Pics/ Ideas for interior lighting - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 18 (permalink) Old 02-12-2014, 02:43 PM Thread Starter
OVRPWRD's Avatar
I just picked up my Cobra about a month and a half ago, and want to add lights to the interior. I will use it mostly for car shows & cruise nights ...when I leave it is usually dark. It would be nice to have some footwell lighting. I was actually thinking about some hooking up a switch for them to go on and off on the doors are open. Let's see some ideas!
OVRPWRD is offline
post #2 of 18 (permalink) Old 02-12-2014, 03:03 PM
Ray
Ray's Avatar
Send a message via Yahoo to Ray
I don't have any photos but we installed a pair of led lights on the 2x2 bar just ahead of the lower dash with a rocker switch below the dash. It's enough light to get the seat belts on, read a map etc. but not distracting when they're on.
I'll try to grab a photo but it will have to wait for tonight...
Ray
Ray is offline
post #3 of 18 (permalink) Old 02-12-2014, 03:13 PM
Plodding Along
CCRsAC's Avatar
I added a pair of reproduction Ford interior light brackets with sockets and bare bulbs for a period-correct look. They're installed in the under-dash support pan that I added from Mike Everson, but could be installed in other configurations.
You may also want to check at your local Advance Auto or Auto Zone as they have some easy-to-install LED lighting that would work, too.
You can see the original-style socket to the left of the steering shaft in this picture. There is a 1 1/4" hole cut below it in the panel so that the bare bulb is visible. These cast a very "old" looking yellowish light down into each footwell.
Later,
Chris
Mk3.1 #7074
Picked-up at FFR - 10/10/09
CCRsAC is offline
post #4 of 18 (permalink) Old 02-12-2014, 03:39 PM
Cobra Enthusiast
TURBOSNAKE's Avatar
I used adhesive LED strips on the angle at the bottom of the dash and connected them to the courtesy light circuit on my GM-style light switch.These strips draw vey little current and light up the footwells completely. HTH, Jim
TURBOSNAKE is offline
post #5 of 18 (permalink) Old 02-12-2014, 04:24 PM
CRZN 427's Avatar
Lights, Yea..
A while back there was an offer to get some lights from a Forum member who had bought a large quantity and passed on the savings. I got six of them. They have a frosted lens which makes them not as bright as I would like, but I may be able to change to an LED, or a clear lens later on, I want to see what they are actually like, in the dark, after I get the car on the road.
I mounted one under the dash, on the 2 x 2, on each side, and since I have cockpit accessible storage above the differential, another one on each side on the back wall (I also put another pair in the trunk).
I wired the two on the driver side to a door activated switch, and the two on the passenger side on another door activated switch so each side only comes on when that door is open. I wired them directly off the battery so they will come on even when the battery cut-off switch is in the off position.
I also put the Mustang dome light at the top of my cockpit accessible storage area and wired it to a switch mounted on the dash, it is also wired directly off the battery.
Regards, Rick.
CRZN 427 is offline
post #6 of 18 (permalink) Old 02-12-2014, 05:04 PM
For my Mk3 build, I used some LED downlights from a former forum vendor in each footwell. Installed them in the dash support on each end. I used a separate switch on the DS dash support. Pictured below. They're fine, but not real bright.
For my Mk4 build, used these: West Marine # 12645099 LED accent light, stainless steel, amp draw: 40mA. watts: 0.55. Also installed them on the dash support on each end exactly like the Mk3 build, except switching them with the courtesy light setting on the headlight switch. Also putting one in the trunk, and will switch with a pin switch (e.g. whenever the trunk is opened). Thought about pin switches for the doors, but couldn't come up with anything too neat/clean with the hinges. These are nice and bright and work perfect for this application.
This is the DS light on my Mk3. Same setup in the Mk4 just with the different fixture.
Build 2: Mk4 Roadster #7750. Deliv: 09/09/2012. Legal: 03/30/2015. Red/white club (again). 2015 FFR Open House "Best in Show"
Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. Deliv: 08/05/2015. 2015-2016 Coyote.
edwardb is offline
post #7 of 18 (permalink) Old 02-12-2014, 05:24 PM
AC Bill's Avatar
I added a pair to underdash panel. In that position they can also work as a map light if need be. On/off using gauge light rheostat switch.
AC Bill is offline
post #8 of 18 (permalink) Old 02-12-2014, 05:34 PM
Tyler Wayne's Avatar
I have standard LED bar in each footwell, plus the door lighting. Can be activated trough door switch, headlight switch and on with disalarming arm (walk up to car, interior lights are on at night)
http://www.ffcars.com/forums/17-fact...es-handle.html
Tyler Wayne is offline
post #9 of 18 (permalink) Old 02-13-2014, 01:25 AM
2007 Calendar Cover Car
Redfish's Avatar
A couple older pics of mine...
FFR4462K MKII
331 Dual 390CFM Holley Quads, AFR 185s, Comp Cams XE274HR
315 Mod, IRS, FR500s, Power Cobra Brakes, Manual Steering
'68 Mustang Hardtop, 302, C4
Redfish is offline
post #10 of 18 (permalink) Old 02-13-2014, 06:07 PM
Avalanche325's Avatar
I have LED, I think they are licence plate lights, on the 2X2 tube that comes down in front of the doors. They have a chrome cover, but I did make aluminum spacers because the wire comes out of the back. They are hidden and light up the footwells nicely. I have them hooked up to the headlight switch courtesy light position. I am also going to put pin switches on as soon as I am sure my door position is finalized.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #11 of 18 (permalink) Old 02-15-2014, 02:02 PM
FFR Rookie Craftsman
stengun's Avatar
Howdy,
I used 2 of these LED strip lights to light the trunk of my Spyder.
They are about the size of a $.25 pack of gum and cost $3.99/ea.
Here's a link to were I bought them:
6K WHITE 9W 3 LED HIGH POWER PANEL LIGHT
Paul
stengun is offline
post #12 of 18 (permalink) Old 02-15-2014, 08:26 PM
Mustang Man's Avatar
Like above, I have the adhesive back cut-to-length LED strip lighting on the dash 2x2 and wired to the headlight switch. Simply turn the knob and you have plenty of light to see to buckle in, etc.
HTH...
FFR5310RD
Mustang Man is offline
post #13 of 18 (permalink) Old 02-15-2014, 08:31 PM Thread Starter
OVRPWRD's Avatar
HTH...
Just wire directly to the original ff switch?
OVRPWRD is offline
post #14 of 18 (permalink) Old 02-16-2014, 01:25 PM
That is correct. The FFR headlight switch is based off of an early '70s GM switch (Nova, Camaro, etc.) and there is a terminal for interior lighting on it. You simply rotate the knob CCW until it "clicks" and that terminal has power and will cause your interior lights, whatever you choose, to illuminate.
I wanted to do door pin switches as well but opted for simplicity...
FFR5310RD
post #15 of 18 (permalink) Old 02-16-2014, 01:51 PM Thread Starter
OVRPWRD's Avatar
Thanks Mark. Think I'll go the same route and hook to the switch. I assume it works with the key off?
OVRPWRD is offline
post #16 of 18 (permalink) Old 02-16-2014, 03:39 PM
Yup, it is a hot at all times connection...
FFR5310RD
post #17 of 18 (permalink) Old 02-16-2014, 03:56 PM
SJDave's Avatar
I used West Marine LEDs in the under dash panels also. Very compact and alot of light. I used a rocker switch in my center console, but I like the idea of using the headlight switch.,..another change. I also added LED puck lights in the trunk and under the Bonnet hooked to the same switch...has come in handy on trips
Hinged panels dropped down:
SJDave is offline
post #18 of 18 (permalink) Old 02-16-2014, 06:51 PM
nukemmc's Avatar
I took another play out of the Jeff Kleiner book that I saw on his Indy14 Build thread. These lights have a nice vintage look to them, are nice and compact and I will run them from the same "Dome Light" position on the Mustang light switch you folks are using on the FFR/GM switch.
~Bruce
7/22/2013 Ordered
11/8/2013 Delivered
10/2/2014 First Start & Go Kart
7/22/2015 Painted, Licensed & street legal
400Hp 351W, TKO600, 3.27 3-link
nukemmc is offline
