online now
post #4 of 15 (permalink) Old 06-05-2007, 01:50 AM
Just did my dash in leather on Saturday. Ditto the 3M Super 77.
jeffnpats is offline
post #5 of 15 (permalink) Old 06-05-2007, 02:15 AM
Scott L's Avatar
I sprayed the dash and vinyl with 3M Super 77, and tacked the edges and cutouts down with the weldwood contact cement. This worked really well. I don't think the 3M alone will hold down the edges in the long run.
Ready to go
Sanding, sanding, sanding
Graduation Day
Scott L is offline
post #6 of 15 (permalink) Old 06-05-2007, 02:44 AM
nc1mike's Avatar
3m super 77 and a lot of it over a super clean dash aluminum.
nc1mike is offline
post #7 of 15 (permalink) Old 06-05-2007, 02:54 AM
I think Permatex made it but I used the headliner spray adhesive that was recommended on this Forum. Working great so far....
ksmith is offline
post #8 of 15 (permalink) Old 06-05-2007, 03:01 AM
In the home stretch....
John Card's Avatar
The best stuff is the spray adhesive that professional upholstery shops use. Ive seen it labeled as "Landau top adhesive" (think vinyl top) - very similar to contact cement. An upholstery shop could probably sell you a small amount or spray it on for you.
- The Wife
Build photos here:
John Card is offline
post #9 of 15 (permalink) Old 06-05-2007, 03:08 AM
Chevy FFR - Randy J.'s Avatar
3m 8090 as a spray or Dap Weldwood brush on contact cement. With either, you better lay the vinyl on perfect because that's where it will be!
3M 8090 is a fast-acting, high-strength, aerosol contact adhesive designed for two-surface application. 3M 8090 adhesive is resistant to heat and plasticizing oils and is excellent for attaching vinyl, insulation, foam, padding and rubber parts to metal and other surfaces. Bonds can be made within minutes of application or as long as one hour later.
R
Robert, I really miss you man.
FFR Roadster Mark III, 500hp Small Block Chevrolet, TKO600, BMW Imola Red with silver ghost flamed stripes by the immortal Batman
"There's nothing you can't do, only stuff you haven't done yet!"
Chevy FFR - Randy J. is offline
post #10 of 15 (permalink) Old 06-05-2007, 11:23 AM
Weldwood in a can. Used a small roller to apply it to the dash. Once vynal was layed on used a small rolling pin(don't tell boss) to roll out till smooth. I did'nt have good results with spray glue here. Wipeing down the alum with laquer thinner helps get it spotless for good adhesion.
M III recieved 8-06, 3 link,lca's PS+PB,carb,302,373 gears, T5 first start 8/27/06.Go Kart 9/9/06
Tagged 10/24/06
Graduate 4-07
hind sight is offline
post #11 of 15 (permalink) Old 06-05-2007, 01:03 PM
1st RFM/FFR Legacy Winner
Greg_M's Avatar
Another vote for what Randy used. 3M Super Trim adhesive sets up stronger than the 3M 77 stuff IMO. The 77 gets a little soft with summer heat. I have used both on my car.
Permatex makes a black weather strip adhesive in a tube that's great for installing small areas and edges where you need extra grip and can't tolerate overspray.
Weldwood brush-on from a can works great for the carpets.
Greg_M is online now
post #12 of 15 (permalink) Old 07-19-2007, 12:23 AM
Red face
I'm using a marine grade black vinyl which I purchased at JoAnn's Fabric. I attached the vinyl to the bare aluminum dash with 3M Super 77 spray adhesive. (after sanding the aluminum with coarse sandpaper and cleaning with acetone). On the fingers where the ends of the vinyl folded over curved edges of the aluminum, I used Weldwood contact cement. Everything looked absolutely perfect ...for a month. Then we had a week of 90 degree (F) weather. It was probably over 100 degrees in the garage. Now all the adhesive is soft, sticky and runny. About a third of the vinyl has delaminated from the aluminum and most of the corners have lifted. Previously, the glue had been very hard and secure.
Today I went to the auto parts store and tried some trim adhesive but it doesn't look like it's hardening. I suspect this due to plasticizer migration from the vinyl.
Has anyone had success with and adhesive and the marine vinyl?
Thanks again for your help.
Gary
Mark II, 302 EFI, 3 link. First start Nov. '06. On the road Sept. '07
Visit my build site at
First
12/06.
garyabc is offline
post #13 of 15 (permalink) Old 07-19-2007, 12:37 AM
aka: Bob in Simi Valley
FFR5163's Avatar
Gary:
I too used Marine vinyl from JoAnn's and 3M spray adhesive. You just described what has happened to my dash. I feel like I should have used Gorilla glue. That stuff works!
A gun is like a parachute. If you need one, and don't have one, you'll never need one again.
Non-donor MK II, FFR-5163K, Ford Racing 302, Tremec, Team III Wheels, Red w/Silver Stripes.
FFR5163 is offline
post #14 of 15 (permalink) Old 07-19-2007, 12:39 AM
MrJeffreyB's Avatar
I used Permatex Headliner Adhesive. No problems.
-Jeff
MKIII Delivered 4/05, Graduated 8/07, 351W, Carb, 3-link, 4x4's w/Gas-N Pipes, Disks, 15" Team III, T5Z, 3.55 Rear, Indigo Ink and Titanium by Ron Randall at Metal-Morphous
MrJeffreyB is offline
post #15 of 15 (permalink) Old 07-19-2007, 12:42 AM
Gary
I used Weldwood in the can with my marine grade vinyl with no problems. I put 2 coats on each surface and let it dry before installing. I tried the 3M spray and it looked good until the sun hit it, then it got soft and lifted.
StormyCobra is offline
