Hood Problems When CLosing - FFCars.com : Factory Five Racing Discussion Forum
Old 10-05-2012, 06:27 PM   #1 (permalink)
jims09build's Avatar
Hi All,
Car is painted and ready to drive(If I ever get a weekend without Rain) The problem is before paint the hood closed perfectly. Now when I close it the driver side front corner does not go down level. I can push it down easily with 1 finger and it will stay there. But each time I open and close it, it does the same thing. Nothing seem to be holding it up underneath. It's driving me NUTS!
Jim in Pa
jims09build is offline   Reply With Quote
Old 10-05-2012, 07:00 PM   #2 (permalink)
Mr. Barry's Avatar
Take a piece of white chalk, and rub it over the offending corner (and a few inches beyond), ....Close the hood, and push down...When you raise the hood, you will probably see that the paint is rubbing somewhere close to the corner....
Hard to see when everything is the same color.
Edward
Mr. Barry is offline   Reply With Quote
Old 10-05-2012, 07:34 PM   #3 (permalink)
Edward
It's not hitting anything. I can push it down and it stays down. All the moving hinge parts are fairly loose so nothing is binding. Thanks
Old 10-05-2012, 08:23 PM   #4 (permalink)
Mr. Barry's Avatar
Not trying to be a "wise guy", but just trying to give you a suggestion....
Something is keeping the corner from dropping, until you push it down, (with no effort)....
I get that...But , having myself painted quite a few cars, I have found that sometimes the obvious is overlooked....The chalk may prove nothing, but you have nothing to lose, but a few minutes of your time...The chalk will wipe off easily.
Edward
Old 10-05-2012, 08:43 PM   #5 (permalink)
Dave M's Avatar
My guess is that the hinge needs to be tweeked abit. I had a similar issue with mine and after a very small adjustment it no longer does it.
Dave
Dave M is offline   Reply With Quote
Old 10-06-2012, 02:11 PM   #6 (permalink)
AH you need to adjust the hinges.
Old 10-06-2012, 02:27 PM   #7 (permalink)
BigLeo69's Avatar
Icon21
hood hinge adjustment or go to the front body mounts and loosen you can tweek the front up a bit too
start at the hinges first, they can also bottom out on the 3/4" tube across the radiator throw some clay around that and then close to see if it hits it at the bracket on the hinge
also depends on what hinges you have mine are the mk3.1's
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
Old 10-06-2012, 05:04 PM   #8 (permalink)
tightasp's Avatar
I had the exact same problem as you. Found a misinstalation of the gas strut on the right side was keeping the hood up on the front corner. The problem was that the strut comptetely collapsed just before the hood shut. Seems the PO mounted the strut pivot in the wrong location on the right side only. Since both struts had lost there gas charge I only replaced the left side and it supports the open hood by itself and the hood shuts flush with no extra effort. Mike
tightasp is offline   Reply With Quote
Old 10-06-2012, 06:01 PM   #9 (permalink)
BigLeo69's Avatar
thats why i don't use them, prop rod
back in late 09 i complained to F5R and thought the layout holes were in the wrong place they sent me a new set the same freakin size and #, gave them to a member he just payed shipping.
thought about moving the brackets but i like the car with out the struts.
372w handbuilt
Old 10-06-2012, 06:16 PM   #10 (permalink)
Master Student
Doug Meldrum's Avatar
I had the same problem... I bought shorter struts from McMaster Carr. The hood doesn't open as far but it works. The struts will keep pushing the corner up while you drive. On the hood issue... I adjusted the hinge (moved it down).
If I had it to do over, I would use the Breeze hood hinges. I'm not happy with the junk hinges FFR sends out.
FFR #7228, under construction
Doug Meldrum is offline   Reply With Quote
Old 10-07-2012, 01:36 PM   #11 (permalink)
Thanks for all your kind responses. I tweaked the hinges, removed the struts and all the bumpers and tried to raise the body mounts in the front but it still does the same thing. I will try the chalk trick this morning. I didn't have this problem when the car was completely assembled before paint. Maybe when I reassembled the hinges after powdercoating them I got something wrong. I did drill positioning holes in the mounting brackets so I know they are back where they were. I even rigged up a strong spring under the hinge to help pull it down but even that did not help. I know it is something simple and I will figure it out. Can't drive it any ways as it's 45 degrees out and going to rain again
Jim in Pa
