Windshield Holes not correct...@#$%^&^% - FFCars.com : Factory Five Racing Discussion Forum
Old 10-25-2012, 10:57 PM   #1 (permalink)
Struggling New Guy
NAVYDUDE's Avatar
Gentlemen,
If you could, (I have a MK4 if it matters) Could you tell me the distance from the body to the rear of your cutout using the outside length of the hole as the reference?
I guess its my fault for not VERIFYING the measurements are the same for both sides and correct (measure thrice and cut once). BUT from FFR, My drivers side outline was outlined from about the 3 to the 5" mark and the passenger side is almost 3/4 of an inch forward... again....!@#$%^&
I still need to trim the usual 2" offthe bottom of the side frames , but still pointless if the body holes arent lined up correctly and the passenger side is 3/4" forward of the drivers side.
Thanks again fellas.
Received 8 JUN 2012
Roller 20 JUL 2012
Go Cart ??
Legal ??,
NAVYDUDE is offline   Reply With Quote
Old 10-26-2012, 02:18 AM   #2 (permalink)
samadhi's Avatar
As cut by ffr
Tape is along seam.
(Uploaded using latest iPhone app, see if it works)
Vic
FFR 7502
408w
rhs 200
rpm airgap
750 Speed Demon
Over budget funding provided by my wife's business, the best yoga studio in Ottawa!
First start... check
Go-kart... check
body on drive... waiting on insurance appraisal
samadhi is offline   Reply With Quote
Old 10-26-2012, 02:59 AM   #3 (permalink)
Struggling New Guy
NAVYDUDE's Avatar
Vic !!!!!!
AGAIN- you pulled it out!!! It looks like yours are cut from 3 1/4" to 5". I'll make the adjustment to the passenger body tomorrow since my drivers side matches yours, then trim the windshield frames and see how things line up !! Thanks again my friend- well thats at least two cold ones I owe you.
Received 8 JUN 2012
Roller 20 JUL 2012
Go Cart ??
Legal ??,
Old 10-26-2012, 03:17 AM   #4 (permalink)
samadhi's Avatar
A heads up.
The passenger side is not right on the seam line.
Passenger side is inside. ImageUploadedByAutoguide1351221476.817882.jpgImageUploadedByAutoguide1351221476.817882.jpg
FFR 7502
408w
rhs 200
rpm airgap
750 Speed Demon
Go-kart... check
Old 10-26-2012, 03:19 AM   #5 (permalink)
samadhi's Avatar
Baffled me at first,as many things do, but other mk4's I've seen are the same.
Cheers
FFR 7502
408w
rhs 200
rpm airgap
750 Speed Demon
Go-kart... check
Old 10-26-2012, 03:37 AM   #6 (permalink)
Struggling New Guy
NAVYDUDE's Avatar
VIC, heres my problem
Received 8 JUN 2012
Roller 20 JUL 2012
Go Cart ??
Legal ??,
Old 10-26-2012, 03:48 AM   #7 (permalink)
samadhi's Avatar
Can you tell where the body seams are? The drivers side runs right inside the seam while the passenger side runs an inch on the inside.
BUT... I've never tried to mount my windshield, this is what ffr cut, it may be wrong.
FFR 7502
408w
rhs 200
rpm airgap
750 Speed Demon
Go-kart... check
Old 10-26-2012, 04:02 AM   #8 (permalink)
Struggling New Guy
NAVYDUDE's Avatar
VIC,
I can get the windshield frames through the body slots and along side of the mounting points, my problem is the right slot is 1/4" forward or the drivers side-
I'm trying to figure out if the passenger side is too far forward (or correct), or is the driver side too far rearward (or correct)
Received 8 JUN 2012
Roller 20 JUL 2012
Go Cart ??
Legal ??,
Old 10-26-2012, 04:32 AM   #9 (permalink)
COMPETITIONCOBRA's Avatar
Dismantle the windshield posts from the frame and set each one in and see how they sit and adjust the holes forward or back so that the posts are centered so that you can bolt them to the chassis. Obviously in the end they should be the same distance from the dash edge.
COMPETITIONCOBRA is offline   Reply With Quote
Old 10-26-2012, 05:56 AM   #10 (permalink)
CRZN 427's Avatar
Not To Worry.
Remember that the body is not symmetrical. The differences you are talking about are normal from my experience, mostly MK-I and MK-II mind you.
If you need to verify Cobr@ bodies are not symmetrical, check with the Kirkham brothers.
Regards, Rick.
CRZN 427 is offline   Reply With Quote
Old 10-26-2012, 06:54 AM   #11 (permalink)
AC Bill's Avatar
Try and prevent any pressure on the posts, from the body pressing against them, when the WS is installed.
Enlarging the post holes longer and wider, is standard procedure. The post bezel covers it anyway..
Old 10-26-2012, 09:38 AM   #12 (permalink)
samadhi's Avatar
If you need better pics I can take them.
Let me knowq
FFR 7502
408w
rhs 200
rpm airgap
750 Speed Demon
Go-kart... check
Old 10-26-2012, 10:54 AM   #13 (permalink)
jolsen42's Avatar
There's your answer!
John O
FFR1293-289 slab side Mr Bruce body, 289 hi-po, Tremec TKO, 3-link 3.55 rear, spoked pin drive wheels, under car exhaust. A facsimile of CSX 2367.
jolsen42 is offline   Reply With Quote
Old 10-26-2012, 01:37 PM   #14 (permalink)
OMG off by a 1/4"
Old 10-26-2012, 01:49 PM   #15 (permalink)
BigLeo69's Avatar
on my mk3.1 the layout holes were off, and of course everytime you pull the body there will be a difference, main thing is to keep clearance around the post.
i actually didn't like the escutheons that F5R supplied and made my own, covers the hole and i actually had room on the passengers sie to slide a wrench from the top of body along the WS post and bolt it up.
here is a thread on it:
those chincy windscreen escutheons
this area too at the posts you will find that the drivers side you have to conform your body to get to the bolts, mine was made much easier because i moved my fuse panel to the passengers side at the glove box area.
water likes to come in around this area too, so when your done with the paint and are ready to install the finish pieces seal this area up.
did i mention water likes to come in everywhere.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
Old 10-26-2012, 02:11 PM   #16 (permalink)
emac's Avatar
FWIW, I had to open my holes up to get the windshield to fit without touching the body. Also, I had to put a couple of washers between the frame and the windshield mounting arms. I noticed as I tightened the windshield it would flex and create a gap on the body. The washers kept the winshield from flexing. I guess you could have bent the arms, but I was trying my best NOT to crack the windshield!
351 tko 500
Delivered Nov 13, 2011
First start December 31, 2011
First gocart Jan 12 ,2012
Graduation 05/12/201
graduation thread
Old 10-26-2012, 02:23 PM   #17 (permalink)
BigLeo69's Avatar
Thumbs up
did the washer shim too on drivers side, a bit of a trick but here something that will help on the install if you need to shim, take some spray contact spray it on the washer slide it over into the hole area to get some of the glue on the frame then remove it spray a bit more on the washer let sit to dry then stick the washers onto the frame, less fumbling of the fingers when you go put the bolts thru.
372w handbuilt
Old 10-26-2012, 04:46 PM   #18 (permalink)
CRZN 427's Avatar
Windshield Support Posts
The support posts have about an 8 degree bend as they exit the body. It is possible that the posts were slightly damaged (the bed was changed) during manufacture or shipping.
The important thing is to insure that when the posts are firmly attached to the chassis, the wiindshield frame fits to them without any flexing of the posts. If there is a need to flex the posts to get them to fit, there will be un-necessary stress in the mounting screws that go into the brass strips. It is understood that the posts need to be clear of the body as they pass through.
HTH Regards, Rick.
Old 10-26-2012, 05:20 PM   #19 (permalink)
Scott L's Avatar
I centered the body over my front wheels, and wound up moving the factory windshield cut-outs. I had to glass in the factory cut holes from underneath to fill the 1/2" gap this created.
Hope you find a less extreme solution.
Scott L is offline   Reply With Quote
Old 10-26-2012, 08:33 PM   #20 (permalink)
wideglidejoe's Avatar
X2 what Scott L said on my MK3
Wideglidejoe
FFR#6143 Mk III: FE 455" w/TKO 600 .82, IRS w/3.27's, 17" Team III's w/245/45's & 315/35's. Gas N pipes.
Picked it up end of Aug '08
First start 5-12-10
First go kart 5-26-10
wideglidejoe is offline   Reply With Quote
