What size stripe? - FFCars.com : Factory Five Racing Discussion Forum
Old 09-24-2012, 02:24 PM   #1 (permalink)
Davey's Avatar
What size stripe?
After a little over 7 years my Mark III is finally getting paint. Question is, those of you who have used the "small stripe" beside the large 6.5" stripes, how wide is the little gap and how wide is the "small stripe"?
We're ready to lay out the stripes on Friday and I'd like some feedback.
Dave
FFR 5002, Mark III,302 FMS crate engine, T-5, carb, 3.73 rear, Cobra calipers,w/Brembo rotors, 17\" wheels w/Fuzions. Started 9-1-05. 1st start completed 9-7-2008
Davey is offline   Reply With Quote
Old 09-24-2012, 02:39 PM   #2 (permalink)
LuisL's Avatar
both 1/4".
cheers
FFR4398. Powder coated chassis, pin drive IRS, custom side pipes, custom 289 FIA features, all aluminum 4.6L DOHC with Twin Turbos, Tremec TKOII, and lots of other goodies.
LuisL is offline   Reply With Quote
Old 09-24-2012, 02:45 PM   #3 (permalink)
KC Wildcat's Avatar
x2 1/4" stripe, 1/4" gap
Rich
KC Wildcat is offline   Reply With Quote
Old 09-24-2012, 04:14 PM   #4 (permalink)
cwrandolph's Avatar
X3 1/4" stripe, 1/4" gap. Don't forget to taper the stripe from front to back.
EDIT: Just to be clear - taper the stripe from the nose to the dash and also from the rear going forward to the back of the seats. I kept the "vertical" section of my stripes straight. In other words, the stripe on the lower oil cooler area is the same width as the very front of the nose. At the rear, I stopped the taper as the stripe turned down at the curve of the trunk.
cwrandolph is online now   Reply With Quote
Old 09-24-2012, 11:07 PM   #5 (permalink)
fastco's Avatar
hmmm, why taper the stripe? Mine was tapered when initially painted, but I thought it was a little weird.
Eric Edscorn
http://www.procrew.net/
fastco is offline   Reply With Quote
Old 09-25-2012, 12:42 AM   #6 (permalink)
Lifetime Journeyman
CapeCoralCobra's Avatar
Word is, if they weren't tapered, when viewed from the front/rear, the stripes would look wider at the ends than toward the middle. Optical illusion. Don't think I've ever seen one that wasn't tapered, so I don't know how they'd look untapered.
Alan
Mk 3.1 #7172 / Viper Red w/Pure White stripes
308 / GT40P heads / TFS Stage 1 cam / Crane roller rockers / Explorer intake / 65mm TB / 24# 75mm Pro M MAF/ March pulleys
Cobra spec T5 / 3.73 8.8 / Konis all around / 15" FFR Halibrands
CapeCoralCobra is offline   Reply With Quote
Old 09-25-2012, 01:18 PM   #7 (permalink)
Mr Goodwrench's Avatar
Have you considered widening the space between the two large stripes? Out to the space for the Cobra emblem. personal taste. I like this better.
Dennis
302/345hp Cobra intake, GT40 heads, T5Z, 4 point rear with 3:55 gears, Koni front & Carrera rear coilovers, Forest green body & white pearl stripes, Tan interior, Custom wood dash & Console with instrument cluster, Tan Soft Top, GPS Speedo, Heater.
Mr Goodwrench is offline   Reply With Quote
Old 09-28-2012, 02:57 PM   #8 (permalink)
Also, If I had it to do over again. I would taper the trunk stripes only to where the trunk curves down and then I would take the stripes straight down (vertical) from there. If you don't they look funny when they're not vertical when viewed from behind..
Dennis T
Old 09-28-2012, 04:56 PM   #9 (permalink)
Fred Yarema's Avatar
I did what Dennis suggested...
Taper goes from the cockpit to the ends of the body, then no taper down. Looks better that way. The gap between the stripes on mine is one inch - 3M does make the special striping tape in that width - hard to find though - have a lot left on the roll but worth the cost - made things a lot easier while taping up in the spray booth!
Fred Yarema is offline   Reply With Quote
Old 09-28-2012, 11:35 PM   #10 (permalink)
Davey's Avatar
Thanks to all for the info...........
Old 09-29-2012, 12:36 AM   #11 (permalink)
Master Student
Doug Meldrum's Avatar
X2
That's the one I used. All of the other layouts don't look as good IMO. You can see the layout in my graduation pics below.
FFR #7228, under construction
Doug Meldrum is online now   Reply With Quote
Old 09-29-2012, 11:06 PM   #12 (permalink)
Beautiful paintwork - love the colour combination - what did you use : Lexus Indigo and Arctic white ?
FFR7848 picked up Aug 6, 2012, Build School Aug 10-12, 2012
2004 Mach 1 donor, hydroboost, ABS, stock gauges, 3 link, dual roll bars, tubular LCAs, footbox & trunk mods, firewall forward
Plan to do my own wire diet but may chicken out later
mohara is offline   Reply With Quote
Old 09-30-2012, 02:09 AM   #13 (permalink)
cwrandolph's Avatar
Thanks for the compliment. The colors are both 65 Mustang colors: Wimbledon White and Caspian Blue. This blue usually looks lighter than the Indigo blue but it changes with the light. Check out my graduation post for some different views.
5+ years - time to graduate FFR 6113 - Graduate # 18 of 2012
