Gluing Carpet??? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 13 (permalink) Old 03-03-2013, 01:52 PM Thread Starter
Gluing Carpet???
Anyone use silicone adhesive like RTV to install carpet? Working on a project(not ff5 car) where spray adhesive won't work ...need time to adjust and go around things....any thoughts, looked at Henry 663 bow it's to cold to set....garage is 55 degrees. Has anyone tried Henry 263?
Jon
Saltshaker is online now
post #2 of 13 (permalink) Old 03-03-2013, 03:17 PM
steno's Avatar
I just used a general tile adhesive.gave me the time I needed and wasn't messy. Not really bad for removal either!
steno is online now
post #3 of 13 (permalink) Old 03-03-2013, 05:49 PM
timp2's Avatar
I used silicone on the bottom most parts of the floor carpet because I used silicone to seal some of the sheet metal to the round tubes and contact cement would not adhere to it. The silicone worked just fine.
FFR 6055, 351W engine in 5/09, TKO 500, Pin Drive IRS, Non-donor build, Trigo 15's, Wimbledon White with Anthracite stripes. Inspected and street legal 12 Oct 2011
timp2 is offline
post #4 of 13 (permalink) Old 03-03-2013, 07:44 PM
AC Bill's Avatar
I used black silicone between the carpet and the insulation material..3 years and all is well.
Hint- Black silicone is less likely to show if you get a little sloppy..lol
AC Bill is offline
post #5 of 13 (permalink) Old 03-03-2013, 09:41 PM
PaulW's Avatar
Interesting
A timely thread as my new (brown) carpet arrived and I am getting ready to install the insulation and carpet. I had always assumed that you just use the spray adhesive for both. Is there an advantage to using silicone and would you use it on the vertical surfaces as well or just the floor?
Paul
FFR Mark IV 7411 Picked up 04/08/11
First go-cart 08/31/11
Graduation May, 2013
Sold 30/06/14
Kit delivered 06/19/15
FE 390, 4 speed Toploader
S/C configuration
Go-cart October 2015
Licensed and Driving 03/22/16
"Badges, Badges? We don't need no stinkin' Badges!"
PaulW is offline
post #6 of 13 (permalink) Old 03-03-2013, 10:18 PM
Husband/Father/Son
mrmustang's Avatar
Jon
Listen to MrMustang you must, yyyyyeeeessssss hhhhhhhhhhhhhhhhhmmmmmmmmmmmmmm'
3M™ Repositionable Spray Adhesive 75
Now go and find a heated area that you can get warmed up to a minimum of 60 degrees.
mrmustang is offline
post #7 of 13 (permalink) Old 03-04-2013, 12:22 AM Thread Starter
Silicone
Anyone else had success using Silicone? What brand, how was it applyed ??
Jon
post #8 of 13 (permalink) Old 03-04-2013, 02:04 AM
jrflyan's Avatar
I used the 3M high strength spray for a majority of the carpet. In some of the tighter places or vertical locations I used clear silicone. It is still holding after 1 year and a track day... Good luck
jrflyan is offline
post #9 of 13 (permalink) Old 03-04-2013, 09:34 AM
CRZN 427's Avatar
Why??
.....spray adhesive won't work ...jon
Why do you think spray won't work? A little more detail, or pictures might help.
Have you considered Urethane spray? It comes out of the nozzle in more of a stream than a spray and can be directed to small spaces a little easier, and is workable for a few minutes. I got mine at an upholstery supply store (can has a full yellow paper label).
If over spay is the problem, use masking.
I use quite a bit of E-6000 Silicone on my tops. It works OK but skins over in about five minutes and is a pain to apply in hard to reach spaces but it will glue almost anything to almost anything else, I get it at my local ACE in a hand squeeze tube...and it is smelly.
I also use 3M Super 77 spray, works good as well, with five to ten minute work time.
Regards, Rick.
CRZN 427 is offline
post #10 of 13 (permalink) Old 03-04-2013, 01:52 PM Thread Starter
This is a not a factory 5 project where the carpet needs to be slid under a lip or behind the down bar which is within a inch of the body.need working time so the carpet can be moved and adjusted.
Jon
post #11 of 13 (permalink) Old 03-04-2013, 02:11 PM
Howff's Avatar
Weldwood gel contact cement
Howff is offline
post #12 of 13 (permalink) Old 03-04-2013, 05:54 PM
AC Bill's Avatar
I used an "automotive" silicone (not RTV though), on all vertical carpets, with no issue of slippage. Once in place, I applied pressure (by hand), to the carpet to help the silicone under it to spread. This created a good firm adhesion.
Advantage in using silicone was the allowable working time, and the ease of slipping the carpet up against other pieces of carpet, to make nice tight seams.
Place a bead at the edges of each carpet piece, as well as several X beads in the middle area.
Another tip - spray some flat black paint at all the seam points of the carpet, prior to gluing it in, on the insulation. This will prevent any silver insulation from showing through at the seams.
AC Bill is offline
post #13 of 13 (permalink) Old 03-04-2013, 06:41 PM
CRZN 427's Avatar
Another view
Jon
If there were more info a more detailed response could be offered, but...
I know from your first post that it isn't an FFR project.
In cases where the carpet has to go under a lip, I would likely apply the glue up to that area and not under the lip at all. If it is secured up to the point it goes under something, and is under something, it isn't going anywhere and will make future replacement much easier.
If you are concerned about weather proofing with the carpet adhesive, do that as an independent activity and then put the carpet under the lip.
As for around down bars, after the carpet is fitted is there enough room to pull the section that is behind the obstruction and apply a dab of glue, or tape, to the under side? If it is behind something will it be visible? If not visible will it really need to be attached in that small area?
Just some random thoughts again.
Regards, Rick.
CRZN 427 is offline
