5" Al vs. 4" Fe? - FFCars.com : Factory Five Racing Discussion Forum
Old 10-22-2012, 02:37 AM   #1 (permalink)
hoofa's Avatar
5" Al vs. 4" Fe?
hoofa is offline   Reply With Quote
Old 10-22-2012, 02:40 AM   #2 (permalink)
h82crash's Avatar
Building your own frame?
Tom
Old 10-22-2012, 03:33 AM   #3 (permalink)
MPTech's Avatar
How thick is the Al? and what's the weight difference?
Licensed 4/24/13!! Wahoo!
Old 10-22-2012, 05:31 AM   #4 (permalink)
h82crash's Avatar
What did Factory Five use for their aluminum frame?
Tom
Old 10-22-2012, 01:25 PM   #5 (permalink)
Aluminum is about half the weight of steel and the more common 6061-t6 is about half the strength. After welding the aluminum frame it would have to be reheat treated. Aluminum also has the bad habit of fatigue cracking after a few years of use. It can be done but has draw backs you should be aware of.
Bill Lomenick
Old 10-22-2012, 02:27 PM   #6 (permalink)
Plodding Along
CCRsAC's Avatar
He's back!!!
Couldn't help notice the prominent first aid kit to the right in the photo. Given some of Hoofa's past projects, this is probably a good idea!
Later,
Chris
Mk3.1 #7074
Picked-up at FFR - 10/10/09
CCRsAC is offline   Reply With Quote
Old 10-22-2012, 03:25 PM   #7 (permalink)
AC Bill's Avatar
OMG!
Hoofa, has it gotten to the point in your build that you have hacked, and slashed, and sawed, so much, that you now need a new frame?
I'm thinking any dent in a round aluminum tube frame, would really weaken it. Might be better to go with square tube aluminum. Easier to weld too..
Old 10-22-2012, 03:29 PM   #8 (permalink)
h82crash's Avatar
Like Bill said, fatigue in aluminum is cumulative over time. So the design needs to identify areas of stress and increase strength in those areas. Still, if built right, should last 30+ years. Gonna need a pretty large heat treat oven. 900 degrees for 10 hours and a quench should do it.
As opposed to steel which can be stressed over and over and as long as it is not pushed past its molecular elasticity, will last forever (figuratively).
Tom
Old 10-23-2012, 06:06 PM   #9 (permalink)
hoofa's Avatar
I'm gonna skip the heat treat, it only has to last for two days.
Old 10-23-2012, 06:17 PM   #10 (permalink)
h82crash's Avatar
Something you know that we don't? Nuclear attack? Alien abduction? Economic melt down?
Tom
Old 10-23-2012, 06:24 PM   #11 (permalink)
s cobra's Avatar
May-pole
s cobra is offline   Reply With Quote
Old 10-23-2012, 10:01 PM   #12 (permalink)
Sanford's Avatar
He's building his own personal HARP system. Gonna mess with the weather and tectonic plates??? lol
Old 10-24-2012, 03:01 AM   #13 (permalink)
Technic-Fan's Avatar
Festivus Pole
Technic-Fan is online now   Reply With Quote
Old 10-24-2012, 03:42 PM   #14 (permalink)
AC Bill's Avatar
Custom "Green" cloths dryer?
Heck, a guy has to wash his underwear at least once a year.
