Tko alignment problem - FFCars.com : Factory Five Racing Discussion Forum
Old 11-02-2012, 12:23 AM   #1 (permalink)
luey2009's Avatar
Ive got my flywheel installed, clutch and pressure plate, aligned and installed,and the quicktime bellhousing installed. My tranny stops with about a 1/2'' left to go in. I checked the pilot bearing when I installed it on the crank,no prob there. Checked the clutch plate, no prob. Just seems to stop short and wont go in any further. any thoughts? did a search, but couldnt find the answer I need. could the input shaft be to long?
FFR #7815 mk4 complete kit ordered 4/23/12, kit completion date 5/26/12,delivered 6/3/12,roller w/lights 9/15/12, motor installed 11/3/12,first start 11/24/12
Old 11-02-2012, 12:38 AM   #2 (permalink)
I have run into this a couple of times. In my case I did not have the clutch aligned close enough to assemble it. I used a large pry bar to engage the clutch and it slid right in. Not sure if this is the same problem as yours. Try also installing a dowel into the bearing and the mark it where it exits the bell housing. Measure that and compare it to you input shaft.
Old 11-02-2012, 12:45 AM   #3 (permalink)
luey2009's Avatar
I will try the dowel trick. can you explain the prybar procedure for me, im not sure I follow, thanks-Andy
Old 11-02-2012, 01:21 AM   #4 (permalink)
I used the pry bar to move the clutch fork thereby actuating the clutch.
Old 11-02-2012, 01:47 AM   #5 (permalink)
QSL
Stealth Ninja FFR builder
QSL's Avatar
X2... that while shaking the trans gently and pushing it in. Its really a two person job. I used a very long socket extension interlocked into the clutch fork.
MK4 delivery 12/17/11
Build thread: HERE
Epic First start video HERE
Build thread: HERE
Old 11-02-2012, 01:48 AM   #6 (permalink)
We know what you're up to
Don Payne's Avatar
Your clutch is not quite aligned yet. Loosen up the pressure plate and try aligning it again. It is frustrating, but that is why it will not go in. Did the same thing to me a couple of weeks ago.
-Don
Old 11-02-2012, 01:53 AM   #7 (permalink)
Do you have a pilot bushing or roller bearing?
Like the others have said, your clutch is not exactly aligned.
If you have the roller bearing, check it to make sure this didn't happen.
Old 11-02-2012, 01:58 AM   #8 (permalink)
Mike Forte's Avatar
Hi luey,
Give me a call and we can go over the parts list and figure what's wrong.
Mike Forte
Forte's Parts Connection
40 Pearl Street
Framingham, Mass. 01702
mikeforte302@gmail.com
508 875 0016
www.fortesparts.com
The Early Ford & FE Tremec were also originals from Mike. The Mustang firewall adjustable quadrant kit also is an original from Mike. His latest developements are external slave clutch release conversions & cable release conversions too.
Old 11-02-2012, 02:03 AM   #9 (permalink)
luey2009's Avatar
I do have a roller bearing, I will check it and see what it looks like
Old 11-02-2012, 02:04 AM   #10 (permalink)
luey2009's Avatar
Originally Posted by Mike Forte View Post
Hi luey,
ok thanks Mike, will call you tomorrow
Old 11-02-2012, 02:40 AM   #11 (permalink)
You might check the inside diameter of the bearing and the outside diameter of the input shaft and make sure the bearing is the right size
People make mistakes all the time someone could have just grabbed the wrong part for you
bigwindsor is offline   Reply With Quote
Old 11-02-2012, 04:44 AM   #12 (permalink)
luey2009's Avatar
are you referring to the throw out bearing diameter?
Old 11-02-2012, 10:10 AM   #13 (permalink)
Tennessee Tim's Avatar
One way to make it a one-person job is to use a long carriage bolt or a piece of all-thread to pull the clutch into the disengaged position and hold it there while you fit the transmission.
Tim
Tennessee Tim is online now   Reply With Quote
Old 11-02-2012, 11:31 AM   #14 (permalink)
Wade Chamberlain's Avatar
good idea Tim. A big C-clamp works too.
Wade Chamberlain
FFR2229K
Old 11-02-2012, 01:24 PM   #15 (permalink)
luey2009's Avatar
thanks for the tips guys. still messing with it this morning, just wont go that last 1/2". how far does the fork need to go forward, and how much pressure should I be applying to it? How much force should I be pushing on the trans as im trying to push it in? The clutch alignment tool goes in and out perfectly, so I think its aligned ok. gonna try to get an extra set of hands tonight
Old 11-02-2012, 02:04 PM   #16 (permalink)
QSL
QSL's Avatar
you just about ned to go full throw on it. The trans should slide in easy without forcing. Just slight wiggling. If that does not do the trick, something else is wrong.
Build thread: HERE
Build thread: HERE
Old 11-02-2012, 02:07 PM   #17 (permalink)
FFR5452's Avatar
TKO trannys can come with two different length input shafts depending on your engine choice.
Make sure the input shaft on your trans is the right length for your engine.
FFR5452 is offline   Reply With Quote
Old 11-02-2012, 05:55 PM   #18 (permalink)
BigLeo69's Avatar
Icon21
first did you align your bellhousing to the block
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
Old 11-03-2012, 08:21 PM   #19 (permalink)
luey2009's Avatar
everything went in with a little wiggling, thanks for the tips guys!
Old 11-03-2012, 10:02 PM   #20 (permalink)
FFR5452's Avatar
Are we still talking about transmissions?
