PCV or NO PCV Valve - FFCars.com : Factory Five Racing Discussion Forum
Old 10-20-2012, 05:31 PM   #1 (permalink)
PCV or NO PCV Valve
I have a Ford 302 crate motor and I do understand I need to ventilate the crankcase.
The question is it better to use a PCV valve or not? I read that providing a PCV valve promotes better crankcase ventilation from the neg pressure created in the manifold. On the down side it is not as attractive as just putting a ordinary valve cover vent in.
We do not need it for emission control where I live.
Thoughts??
Jon
MK4 Complete Kit delivered 11/3/11,Ford 302 Boss 345 hp,IRS,Wilwood brakes
jmwdl is offline   Reply With Quote
Old 10-20-2012, 05:39 PM   #2 (permalink)
New
SeanHM's Avatar
I did away with mine, FWIW. Ditched the valve cover to TB line too. And just made a block off for the IAC.
SeanHM is offline   Reply With Quote
Old 10-20-2012, 05:46 PM   #3 (permalink)
I gave up on PCV cause I autocross and couldn't keep it from sucking in oil mist during longer duration turns and fogging behind me. But, in general it's a good idea that doesn't really have any downsides performancewise. If you want to be semi emissions concious you could run a vent hose from the VC into the underside of the air cleaner.
Old 10-21-2012, 01:50 AM   #4 (permalink)
Drop Zone's Avatar
I agree ditch the PCVl, but if you want it I would go with one of these from Billet Specialties Breathers / PCV Breathers | Billet Specialties, Inc.
Drop Zone is online now   Reply With Quote
Old 10-21-2012, 03:35 AM   #5 (permalink)
Cobra Jon's Avatar
I would highly recommend keeping the pcv valve... it's not an emissions device, it's for removing unwanted combustion vapors and moisture from the oil.
Cobra Jon is offline   Reply With Quote
Old 10-21-2012, 10:10 AM   #6 (permalink)
A PCV really isn't an issue on a street car. It does help with crankcase pressure, and venting the opposite side to the air cleaner limits where the oil vapors go.
On a track car, there needs to be a lot more control of oil vapors. http://www.racingicons.com/sale/351-7.jpg
Blowby and oil vapor still have to be addressed, having a breather dump oil all over the valve covers won't be any better looking than a PCV installation. Nobody builds a zero percent blowby motor.
Old 10-21-2012, 05:31 PM   #7 (permalink)
Plodding Along
CCRsAC's Avatar
I used filtered breathers to a central canister (repro of the catch can from the 427 comp cars) mounted on the firewall. From there, there is an additional drain line that goes to a separate catch can. This way, the breathers are vented to the atmosphere, but I'm also ensuring that I don't dump condensation or oil on the tires (or the road).
Later,
Chris
Mk3.1 #7074
Picked-up at FFR - 10/10/09
CCRsAC is offline   Reply With Quote
