What are these? - FFCars.com : Factory Five Racing Discussion Forum
Old 09-11-2012, 02:40 PM   #1 (permalink)
Silverstreak02's Avatar
What are these?
I was going through my unused parts last night and found these. What are they?
Old 09-11-2012, 02:48 PM   #2 (permalink)
Inner tie rod power steering rack extenders.
Old 09-12-2012, 01:59 AM   #3 (permalink)
Thanks Mike. I'm glad it's just another part that was meant for a different purpose.
Frank although I'm happy with my manual steering I'll hold onto the adapters for now.
Old 09-12-2012, 06:16 PM   #4 (permalink)
Guys,
Do you need those extenders if you install your power rack with the Breeze Offset Bushings to help avoid the bump steer, which is what I believe the rack extenders also do as alternate solution?
Sal
My Build Thread
Non Donor
Complete Kit MK4: Ordered 05/09/12
Delivered:06/20/12
302 with TKO 500 (Forte)
ISIS Harness
IRS
Hydraulic Clutch
Dropped Battery Box (FFMetal)
Color:TBD
skjsming is online now   Reply With Quote
Old 09-12-2012, 06:37 PM   #5 (permalink)
Banned
I have a set if anyone needs them. $30.
Old 09-12-2012, 10:10 PM   #6 (permalink)
Originally Posted by skjsming View Post
Guys, Do you need those extenders if you install your power rack with the Breeze Offset Bushings to help avoid the bump steer, which is what I believe the rack extenders also do as alternate solution?
Not exactly. Both can improve front end geometry and reduce bump steer, but they are different. The Breeze bushings center up the rack and move it slightly. The extenders move the pivot point of the inner tie rods out to where they line up better with the pivot points of the upper and lower control arms. The manual rack that FFR sells is a specially modified rack from Unisteer that has the wider pivots out of the box. With the extenders, a PS rack can achieve a similar setup.
