Still unhappy with Temp. - FFCars.com : Factory Five Racing Discussion Forum
Old 09-07-2012, 10:56 AM   #1 (permalink)
DRONE's Avatar
Can timing cause the car to run hot if so what is the recomended timing, should it go closer to TDC or further away? -9deg.TDC -10deg.TDC -11TDC
The only sure rule in golf is - he who has the fastest cart never has to play the bad lie.
~ Mickey Mantle
DRONE is offline   Reply With Quote
Old 09-07-2012, 11:09 AM   #2 (permalink)
jolsen42's Avatar
Yes timing will effect your temp. Advance your timing(turn your distributor to the right). Timing should be anywhere from 12deg. -16deg btdc.
John O
FFR1293-289 slab side Mr Bruce body, 289 hi-po, Tremec TKO, 3-link 3.55 rear, spoked pin drive wheels, under car exhaust. A facsimile of CSX 2367.
jolsen42 is offline   Reply With Quote
Old 09-08-2012, 02:59 PM   #3 (permalink)
DRONE's Avatar
Would that be counter clockwise looking down on the dist.?
~ Mickey Mantle
Old 09-08-2012, 03:19 PM   #4 (permalink)
Cobradavid's Avatar
Doesn't more advance make it run hotter?
My Saving Grace: John 3:16
My car: http://mysite.verizon.net/resshc7d/
FFR6687, Graduate #39 in the Class of 2009
March 2012 POM on The Other Forum
Cobradavid is offline   Reply With Quote
Old 09-08-2012, 06:02 PM   #5 (permalink)
FFR5452's Avatar
Ian, did it just start running hotter the last few weeks? Usually when distributors wear, the timing will retard rather than advance.
Has the idle changed any lately? What has changed, temperature wise, to lead you to seek answers?
FFR5452 is offline   Reply With Quote
Old 09-08-2012, 07:26 PM   #6 (permalink)
Thumper135's Avatar
I agree with Jim here, more info…… did it just start running hotter than normal, or is this temp what it’s been running all along? The answer to this question is the best starting place and can give us a good starting point here…….
Thumper135 is offline   Reply With Quote
Old 09-08-2012, 07:29 PM   #7 (permalink)
Nope, unless we're talking some ridiculous amount. In reality retarded timing raises exhaust gas temperature and consequently engine temp.
Drone, check your timing.
Mk4 Build thread
Mk4 Bodywork & paint thread
Old 09-09-2012, 10:54 AM   #8 (permalink)
DRONE's Avatar
Well ... I did do my own tune up about 7 months ago and it was soon afterwards that I noticed that it was running a little hotter, I did the coolant flush thing and made sure that I thought I burped it, but the temp still climbed. I haven't been able to work on it for the last 6.5 months and I will be back in town on the 20th, I want to go to to the races that weekedg with Marty and the gang so I figured I would start the questions now.
~ Mickey Mantle
Old 09-09-2012, 11:28 AM   #9 (permalink)
jolsen42's Avatar
Advance your timing.
John O
Old 09-09-2012, 12:25 PM   #10 (permalink)
Wade Chamberlain's Avatar
sounds to me like the system still has air in it if the problems started after you did a cooling system flush. I'd start there. On timing, 14°BTDC is a pretty good place to start.
Wade Chamberlain
FFR2229K
