Pulling out the Trans to Replace Clutch in a Mk II - FFCars.com : Factory Five Racing Discussion Forum
Old 09-07-2012, 09:58 PM   #1 (permalink)
Mike in CA's Avatar
Smile Pulling out the Tremec 3550 to Replace Clutch in a Mk II w/Quicktime BH
Just for future reference; Is there any way the transmission can be pulled out of a Mk II without pulling the engine? I have seen a couple of differing opinions over the years on here concerning this, but as I may need to do a clutch replacement in the near future, I thought I would re-visit this issue. Just so everyone knows my specifics, I again have a late Mark II with Tremec 3550 and a Quicktime bellhousing.
One post a while back said that if the angle cross brace under the trans is cut out, then the trans can be pulled and then weld the brace back in, but that sounds a little cludgy to me. All thoughts will be appreciated.
Mikey
FFR #4984 408 Stroker Roller, Victor Jr. Heads and Intake, Holly 750, IRS, Cobra R Brakes, 3550 Trans
\"All it takes for Evil to succeed; is for good men to do nothing"
Mike in CA is offline   Reply With Quote
Old 09-07-2012, 11:56 PM   #2 (permalink)
If you have a standard T5 trans, it's doable. Flip it on it's side and move it back. I have a heavy duty tremec TKO. There's no way that's going to happen. It faster and less work to simply pull the engine. And you don't have to spend as much time lying on your back.
Old 09-08-2012, 12:14 AM   #3 (permalink)
nickm1024's Avatar
Can you pull a TKO in a mk3? Ive pulled a t5 twice fairly easy. TKO I know is larger.
Delivered 3/26/08.
Rollin on temp tags and drivin in gelcoat 10/16/08
Painted and on the road 4/4/09
FFR 7501
Dec '12 repowered 408w w/ mass Flo
nickm1024 is online now   Reply With Quote
Old 09-08-2012, 12:23 AM   #4 (permalink)
The MIII has a removable trans mount and cross bar. It should be pretty easy to drop the trans from there - just like a Mustang.
Old 09-08-2012, 01:16 AM   #5 (permalink)
nickm1024's Avatar
I just didn't know if a TKO would rotate on its side to pull out with it being larger. I'm currently trying to decide between an astro t5 and a TKO as im going with a 408 this winter. Lots of TKO's available used for good coin but I didn't know how easy to remove/install
Delivered 3/26/08.
FFR 7501
Old 09-08-2012, 02:15 PM   #6 (permalink)
I have helped a couple of times r and r a T-5 in a MkII. It wasn't fun at all. I don't think a tremec will come out. It might be worth looking at making that trans mount removeable like a MkIII as part of the job.
Old 09-09-2012, 12:11 AM   #7 (permalink)
Mike in CA's Avatar
Thanks for the info, but so far none of you have answered my question. Since my car is a Mk II and not a MK III and I have a TREMRC 3550 and not a T5. But perhaps someone that actually knows the answer will chime in. I would have blown up a T5 in the first month with my 408 Since it puts out almost 600 lbs of torque.
Old 09-09-2012, 01:02 AM   #8 (permalink)
Radar Pete's Avatar
I have a late model MKII and have droped the tranny out the bottom. I have a T5. If the 3550 is a quarter of an inch or more wider than a T5, it will not come out the bottom. Pete
FMS 302,GT40 Alum heads,Cobra intake,70mm MAS/TB,24lb injtrs, 8.8w/3.55,WC T5,Srt Perf Seats, donor build except eng/tranny, Hummer Yellow w/o stripes
Radar Pete is offline   Reply With Quote
Old 09-09-2012, 01:32 PM   #9 (permalink)
Kiwiracer's Avatar
I've had this saved for a while...
Author
Topic: Pulling a T-5 from a Mk 2. Tricks??
FFr 5332
Member # 8456
Remember reading a post on this, but a search yielded nothing I could use. I'm pulling my T-5,( Mark 2 frame ) have it seperated from the bellhousing, and just won't quite back up far enough to get the input shaft clear of the bellhousing. Is there any tricks before I go to the trouble of borrowing a hoist and moving the engine forward? It's pretty close...maybe I'm missing something
Posts: 9 | From: Tucson, Az. | Registered: Dec 2005 | IP:
mrmustang
Directions originally sent to me by Wade C back in 2002. I've used them on both mark I and Mark II chassis's without a hitch.
"Put your car up on jackstands. Remove the shifter boot and shifter handle. Depending on what kind of shifter you have, you may also be able to remove the shifter stub for another 2" clearance (my Hurst came right out). Remove driveshaft, speedo cable, and all wires to trans. Place jack or block of wood under bellhousing to support the back of the engine. Remove all 4 bolts from trans mount (in trans, and in crossmember), but leave the mount there for the trans to sit on
momentarily. Remove the 4 bolts where the trans bolts to the bellhousing. The trans needs to slide rear-ward enough so the input shaft will clear the bellhousing (about 6"). In order to slide it that
far rearward, you'll have to rotate it first, 90° onto its side. One side clears the other doesn't. Sorry I can't remember which way! Anyway, it will then slide straight back, and you can drop it out nose first."
FFr 5332
Member # 8456
Thanks! looks like the driver's side of the trans is the side to rotate it onto...more potrusion and bulk on the pass. side. Still open to any other tricks.
jaysherman
[IMG]file:///C:\DOCUME~1\ARRANH~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_image012.jpg[/IMG]
Member # 933
I tried really hard and could not get it out on a mark II without pulling engine forward. I rotated the trans every which way and no luck.
89 Donor, EFI, E-cam, 4X4 headers, 355 gears,
Posts: 1192 | From: Northern California | Registered: May 2002 | IP:
Unfortunately no idea with the tremec, but maybe this'll help others.
Mk II FFR # 3503, 2001 Fuel Injected 302, E-303 Cam, Ford 1.6 roller rockers, GT-40P heads, Rear coil over shocks, 3.55 Richmond gears
Kiwiracer is offline   Reply With Quote
Old 09-09-2012, 10:31 PM   #10 (permalink)
A 3550 is a TKO. There's no way I can remove mine without pulling the engine. I'v tried it.
Old 09-10-2012, 10:52 PM   #11 (permalink)
Richard Oben's Avatar
TKO MK II not going to come out without moving the engine. You may not have to remove the engine but you will need to move it forward. HTH, Richard.
Richard Oben is online now   Reply With Quote
Old 09-10-2012, 11:01 PM   #12 (permalink)
accobra66's Avatar
Although this sounds completely crazy hear me out.
With my Mark II there is no bracing above the trans. Only tin and carpeting.
If you were to remove the carpeting from the trans tunnel and the tin could it be lifted up and out through the interior?
Perhaps too wide but I am fairly certain just looking at spacing that I could get my Richmond 5 speed between the square tubing and out the top.
I must be way off base here because I do not think I have ever heard of this. Frankly, I hope never to have to try it.
Carbed 351W w/Richmond 5 speed, Levy 5-Link rear suspension w/ Street Bump Steer, powder coated frame and heated seats.
accobra66 is offline   Reply With Quote
Old 09-10-2012, 11:52 PM   #13 (permalink)
Radar Pete's Avatar
For KIWIRACER: You're doing it correctly. Rotate the tranny 90 degrees toward the passenger side and slide it back. It should clear the input shaft. It worked for me. I did it five years ago (and will do it again this winter) but don't remember any other hints. I'm sure that you drained the tranny, removed the driveshaft, and shifter. Don't know what else to say. Pete
Old 09-11-2012, 08:17 AM   #14 (permalink)
Mike in CA's Avatar
My engine sits way back in the engine compartment for some reason. Probably because i have custom solid motor mounts. There is a good foot or more of space between the front of the engine and the rear of the radiator support. So I should have plenty enough space if i unbolt the motor mounts and disconnect fuel, electric and exhaust connections to just slide the engine forward without removing it. The oil lines have loads of room and slack to move forward, so they should not even need to be disconnected. If I do that and if needed, I can also unbolt the Quicktime bell housing, i should be able to get the TKO out without completely pulling the engine. I also have a center mount hurst shifter instead of the standard rear mount, so it can be easily unbolted and if necessary the shift kit can also be removed. What are thoughts on that plan?
I also installed the tunnel carpet with snaps and the tunnel cover with screws, so both can be easily removed if anyone thinks that the trans can come out from the top, although I have not heard of that being done. I really only made tunnel access easier for any minor maintenance. But I welcome any thought on that idea as well.
I just have bad fellings about pulling the engine with the body on and screwing up a very expensive paint job. And since the 351w is just slightly smaller than a big block, it does not give very much room to get by the body. It was a real PITA putting the engine and trans in as one piece without the body on, so I sure would not look forward to doing it with the body on.
I had to crank it at such a steep angle it barely cleared the firewall and radiator support without the body so there is several inches less space to the rear with the body on. I think i would have to put the trans and engine in seperately instead of as one piece as I did with the body off.
So keep sending your thoughts and thanks for all the help.
Mikey
Old 09-11-2012, 04:55 PM   #15 (permalink)
Frank Messina's Avatar
ACCOBRA66, you have one of the late Mk 1 crossover cars, not a full MkII. The MkIIs had a cross braced backbone so nothing is coming out the top on those cars.
Mike in CA, cover the fenders and the nose with furniture pads, round up a couple extra hands and pull the whole thing out. I doubt your engine sits any farther back than anyone elses, and while sliding it forward may seem tempting trying to R and R the trans from some odd position dangling off a hoist will be murder. FWIW
Frank
Frank Messina is online now   Reply With Quote
Old 09-11-2012, 05:53 PM   #16 (permalink)
slapshot2's Avatar
Icon21 It is doable, and not a bad job with a lift
I removed a T5 from mine and replaced it with a TKO600.
Fluids were drained.
Transmission turned on its side and pulled back, and the new one installed reversing the process.
This was a complete removal of the bell housing, clutch etc and replaced with a Quick Time housing, aluminum fly wheel et al.
When you turn on your car, DOES IT RETURN THE FAVOR?
Mark I, FFR 1805, 302 Cobra R, Fuel injected, 4 Link, Power steering and brakes, coil overs, TKO 600, Quick time Bell Housing
slapshot2 is offline   Reply With Quote
Old 09-11-2012, 06:36 PM   #17 (permalink)
C'mon you guys. The guy has a Mark II with a backbone and a Tremec TKO. Not a Mk I, not a t-5. They're not the same animal. I know we try to be helpful but exploits involving combinations other than what Mikey has aren't relevant to his situation.
Frank
Old 09-11-2012, 10:56 PM   #18 (permalink)
Bill Hughes's Avatar
When I built my car, 347 and TKOII, I installed motor and trans as a unit. Can you pull that same unit with the body in place?
If yes, that sounds like the best option.
Build started 15 Dec. 2002
Old 09-11-2012, 11:10 PM   #19 (permalink)
Frank
X2. MKII, 351W block, TKO -- have done the whole thing twice with body (painted) on. Good lift and leveler and just taking it real slow and easy and there is no need for any contact or issues anywhere, whatsoever.
I suppose if the ONLY thing I was doing was the trans I might be tempted to try and do it from underneath on a 4 post or other lift with a proper trans jack etc. -- which I have done on other cars. (And yes I have done the jack stands and trans on chest thing too in my younger years but NOT by choice!!)
But on this one and for the reasons Frank mentions, being able to do whatever work is required clutch wise etc. in a proper comfortable position more than offsets anything to do with pulling the whole thing versus not.....
Regards,
MKII, PDW, Torsen 3.55 Pin Drive IRS, Dart 393W, AFR 185's, Victor Jr., Accufab TB, Accel DFI GEN 7 EMS, TKO 600 wMcleod Scatter&Street Twin Clutch, 1+1 Elec., TTD's, Da Bat Paint
Bill Lohmiller is offline   Reply With Quote
Old 09-12-2012, 12:10 AM   #20 (permalink)
cwhoofgator's Avatar
Answere is NO SIR.
cwhoofgator is online now   Reply With Quote
Old 09-12-2012, 02:34 AM   #21 (permalink)
Pulling the engine out is not that big of a deal. From start to finish, it take me about 4 hours to get the engine out and on a stand. And that includes bringing the hoist up from the basement and putting it together.
That sounds like a lot of work, but really isn't. It's easier work than pulling a clutch on your back. I'v done that, too, once or twice.
Old 09-22-2012, 01:38 AM   #22 (permalink)
Mike in CA's Avatar
Thanks guys, I think you have pretty much convinced me that the engine has to come out. I am hoping to put that off till next spring. My biggest problem is, since i put the thing together, I have had 8 back surgeries and I am not sure i am up to the task at this point. I know a shop would charge $2,500 just to r and r the engine, plus the clutch parts and labor for that. So I am in kind of a quandry. I can't afford a shop to do it and i am not sure I am still able to do it. But for now the car still works fine, but i know the clutch will need to be done at some point in the near future. I guess i will figure it out when the time comes.
Mikey
Old 09-22-2012, 01:43 AM   #23 (permalink)
Bring it over to my place. We'll get it all done in a single day. Maybe two.
Old 09-23-2012, 01:56 AM   #24 (permalink)
Mike Brasfield's Avatar
I've replaced clutches on about all models except the MK4. I find it is a lot easier just remove the engine and trans as a unit. While out you can do anything you want in the engine compartment. Just did one last week.
Mesa Mike
Mike Brasfield is offline   Reply With Quote
Old 09-23-2012, 04:14 AM   #25 (permalink)
Stinson Pilot's Avatar
Mike,
Is the top of your tranny tunnel removable? If so, it's easy to take it out from the top.
My top is removable just for this reason. I can remove the top cover, both seats and it comes right out through the top.
Already done it a few times.
For the record: Mine is a MKII with a 3550.
Stinson Pilot is online now   Reply With Quote
