Anybody know if I can but new bushing for the ends of the Koni shocks. I havent been able to fine them. They come out with the removal of a snap ring.
Thanks Mike
Thanks Mike
If your talking about the aluminum end caps that hold the spring in, answer is yes, as I bought some replacements from FFR for like $20 each
Tony Nadalin
2012 ICSCC ITE Class Champion My Garage
No. I am looking for the plastic in the rod ends. The part the mounting bolt passes through.
OK, mine are metal not plastic, like a tie rod end
Tony Nadalin
i would think you could machine one out of nylok or aluminum
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
I probably didnt explain that very well. The ball the bolt passes throough is metal. The pieces that capture the ball are plastic. I need the plastic part.
It is unlikely that you will find the outside piece (race) separately. If you can get the bearing out by removing the snap rings and can measure the critical dimensions, inside and outside diameters and width, you will find many sources to buy a new spherical bearing.
Mike, I'm guessing you'll have to replace the entire bearing unit. My Koni 3012 shocks had the spherical bearing replaced with Penske pieces that had less slop in them... metal/metal, no plastic to wear out. Did you try Koni-NA, I'm guessing they'll have to stock replacement pieces, or the upgraded bearings too...
MkIII, 351W with all the fixin\'s...
Either here Truechoice Koni Racing Services
or here The Chassis Shop
Do a little checking as the ones in my konis looked more like the high misalignment versions in the pegasus link. The last time I did this I ordered from the chassis shop, checking ID and OD for a match. What I got was narrower than what was in my Konis (DAs from Levy) originally. It wasn't a big deal but I needed to add some extra length to the spacers. So check ID, OD, and width at the ID.
