Power steering - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 25 (permalink) Old 03-14-2013, 02:32 AM Thread Starter
Power steering
Can anyone recommend a power steering rack? Part number too if you have it.
Thanks , BD
Bobby Doug is offline
post #2 of 25 (permalink) Old 03-14-2013, 02:52 AM
Bill_VA's Avatar
Bobby, if you do a quick search for "power steering" you'll see this topic is probably one of the most discussed topics on this forum. You'll see there's more than one way to skin this particular cat. It also depends on your budget, you could do it on the cheap and have a very adequate and dependable setup. You could also spend a bunch of money and get high-end parts and are better and possibly more or less dependable than OEM Ford components. Personally, I didn't spare too many expenses when I built my car and didn't want to compromise when I decided to convert to power steering (I'm really hoping that didn't come off as snobbish).
Here's what I did: My Power Steering Conversion
New Owner of
Bill_VA is online now
post #3 of 25 (permalink) Old 03-14-2013, 10:30 AM
Like his entire car Bill's setup is a masterful work of art! By his own admission it does represents the high end. I'll present the other end of the spectrum using OEM parts which I have done on 3 roadsters.
Autozone racks:
#6406; 3.0 turns lock to lock
#6439; 2.5 turns lock to lock
#64163 2.25 turns lock to lock
They are all right around $100. Couple that with an OEM mustang pump ($50), a CFR bracket ($60) and about eighty bucks worth of teflon hose and fittings from Breeze and you'll be out the door for around $300.
For a street only car, or even one that may see an occasional autocross for giggles you might be happiest with the 3.0 turn rack. I just completed a Mk4 using a 3.0 rack which is a street cruiser and for that type of use I think it is ideal; responsive but relaxed if that makes sense. I have the fast 2.25 rack in my own car and love it but I do a lot of auto-x and track time. It is go cart quick and changes direction like a cat on carpet! I'm completely comfortable with it however some people who have used that ratio feel that it's too fast. As an aside, after driving them back to back it is surprising how much the two different racks change the whole personality of the cars---not that one is good or bad, just different. Additionally different drivers prefer different levels of assist. If you find that it is more than you like you can trim the pump's pressure relief spring to reduce it. If you would like the ability to adjust it for various drivers or uses (I run full assist on track but back it down on the street) you can incorporate a Heidt's adjustable pressure valve for an additional $100 or so.
Good luck!
JKleiner is online now
post #4 of 25 (permalink) Old 03-14-2013, 12:24 PM
dv/dt's Avatar
If you really want to go high end:
But they only make it in quick ratio and it is $900.
"Can you imagine?!"
dv/dt is online now
post #5 of 25 (permalink) Old 03-14-2013, 01:27 PM
FFCobra Captain
Dan Babb's Avatar
Highjack Warning
Jeff....I've been collecting parts for a swap (have pump & brackets).
I have a manual rack in my car now. With the power racks you mention bolt right in or do I need any other parts? I've read about rack extenders and different u-joints and not sure what I'll really need.
FFR5857
PS/PB/AC
Dan Babb is offline
post #6 of 25 (permalink) Old 03-14-2013, 04:01 PM
Jack Wojack's Avatar
I have the AGR Power Rack that has been specially tuned for the FFR Cobra along with the companion AGR Saginaw Type II Aluminum pump and I couldn't be happier...as for as performance/road feel. To be accurate I sent AGR my 3 turns lock-to-lock rack and they changed the internal torsion bar valve. I would speak with them. There is a point in time when Ford updated their Mustang racks and went to helical gears, I think their helical, which is a better set-up over say a 1985 rack.
Your Power Steering is a critical factor in how your car will drive and it will have a big influence on your driving pleasure. I felt this was not an area to go cheap.
Jack
Judged Best In Class; Production Road Racer at World Of Wheels Chicago 2013. Ford BOSS 347 short block, Dart Al heads.. 360 RWHP, T-5 Z, IRS W/ Detroit Truetrac & 3.73s, SN95 spindles w/SAI mod, 99 PBR brakes, AGR Power Steering, and a Load of engineering changes. Graduation Post #22
11.75 sec. in the 1/4 mile
Jack Wojack is offline
post #7 of 25 (permalink) Old 03-14-2013, 04:25 PM
Avalanche325's Avatar
Do some reading on this one before you buy. THere are a couple good posts. On one, I linked out to a very good article.
Basically, the newer (SN95) racks are way better than the Fox ones. More precise helical gears, and a different torsion bar. AGR makes a Mustang Cobra R type and also a special Cobra replica rack.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #8 of 25 (permalink) Old 03-14-2013, 10:15 PM Thread Starter
All,
Thanks for your replies. I am trying to keep the price down somewhat as I almost to my budget limit and I have a ways to go. I can see that my time line will creep due to funds availability. I can see that this is usually the norm though.
BD
post #9 of 25 (permalink) Old 03-14-2013, 11:25 PM
Dan, if your car is a MkII or III you will need a different lower u-joint. The splines on the PS rack are very different than the manual rack. If it's a MkIV, the rack is still different but you may need an entire steering shaft. I am not sure on that but the MkIV shaft isn't made up of a lot of seperate pieces like the older shafts were.
CraigS is offline
post #10 of 25 (permalink) Old 03-15-2013, 12:29 AM
Dan, as Craig said your Mk3 will need a different spline on the lower shafts U-joint (power racks use 3/4" 36 spline while manual are 9/16" 26 spline). I've found that it can take a little digging to come up with the proper Mk3 power rack shaft or joint because they are unique and not interchangeable with earlier Mk1 & 2 or later Mk3.1 and Mk4.
Good luck,
post #11 of 25 (permalink) Old 03-15-2013, 12:30 AM
BOB SCHAEFER's Avatar
I went with new stock pump and rack and it works perfect but it sure doesn't look cool like those polished ones. Honestly, I didn't even know about the cool stuf or I might of gone that route.
FFR 6635...331 w/ Kenne Bell Supercharger, PS, Koni's, 3.55 Tru Trac AOD
BOB SCHAEFER is offline
post #12 of 25 (permalink) Old 03-15-2013, 02:25 AM
In between Autozone and AGR:
in any case remember your solid aluminum rack mounting bushings:
Mark Reynolds is offline
post #13 of 25 (permalink) Old 03-15-2013, 03:03 AM
*** CAD Librarian ***
i would highly recommend the Breeze rack for another $129 over the Autozone rack, no matter how tight the budget. much, much, better quality. the autozone unit is likely to be spray-painted blue, the hard lines and all.
i returned the autozone rack - twice. i got full money back, but i was on my own for two more alignments.
Mark said get the aluminum bushings, but a cheaper alternative are these:
http://www.summitracing.com/parts/pt...tang/year/1990
they lower the rack and reduce bumpsteer (a bit) and at the very least, they give LOADS more room under the x-member for the hard line fittings. much easier to get the wrench in there.
the best $12.95 you can spend on the car.
if you insist on the Autozone unit, pull on the rod ends, and see if there is a lot of play before you walk out with it.
_
_
NiceGuyEddie is offline
post #14 of 25 (permalink) Old 03-17-2013, 02:53 PM Thread Starter
All,
I hate every single one of you. You guys are spending my money faster than my wife. This car had better be greater than sex. Breeze for steering it will be.
BD
post #15 of 25 (permalink) Old 03-17-2013, 04:12 PM
MPTech's Avatar
I originally bought a manual rack, then decided to go with the power after driving a couple other FFRs. At speed the manual is fine, but they are a bear on a parking lot or backing up. The difference is well worth it. I went with the 3.0 ratio and really like it.
Jeff's plan is right on the mark. I followed it to the T.
  • Power Steering Rack 93 Mustang, 3.0 turn. Part# 6406 (Reman from Autozone)
  • OEM Mustang pump
  • CFR bracket
  • Breeze Rack bushings
  • CFR Performance PS Pulley
  • Breeze Braided Stainless Steel lines and AN fittings
Breeze Offset Rack Mounting Kit
Speedway 5" Aluminum Tie Rod Sleeve, 5/8"
and a warning about the llinks length for setting caster.
Lots of caster? A WARNING
also take a look at my post about the SS hoses, I was fighting the fittings for a while. That Teflon is a bitch.
Power Steering almost done, but slight leak
MPTech is online now
post #16 of 25 (permalink) Old 04-11-2013, 02:40 PM
FFCobra Captain
Dan Babb's Avatar
The u-joints I have on my steering rack right now are the older clamp on style (see picture). The lower shaft is 3/4" round and splined (don't know how many splines though).
I found this part on Speedway. It's a weld-on u-joint.
Sweet Mfg Steering U-Joint, 3/4 36-Spline to 3/4 Round, GM Manual/Mustang II - Speedway Motors, America's Oldest Speed Shop
I guess I could buy this piece and have it welded to the stock shaft I have. The fact that the splines on the lower shaft wouldn't be used shouldn't be an issue..correct?
Does anyone have a part number for a similar clamp on style u-joint that I could buy or is a weld-on u-joint the only option?
I have a thread in the Classified section here looking for the FFR piece too. Just trying to find the easiest way to convert to power steering.
EDIT....since this post comes up a bit, I figured I would update my info post.
On a MK3 that has the manual steering shaft with the bolt on u-joint, you need this part from UniSteer to replace the lower u-joint shown in my picture.
U-Joint 3/4"-36 (Ford) x 9/16"-30
UniSteer Part Number: 8050500
FFR5857
PS/PB/AC
Dan Babb is offline
post #17 of 25 (permalink) Old 07-02-2014, 11:42 PM
Caress of Steel
Joe Campbell's Avatar
Is there a trick to assembling the Breeze lines I"m missing? For some reason, the rack end of the pressure line will not seal up - it keeps crushing the end of the teflon when I thread the collar on. I've snipped the end off three times now to get a clean cut to work with, using one of the big braided line cutters I snagged from a hot rod store. Argh!
; '11 Mustang 5.0 'vert; '07 Legacy Spec.B; '98 F150;
I'll give up my clutch when they pry it from my cold dead toes.
Si vis pacem para bellum.
Joe Campbell is offline
post #18 of 25 (permalink) Old 07-18-2014, 02:02 PM
Great Help for P/S
This post saved me tons of time. Thanks
Doctor Moe is offline
post #19 of 25 (permalink) Old 07-21-2016, 02:52 PM
Bearhawk Builder's Avatar
Just a note on the false economy of the Autozone 6406 rack. It took them 5 tries to get a 3 turn rack in and I just blew it out Tuesday at 482 miles. Ordered a new one yesterday, drove the 40 miles to pick it up this morning and it's the wrong one again (2 1/2 turn instead of 3). They have no way to ensure that you will get the right one until the box shows up and they won't order more than one at a time. It may work out well sometimes but it's a real crap shoot. Just ordered one from Mark at Breeze, more expensive but is it really?
Bearhawk Builder is offline
post #20 of 25 (permalink) Old 07-21-2016, 04:03 PM
johnnybgoode's Avatar
Hey just thought I would add to this thread based on Bearhawk's comment. I bought the 6406 rack as well and when I got it home I put the lower universal on and counted the turns to get the rack centered. Low and behold it was 2.5 tuns (-ish) maybe 2.75. I went ahead and installed it but have since pulled the boots to add limiters and guess what there were 1/4" limiters already installed on both sides of the rack. I've added 2 more for a total of 1/2" which keeps my 245's off of the F-panels at full lock. So just an FYI on what I found. Also my old rack that I thought was 2.25 turns was really 2.5 as it had a set of limiters on it as well. I pulled them off the core for future use, which came in handy. Scott
ps. the new rack feels pretty good, hopefully it will hold up. I'll update this thread if not.
FFR #3870 MK II, Spectra Blue/Arctic White, 1974 414W, 10:1, Eagle 4340 crank and rods, KB Pistons, Ported Performer RPM 2.02 heads & intake, QFT SS-650, Comp XR282HR, Quality Roadsters pan, Crane ignition, TKO600, 3.55 gears, 3 link, QA1's, Tubular LCA's, Heim joints & VPM F/R bars, Power steering with Hiedts valve, Power brakes, Fortes bump steer kit, 5 bolt axels, SSBC rear brakes, Oil cooler, Pusher fans, Halibrand Cobra III's with Nitto 555 245/275/17
johnnybgoode is online now
post #21 of 25 (permalink) Old 07-22-2016, 01:48 AM
I have always said, they are the same rack, limiters determine the # of turns lock to lock. You want a 3 turn rack, take out the limiters, want a 2.25 turn to turn, add a limiter.
rich grsc is online now
post #22 of 25 (permalink) Old 07-22-2016, 09:25 AM
Sorry, but that wasn't the case here, no limiters.
post #23 of 25 (permalink) Old 07-22-2016, 11:01 AM
Per Jeff Kleiner:
Jeff,
I was wondering if you had any insight into the FF "Coyote power steering setup" offered as an option for $399. When I first started researching power steering options, the price all-in was well north of that. EdwardB did a nice job of describing his selection and pricing for each alternative.
When I first saw the FF setup, I was concerned the hardware might be of a significantly lower quality in order to provide a complete setup at that price point. Did FF simply follow a path as you described above?
mmklaxer is offline
post #24 of 25 (permalink) Old 07-22-2016, 12:37 PM
MCathcart's Avatar
IMO... I had 15"s on #2335 and the steering was fine (with the manual Flaming River Rack). #7787 has 17"s the additional tire width on the front pushes the limit in a parking lot or low speeds. I'm now pondering adding power steering with the poly off-set bushings too.
MCathcart is offline
post #25 of 25 (permalink) Old 07-22-2016, 09:32 PM
I can't tell if you are joking.
If not:
Maybe they are that way from the cheapo parts stores, but not a quality P/S rack. They actually have a different ratio. I have an AGR rack and rarely have to move my hands at an autocross while other guys are shuffle steering.
If so:
That there is funny right there.
