Sway bar at the front or the rear? - FFCars.com : Factory Five Racing Discussion Forum
Old 08-27-2012, 10:46 PM   #1 (permalink)
CS14's Avatar
Have some problem to keeping track at the end of the curve then I accelerate. I have 3-link Mooser 3:55 and 15", the big tyres have some problems to get grip but thats quite normal compared to 17".
I think the best way to make it easyer for the front tyres is to put the sway bar at the rear, other ideas?
CS14 is offline   Reply With Quote
Old 08-27-2012, 11:19 PM   #2 (permalink)
Bigtim01's Avatar
Icon21
CS14
Have you tried changing air pressure in the tires. I am running 15" Goodyear Eagle GT II at
35 lbs. for Auto X It helps but I think you are reaching the max grip that the 15" tires have. I think you are right, 17" tires may help you.
Bigtim01 is offline   Reply With Quote
Old 08-27-2012, 11:32 PM   #3 (permalink)
Cone Basher's Avatar
Talking
It's a process.When I first built my car without any sway bars understeer was a big problem. I added the SAI mod and a front VPM bar and it was much better but still had an understeer problem at Auto-X. Added a rear bar VPM bar and still had underster.Added Koni shocks with a different spring rate and it is great. Try this go to google and type the following: site ffcars.com understeer/oversteer correctiions. All kinds of changes can be made to alter the handling of your car but I would recommend an adjustible sway bar for your car. Add the front first and see how it helps. Adding a front bar keeps the frame of the car closer to the horizontal which does not unload the inside tire as yo go around a turn.
Keep us posted:
CB
Old 08-27-2012, 11:54 PM   #4 (permalink)
Give a visit to the road racing discussion forum. Tons of info on setup.
work like a captain, play like a pirate
FFR2606 - 392
FFR2903 - 347
94 Yamaha GTS1000
76 Honda 750F1
Todd Buttrick is offline   Reply With Quote
