Clutch Line - Need Feedback - FFCars.com : Factory Five Racing Discussion Forum
Old 10-29-2012, 09:19 PM   #1 (permalink)
I decided a while back (right or wrong) to run the clutch line along the frame tube inside of the footbox and exiting on the engine side (see pics).
I used a rubber grommet to protect the line, and it's been on my list for a long time to replace the grommet with a bulkhead fitting.
The dilemma: I'm tempted to just leave the rubber grommet and button up the footbox (I'm close to being done with the chassis) - do I really need the bulkhead fitting?
Troy
FFR #7473 MK IV, 351w 393, ~500hp to flywheel, Quick Fuel 750, Performer RPM Air Gap, 3.73 rear, T5Z, King Cobra HD clutch, 15" FFR halibrands, 295/50R15 Cooper Cobras
http://slowcookedcobra.blogspot.com/
tahamsh is offline   Reply With Quote
Old 10-29-2012, 09:26 PM   #2 (permalink)
Rich A's Avatar
Originally Posted by tahamsh View Post
... do I really need the bulkhead fitting?...
No, as long as the grommet does the job of keep the line from rubbing.
If you use a bulkhead fitting an it starts to leak you won't be happy trying to tighten/replace it.
Old 10-29-2012, 10:47 PM   #3 (permalink)
Jack Wojack's Avatar
Put some insulation between the line and the front wall of the foot box and I think you should be good to go.
Jack
Old 10-30-2012, 02:15 PM   #4 (permalink)
Thanks for the feedback!
