Front LCA - FFCars.com : Factory Five Racing Discussion Forum
Old 09-21-2012, 10:40 PM   #1 (permalink)
np630ss's Avatar
Question Front LCA
Is it possible to use Ford front LCA bushings on the FFR tubular control arms?
Np630ss
FFR1007
MK3.1 - Non-donor, 460 .040 over, Keith Black Pistons, Chromoly rod bolts, Procomp heads, Edelbrock cam, gear drive, Harlin Sharp Roller Rockers, Mass Flo EFI, midshift TKO 600, March Pulley System, Power steering, Moser 8.8, 3:31 gears, 3 -link.
Ohhhh Yeeaah!
np630ss is offline   Reply With Quote
Old 09-22-2012, 11:08 AM   #2 (permalink)
bbk347's Avatar
Just guessing I'd say no. The kits are designed to use Ford lower control arms but that just means the bolt diameter and length and distance between the front and rear bushings would be close to the same. The outside diameter of the Ford bushing is probably larger then the outside of the bushings that come with the FFR control arms. I would be surprised if they were the same.
No car right now...
bbk347 is offline   Reply With Quote
