UCA, does std sleeve allow enogh threads - FFCars.com : Factory Five Racing Discussion Forum
Old 09-21-2012, 09:53 PM   #1 (permalink)
Hi
I have a MK3.1 roadster with FFR std 3 5/8 sleeves for the UCA.
Front alignment is set to minus 1 degree camber and 3 degree positive caster.
Not happy with the steering (manual rack), it's too sensitive in speeds above 60 Mph. Also the return to straight forwards position after turn is bad. Therefore I would like to increase caster to 4,5-5 degree. Without removing the heim joints I would like to know how much threads there are on the heim joints. Just want to make sure there is enough overlap into the sleeves.
Hope anuone understands my question.
Best regards Hakan
FFR # 7052 MK3.1 non Donor, IRS 3:27, TKO500, 351w Carb, Levy/Wilwood 6p/4p brakes, 17" Halibrands. Kit arrived April 27 2011. First start Aug 20 2011. Gocart Aug 21 2011. Registration June 19 2012.
hjohan37 is offline   Reply With Quote
Old 09-21-2012, 10:05 PM   #2 (permalink)
Just happen to be working on those exact parts on my Mk4 build right now. They're apart and on my workbench... The links have 1-5/8 inch total threads, and 1-5/16 inch of threads exposed with the nut all the way to the top.
My build will have power steering, so in the process of changing the front sleeves to 5 inch ones from Afco. This thread has a lot of information:
Lots of caster? A WARNING
Old 09-21-2012, 10:09 PM   #3 (permalink)
charles roybal's Avatar
Get SAI kit
Whitby Motorcars
charles roybal MK III #4372 Kieth Craft 408W 527 HP Quick Fuel 780 carb 3-link,VPM Sway bars & 3-link mod, mid shift TKO 500, mod 8.8, team III. \"COBRA ,JET BLACK,FUNS\",KK Donuts
charles roybal is offline   Reply With Quote
Old 09-22-2012, 03:51 AM   #4 (permalink)
ROADRACER83's Avatar
UCA links
Originally Posted by hjohan37 View Post
Hi
Best regards Hakan
Hakan: Once you start to get toward 5-6 degrees postitive caster, the front link is dangerously close to not providing enough threads to handle the suspension loads. I went to a 5 inch tube to get enough threads. Pit Stop USA has them. Also I think Speedway motors.
Allstar Performance ALL56405 : Allstar Performance 5" Aluminum Suspension Tube - 5/8" Thread - 7/8" Diameter
