Replacement boot - ower ball joint? - FFCars.com : Factory Five Racing Discussion Forum
Old 09-14-2012, 10:56 PM   #1 (permalink)
lynnhowlyn's Avatar
OK - finally got around to properly torquing the front ball joints/spindles, and discovered the pass side lower boot is completely shot. Torn/broken completely around the circumference of the boot - so it's now two separate pieces. (1st picture)
Driver side boot is fine - 2nd picture
Looking for a part number for a replacement boot - hopefully that one that I can source at a local auto parts.
And if the answer is 'get one for an sn95 spindle/ball joint' or whatever, since I'm not exactly clear where the sn95 is/was used on an OEM basis, please clarify what year, etc part I should be asking for.
(As a side note, I was frankly somewhat surprised when I searched the Forum that there was so little re; replacement lower boots ... but I may have not used the right search terms. Lots of info re: the upper boot, but very little for the lower.)
Many thanks
Lynn
1st start video (23 April 2013):http://www.youtube.com/watch?v=gWplyizzPC4
1st go-cart video (24 APRIL 2013): http://www.youtube.com/watch?v=Q3IZc1qgZcM
http://redrocksroadster.blogspot.com/
lynnhowlyn is online now   Reply With Quote
Old 09-14-2012, 11:18 PM   #2 (permalink)
timp2's Avatar
Google "energy suspension dust boots" and you will get quite a few threads that lead to common sources such as Summit Racing, etc. I don't know if any supporting vendors have them, if they do I hope they chime in as I would support them first.
FFR 6055, 351W engine in 5/09, TKO 500, Pin Drive IRS, Non-donor build, Trigo 15's, Inspected and street legal 12 Oct 2011
timp2 is offline   Reply With Quote
Old 09-14-2012, 11:20 PM   #3 (permalink)
Jack Wojack's Avatar
Lower ball joints - Ford Mustang (1987 - 1993)
Jack
Old 09-14-2012, 11:24 PM   #4 (permalink)
4.6 SOHC T3650 Telorvek
d42davis's Avatar
This was referenced in a prior post:
"I have Fortes LCAs. I used part#ENS-5-13102r from Summit. I think the r is for red. Seem to work fine. Much better than FFR supplied.Hope it's some help. "
A second post:
"Summit Racing # ENS-5-13102G or Energy Suspension #913130R for the upper and lower dust boots."
Old 09-15-2012, 01:18 AM   #5 (permalink)
Drop Zone's Avatar
I received my KK4 in Oct 10 and earlier this year found both FL ball joint boots rotted. I called FFR and they said they got a bad batch of boots and replaced mine for free including the cost of shipping. Might give them a call and see if they will replace your boots.
Drop Zone is offline   Reply With Quote
Old 09-15-2012, 02:16 AM   #6 (permalink)
Rich A's Avatar
That pass side boot is dry rotted. Definitely try FF first like John said.
Old 09-15-2012, 01:23 PM   #7 (permalink)
lynnhowlyn's Avatar
Thanks for the part numbers - AND for the info regarding FFR recently having had a batch of dry-rotted boots.
I was hoping to pick up a replacement boot today and be able to complete the spindle torquing this weekend, but it make senses to wait till Monday and give them a call.
I received my kit almost exactly 1 year ago - so it's "fresher" than John's and with both of his dry rotted boots having been replaced - they likely will help me out as well.
So I guess I'll go back to wrapping up the e-brake cable routing, then tackle the clutch slave bracket mounting and sort out a passenger side "low" alternator mount. (BTW - suggestions on a "low" alternator mount would be really helpful.)
Thanks again for the help. It's always helpful and much appreciated.
Lynn
Old 09-17-2012, 01:50 PM   #8 (permalink)
lynnhowlyn's Avatar
Good call John on contacting FFR re: the failed (dry rotted) lower ball joint boot.
I just spoke to Dan in Tech Support who asked that I send him a couple pictures (which I did), and I expect a replacement boot will arrive shortly.
Thanks for the heads up about what you encountered, and more importantly - for sharing the solution!
Lynn
Old 09-17-2012, 04:20 PM   #9 (permalink)
I got replacement boots from FFR.
As for low alternator on passenger side - I used Mike Everson's alternator mounting kit. When you rotate your alternator to the low position, relocate the belt adjusting rod below the water pump snout. You'll have to buy one longer water pump bolt.
Kevin
MarkIII, FMS BOSS302,WC T5, Holley 570, MSD Dizzy and Coil, 17"Cobra R's, 3-link, Classic Gauges, Forte's, Everson, Breeze, Finish Line, Ron Francis, Russ Thompson, 5-Star Ford, Gas-N, VPM, Whitby, Dark Water Customs, Herb's, SEcond Skin
Kevin Kearney is offline   Reply With Quote
Old 09-17-2012, 06:27 PM   #10 (permalink)
Drop Zone's Avatar
A few times posted a wrong procedure or got my facts wrong but sharing is what this site is all about, share and support. I usually contact FFR tech support for most items like the boots, part doesn't look quite right etc, then search ffcars.
The only time FFR hasn't supported me is the cover plates for the windshield posts. They sent two of the same side and so when you flip it over and it is dull not polished, their responce was buy a new piece or polish the one you got.
Old 09-17-2012, 06:57 PM   #11 (permalink)
lynnhowlyn's Avatar
Kevin
Hey Kevin -
Thanks for the tip re: using Mike Everson's alternator mounting kit for a "low" passenger side application. I sent him an inquiry note a few days but haven't heard back yet. (He normally replies pretty quickly - so he may be traveling or ???)
Couple quick questions:
Are you using Power Steering along with your "low" alternator mount? (My PS is Ford OEM-style on the DS)
Is your water pump standard or reverse rotation? (mine is reverse - Edelbrock 8840)
Did you need to add a supplemental serp. belt tensioner to get everything working??
Thanks again.
Lynn
Old 09-17-2012, 07:55 PM   #12 (permalink)
emac's Avatar
They did the same thing to me, but sent me the other side. Swapped it out for me. They exist, why they didnt send one to you doesnt make sense.
351 tko 500
Delivered Nov 13, 2011
First start December 31, 2011
First gocart Jan 12 ,2012
Graduation 05/12/201
graduation thread
Old 09-18-2012, 01:24 PM   #13 (permalink)
Lynn,
I don't have power steering. I do have a standard rotation water pump. (I actually bought the Std Rotation pump kit from Mike.) I only have one belt - Goodyear 4060360 or 6PK915.
Kevin
Old 09-18-2012, 03:49 PM   #14 (permalink)
lynnhowlyn's Avatar
Lynn,
Kevin
Bummer ... at least for me
Guess it's time to make this ... my quest for a cost effective "low" passenger side alternator mount that'll work with PS and a reverse rotation water pump ... into a separate thread.
Lynn
Old 09-20-2012, 01:51 AM   #15 (permalink)
luey2009's Avatar
Just got my car on the ground today, and noticed my driver side lower control arm boot was torn apart as well. awaiting a response from ffr. How safe is it without replacing this boot? in other words, leaving it as is?
FFR #7815 mk4 complete kit ordered 4/23/12, kit completion date 5/26/12,delivered 6/3/12,roller w/lights 9/15/12, motor installed 11/3/12,first start 11/24/12,first go cart 3/30/13
Old 09-20-2012, 02:49 AM   #16 (permalink)
Drop Zone's Avatar
The boot holds the grease in. With the boot torn the wear on the joint will be accelorated could cause it to lock. I wouldn't drive around with it torn. If your in the build stage fix it now a lot easier now than later.
Old 09-20-2012, 11:50 AM   #17 (permalink)
luey2009's Avatar
ya good advice, thanks John-Andy
