Motor mounting? - FFCars.com : Factory Five Racing Discussion Forum
Old 08-22-2012, 12:19 AM   #1 (permalink)
FFR Bandit
mildlyamused's Avatar
Motor mounting?
I want to mount my new engine...temporarily, and finish off all of the engine bay wiring, plumbing etc.
I have the bell housing, however I don't TKO 600 yet.
How do I make sure that I have the motor 99% sure- front to back?
Are the mounts (I have Energy Sus.) place the motor in the right spot?
Any thoughts are appreciated
Andy
"You think you hate it now, wait till you drive it!"
Ordered 11/21/2011
Arrived 1/18/2012
1st start 11/09/2012
1st Go Kart....30 mins. later
FFR#7697 MkIV base kit, AFR 205s- 408w sbf, Miller Speed front dress, Tremec TKO 600, 3.55 posi, IRS, 15" Halibrands, PS, hydroboost, & hyd. clutch
mildlyamused is offline   Reply With Quote
Old 08-22-2012, 12:22 AM   #2 (permalink)
BlitzAttack's Avatar
I didnt think it was possible without the tranny installed. If its not the engine will not sit level by itself.....I could be wrong though.
Factory Five MK4 #7593- DOD 9/11/2011
First start - 12/8/2012
Ford 306, Aluminum heads, Cam, Carburated
3 Link, 4 wheel discs, 15" FFR Halibrands
Goodyear Billboards
www.wix.com/cdurhamwot/blitzattack-mk4-build
http://s1124.photobucket.com/albums/l571/BlitzAttack65/
BlitzAttack is online now   Reply With Quote
Old 08-22-2012, 12:32 AM   #3 (permalink)
The motor mounts will properly locate the engine in the frame. Thread the nuts onto the studs of the motor mounts just a couple of turns, not even snug, to keep it from coming out of place as you jockey it around.
Support the back of the bell housing some how, so it doesn't twist the motor mounts and damage them.
The power angle is about 3-5*.
Old 08-22-2012, 12:42 AM   #4 (permalink)
This is what I was referring to.
Goodyear Billboards
Old 08-22-2012, 12:52 AM   #5 (permalink)
FFR Bandit
No prob. supporting the bell...already have a little somtin' in mind.
Just wanna be sure that routing hoses and such are in the ball park.
Biggest "distance thing" front to back is the mechanical throttler linkage.
May just wait til trans is set to finalize that piece. Hoses at least flex!!!!
Andy
Ordered 11/21/2011
Arrived 1/18/2012
Old 08-22-2012, 03:28 AM   #6 (permalink)
Mechanical linkage
You could complete all of the pieces of the mechanical linkage from pedal to firewall, and leave the last piece (the rod from the firewall lever to the carb) to measure when you get the trans.
HTH,
Derrick
Pedalmasher is offline   Reply With Quote
Old 08-22-2012, 05:03 AM   #7 (permalink)
Once the motor mount is is bolted into the frame slot, it's no going to move more than about 1/8" fore and aft. That slot allows you to level the engine, but there's really no movement front to back or side to side.
Set the motor mount studs in the slots. Level the engine side to side. Set the power angle at 3*.
The trans and bellhousing bolt to the back of the engine, and are located by the engine. The engine locates the trans, not the other way around.
Old 08-22-2012, 12:06 PM   #8 (permalink)
Joe.S's Avatar
What is the power angle, the engine tilted slightly back?
Joe.S is online now   Reply With Quote
Old 08-22-2012, 12:53 PM   #9 (permalink)
FFR Bandit
Thanks fellas!!! That's what I needed to know!
If 3 degrees is the right power angle, then all is good.
Thanks Bob. I will post some pictures in the weeks to come to show that it can be done, sans the transmission.
Andy
Ordered 11/21/2011
Arrived 1/18/2012
Old 08-22-2012, 01:31 PM   #10 (permalink)
Exactly. It's usually compared to the horizon, and not the chassis - just like pinion angle.
