IRS Wilwood brake kit - FFCars.com : Factory Five Racing Discussion Forum
Old 09-18-2012, 09:27 PM   #1 (permalink)
Mike Forte's Avatar
Thumbs up IRS Wilwood brake kit
Hi,
I just finished a prototype IRS Wilwood kit. This is a 12.19" x .81" vented rotor with the integral E-brake inside the rotor. The price is $1595.00 including 2 new IRS knuckles, 2 IRS hubs, new Wilwood brake kit machined to fit the machined IRS Knuckles. I need 3-4 weeks to fill orders.
Any questions or thoughts?
Mike Forte
Forte's Parts Connection
40 Pearl Street
Framingham, Mass. 01702
mikeforte302@gmail.com
508 875 0016
www.fortesparts.com
The Early Ford & FE Tremec were also originals from Mike. The Mustang firewall adjustable quadrant kit also is an original from Mike. His latest developements are external slave clutch release conversions & cable release conversions too.
Old 09-18-2012, 10:22 PM   #2 (permalink)
Dually's Avatar
Mike, do you have a picture of the machined knuckle? I have the same setup from Wilwood minus the PB in the rotor hat and used external spot calipers for the PB. They work good but would really like to get the PB in the rotor hat. How is the PB assy tied into the rotor? May be interested in getting parts to get my PB in rotor hat but need to know more about the machining you do on knuckle and how the PB cable hooks up.
Dually is offline   Reply With Quote
Old 09-18-2012, 11:01 PM   #3 (permalink)
rscocca's Avatar
PM sent
CLASS OF 2009 # 79 FFR MK 3.1, # 6898, Complete kit arrived 02/07/09, roller 03/30/09, first start 07/14/09, Registered 10/14/09, PPG Orange Glow over Sterling silver,427W Kieth Kraft (591hp), stack fuel injection,on board fire supression,Front Runner Serp system, TKO 600 mid shift mod, ISIS system, Hydroboost brakes with Willwood pedals, PS, A/C, IRS, Griggs racing front suspension, Foot box mods both sides,Dark Water splitter,dead pedal,glove box. (where's my publisher) Lots o Goodies
http://photobucket.com/rscocca
rscocca is offline   Reply With Quote
Old 09-18-2012, 11:09 PM   #4 (permalink)
GloP's Avatar
If I understand correctly the news here is that this is a setup that avoid having a spot caliper just for the ebrake. It would be great to see more pictures of the machined parts!
GloP is offline   Reply With Quote
Old 09-18-2012, 11:11 PM   #5 (permalink)
Dually,
Are you asking Mike to divulge how he made his kit so you can make yours work like his? Or did I read it wrong?
Randy
FFR MKII, Still in building stage...
randykyra is offline   Reply With Quote
Old 09-18-2012, 11:32 PM   #6 (permalink)
Mike Forte's Avatar
Hi,
I have to machine the knuckle some, machine the backing plate, make a caliper mount and machine the rotor. I could machine your used spindles and make your knuckles & hubs work for a price concession.
I have no plans to send detailed pictures. I've been working on this since this spring when I was told this would be a great improvement over the current Wilwood kits available.... and spent tons of time and tied up lots of money. I hope someone makes it worth it. To date I have just prototyped this and will need to custom machine the parts & spacers. I need purchases to make this happen to more than another dream.
Old 09-18-2012, 11:35 PM   #7 (permalink)
Dually's Avatar
understood on the pictures and investment Mike. Just curious as to how much of the hub was being removed. If you get it done I would consider making the move to internal PB vs spot caliper.
Old 09-19-2012, 12:24 AM   #8 (permalink)
tad240's Avatar
Very nice Mike. This should be one of those upgrades that many will want.
Tad Rhodes
Whitakers, NC
tad240 is offline   Reply With Quote
Old 09-19-2012, 12:33 AM   #9 (permalink)
Tennessee Tim's Avatar
My only thought is where were you a year ago...
It looks like an excellent approach, Mike, and if I didn't already have a similar system with the spot caliper, I would be all over it. It should do well.
Tim
Tennessee Tim is online now   Reply With Quote
Old 09-19-2012, 12:34 AM   #10 (permalink)
GloP's Avatar
I'm pretty sure I'll be ordering one, and I'll give Mike a call tomorrow or Thursday. Hopefully other people will sign up to make it worth Mike's time to have spent so much time researching and designing this from the ground up.
Old 09-19-2012, 12:37 AM   #11 (permalink)
Mike Forte's Avatar
Hub
Hi Dually,
Who said anything being removed from the hub? It's a stock hub...
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
Old 09-19-2012, 12:06 PM   #12 (permalink)
Mike Forte's Avatar
Hi,
Any more interest? So far I have 1 interested and need at least 6 sales to make these. To complete this into production I will need to machine spacers, caliper brackets, backing plate brackets & hardware not to mention ordering IRS hubs & knuckles and Wilwood parts too.
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
Old 09-19-2012, 02:01 PM   #13 (permalink)
Dually's Avatar
sorry Mike, I meant the machining of the knuckles.
Old 09-19-2012, 06:31 PM   #14 (permalink)
KC Wildcat's Avatar
Mike - so am I correct in thinking these will fit with 15" pindrive IRS? I am not much help for you now as I am probably 1 yr out from placing an order, but definitely the way I would like to go.
Rich
KC Wildcat is offline   Reply With Quote
Old 09-19-2012, 08:18 PM   #15 (permalink)
rscocca's Avatar
Hi Mike,
I'm sending up my spare knuckles in the morning for you to machine.
Talk to ya soon,
Bob S.
Old 09-19-2012, 11:31 PM   #16 (permalink)
Bill3422's Avatar
yes, Mike, one here
Ambition is a dream with a V8 engine
Elvis Aaron Presley
Ordered MKIII Dec 2008 - Canceled Jan 2009
Mk IV Down Payment August '12
Delivered Feb '13
Setup for 302, Complete IRS
347 Stroker - AFR Heads -Mass-Flo - T5
Duel Roll bar
Halibrand 17" Wheels
Adds
Power Steering Rack & Offset Alum Bushings - Breeze
Power Brakes - Whitby
Hydralic Clutch & Brake Master Cyl. -Modern Driveline
Trunk Battery Box -FFmetal
Firewall Forward -FFmetal
Aux Oil cooler
Bill3422 is offline   Reply With Quote
Old 09-20-2012, 03:50 PM   #17 (permalink)
snakeboost's Avatar
Soon.........
Paht time pahts guy!!!!!!!!!!
Your Solution Specialist!
Call 508-875-0016 to order today
http://www.facebook.com/album.php?ai...axpipe=1&__a=3
snakeboost is offline   Reply With Quote
Old 09-25-2012, 02:39 PM   #18 (permalink)
snakeboost's Avatar
no pictures yet
0.035" spacing on the 15 x 10" Team 3 wheels we have here in the store!
Old 10-06-2012, 04:46 AM   #19 (permalink)
How much will a set of track friendly solid surface replacement rotors run on this setup?
ChinhookMech is offline   Reply With Quote
Old 10-06-2012, 12:51 PM   #20 (permalink)
Mike Forte's Avatar
Hi,
I received 6 set of Wilwood brakes yesterday. I'll be machining brackets and parts to assemble these kits.
I have 2 people so far. Anyone else interested?
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
Old 10-23-2012, 06:18 PM   #21 (permalink)
Bill3422's Avatar
Mike, after looking at my spindles I decided to have you supply them.
Call me when they are ready to ship or when you want payment
Thank you
Elvis Aaron Presley
Delivered Feb '13
Duel Roll bar
Adds
Aux Oil cooler
Old 10-23-2012, 10:14 PM   #22 (permalink)
Thread hijack alert!
Can someone explain to a rank newbie (in the research stage) the problem this solves? From what I have read, the Wilwood Big Brake system offered doesn't fit on the IRS? That is one of the considerations I had for whether I should do IRS actually (or maybe I've put the cart before the horse?). Anyway, a little edu-mu-cation would be greatly appreciated!
GTA Cobra is offline   Reply With Quote
Old 10-23-2012, 11:57 PM   #23 (permalink)
Bill3422's Avatar
Mr. Forte is machining the parts to make it fit
Elvis Aaron Presley
Delivered Feb '13
Duel Roll bar
Adds
Aux Oil cooler
Old 10-24-2012, 01:13 AM   #24 (permalink)
Mike Forte's Avatar
Hi GTA Cobra,
What I have is a 12.19" Wilwood brake kit that features the internal E-brake (inside rotor) kit that mounts to slightly modified stock IRS spindles & stock hubs.
The picture on the first post includes a picture.
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
Old 12-11-2012, 02:50 AM   #25 (permalink)
Mike Forte's Avatar
Hi Guys,
Jesse has a few shipping tomorrow and more getting ready in the next few days.
Here's a link to my facebook page....
Forte's Parts Connection - Framingham, MA - Automotive Customizing | Facebook
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
Old 12-11-2012, 03:26 PM   #26 (permalink)
snakeboost's Avatar
Good news /Bad news
This is a picture of a prototype setup in a Team3 15" wheel.....As you can see it almost fits! So this first batch will be for the 17" crowd.
Old 12-11-2012, 03:33 PM   #27 (permalink)
snakeboost's Avatar
So for the 15" guys.........
This same setup is possibly available. What we need:
5 customers to make the redesign happen.
$1695.00 for these kits - These should fit the Factory 5 15" wheels as well
Old 12-11-2012, 07:36 PM   #28 (permalink)
Mike Forte's Avatar
Hi,
One set leaving now!!! These boxes weigh 79.5 lbs!!!!
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
Old 12-11-2012, 10:40 PM   #29 (permalink)
KC Wildcat's Avatar
I assume you are talking the regular 15" wheels, but what about the 15" pin drive set up? Inquiring minds want to know!
Rich
Old 12-12-2012, 12:58 AM   #30 (permalink)
Mike Forte's Avatar
Hi Rich,
The pindrive wheel could fit. I would need measurements of the stepped diameters inside the wheel to confirm fitment. Give me a call and we can go over where to measure from.
Mike Forte
40 Pearl Street
508 875 0016
www.fortesparts.com
