behind seat storage shelf - FFCars.com : Factory Five Racing Discussion Forum
Old 09-11-2012, 01:08 AM   #1 (permalink)
prolariot's Avatar
Sorry guys, can't find anything on the search tool.
Looking for ideas to build a behind-seat storage shelf or cubby. I have been driving around a excalibur roadster and have found the behind-seat storage area super-handy.
prolariot is offline   Reply With Quote
Old 09-11-2012, 01:33 AM   #2 (permalink)
SIZE-O's Avatar
Talk to Mark at Breeze Automotive and take a look at this. I'm sure its what you're after.
or,
Build your own. Which is what I did.
Perry
FFR #6641, Mk 3.1, 408W Stroker, Dart Block, Edelbrock Victor Jr Heads, Custom Hydraulic Roller Cam, Quick Fuel 750 CFM, Non-Donor, TKO 600, Center Force Clutch, 8.8" Detroit Tru-Trac, 3.73 Gears, S.S. Side Pipes, Polished FR500 Style Wheel, Big Ass Wilwood Brakes, VPM Reinforced 3-Link, Stainless Steel Braid Everything. POM Dec/2010 & Feb/2011.
SIZE-O is offline   Reply With Quote
Old 09-11-2012, 02:36 AM   #3 (permalink)
Dave O's Avatar
Breeze is a good choice. If you are looking for something a little smaller you might try Darkwater Customs. I used the Darkwater solution and modified it to hold my radio.
[IMG][/IMG]
Dave O is offline   Reply With Quote
Old 09-11-2012, 02:43 AM   #4 (permalink)
Dave O's Avatar
The Darkwater unit does have a cover. I have not added the latch yet.
Old 09-11-2012, 04:15 AM   #5 (permalink)
Doug S's Avatar
Or do you mean a shelf like the one J Persons did and I copied. I like the space to stash a coat or whatever. Here is a link that shows his. I don't have any pics of mine yet.
Rear shelf issue with MK4
MKII FFR#4626-302 Kenne Bell 1.5 supercharger, Trick Flow Stage I cam, Ported GT40Ps, 65mm TB, SCT 90mm MAF, rear disks, 3.55 gears.
Doug S is offline   Reply With Quote
Old 09-11-2012, 10:04 AM   #6 (permalink)
If you are talking about a full width area behind the seats here is what Thierry "mydream" did on his Mk3:
Aaron and I will be incorporating this into his build sometime in the next few days. When we do one of us will add photos and descriptions to the build thread.
Mk4 Build thread
Mk4 Bodywork & paint thread
Old 09-11-2012, 11:53 AM   #7 (permalink)
RE63's Avatar
This is also what I did on John Tak's car and John Millettes car
As previously noted Mark Reynolds- Breeze Automoive- does offer a kit to do something like this.
RE63 is offline   Reply With Quote
Old 09-11-2012, 01:25 PM   #8 (permalink)
J Persons's Avatar
Here's one of mine after it was completed. I also incorporated a map pocket on the back wall and the fire extinguisher. I should have copyrighted this mod.
J Persons is offline   Reply With Quote
Old 09-11-2012, 05:37 PM   #9 (permalink)
CRZN 427's Avatar
Another Large Storage Area
I still have a bug and can't upload any new pictures, but this shows what I did.
I moved the bulkhead back the maximum I could, added a hoop there to connect the aluminum panel (cut from the back of the cockpit piece), added another hoop at the front, removed the straight piece FFR had there, added some braces to attach the shoulder harness just below body level and modified the front of what would have been the upper trunk floor to have access panels into that area. I also have a full width roll bar so the entire front of the opening is unobstructed (except for the seats).
Regards, Rick.
CRZN 427 is offline   Reply With Quote
Old 09-11-2012, 06:26 PM   #10 (permalink)
MPTech's Avatar
Mine's not done yet, but you get the idea.
Also picked up some trunk space too. (that's not a battery box. my wife said that's where her shoes will go. )
Licensed 4/24/13!! Wahoo!
Old 09-11-2012, 10:41 PM   #11 (permalink)
I did mine like J Persons except I left the square tube in the center. You can see that tube in the second MP Tech pic. So I have a full height opening but w/ that tube across it. It isn't really a problem and is actually kind of helpfull when you jam a jacket in there as it helps it stay in place.
Old 09-12-2012, 01:24 AM   #12 (permalink)
mirose's Avatar
I just created my own hinged cover for a hole I cut out. I put some 3M Carbon Fiber covering material on the cover to make it look nice. Here it is before carpeting. I used the breeze divider inside the trunk so that the cubby has its own dimensions and things you put in there don't bounce around the whole trunk.
And here it is in the finished car (not painted, but car is finished)
FFR 7386 MK IV Roadster
Build Began 12/6/2010
First Start 11/18/2011
Go Kart 11/24/2011
My Build Project Website
