Bleeding brakes... I feel dumb - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
Old 08-21-2012, 02:50 AM   #31 (permalink)
Vroom Vroom
CONFIRMED! I am an idiot
MKII non donor
347 stroker with stacks
Old 08-21-2012, 03:04 AM   #32 (permalink)
ROADRACER83's Avatar
No Problem
ZoaFan08:
Not to worry mate. Just roll the car over, bleed the brakes and then roll it back over. Problem solved. Or I guess you could swap the calipers so the bleeder is up.
Everybody on here has made the same type of boo boo at some time.
Old 08-21-2012, 03:08 AM   #33 (permalink)
Banned
I'd suggest a one man brake bleeding system like the one below. It's an investment but this is what I used. Never bled a brake before but it only took about 25 minutes to get all the air out.
The system pushes the fluid from each brake up to the MC. The system makes sense as air naturally likes to go up so you are working with gravity instead of against it (trying to push air downwards) the way old fashioned way. You can also do it by yourself. No more need for a brake bleeding partner.
Phoenix MAXPRO Brake Bleeder Kit, Phoenix Systems MaxPro Brake Bleeder - Videos, Installations & Reviews
Old 08-21-2012, 05:09 AM   #34 (permalink)
Vroom Vroom
Brakes are bled, all nice and tight
MKII non donor
Old 08-21-2012, 10:42 AM   #35 (permalink)
Hey, you said it, not us
Easy fix, glad you sorted it out.
Note to others in the future: The calipers are marked "LH" for the left and "RH" for the right side---UNLESS you swap them to ahead of the axle in which case LH goes to the right and vice-versa.
Cheers,
Mk4 Build thread
Mk4 Bodywork & paint thread
Old 08-21-2012, 11:05 AM   #36 (permalink)
Rob
Rob's Avatar
Are your brake calipers installed upside down? Trapping air inside the caliper.... Just a guess.
Rob is offline   Reply With Quote
Old 08-21-2012, 11:09 AM   #37 (permalink)
You're a little late to the party there Rob. He already verified that was the problem
Mk4 Build thread
Old 08-21-2012, 11:09 AM   #38 (permalink)
Dr Stebo's Avatar
One thing about that is it will always stick in the back of your mind and you'll never do it again
Viper Blue,White Stripes.5.0L 345hp, 5speed, 3.55 8.8 posi 17" Cobra R wheels, 275/40R17, Autometer Sport-Comp gauges.
Dr Stebo is offline   Reply With Quote
Old 08-21-2012, 11:19 AM   #39 (permalink)
Rob
Rob's Avatar
Yea 6:30 am Think I need to make a pot of coffee! LOL
Old 08-21-2012, 08:35 PM   #40 (permalink)
68390GT's Avatar
Make sure you do not have your calipers on the wrong side of the car. Sometimes they will still fit but the bleeder screw would be on the bottom trapping air on the top of the caliper. The bleeder screws need to be on the top of the caliper.
#4511 delivered 7/11/03 Born on 7/4/04. Every morning when I leave for work I pause as I walk by my FFR. Life is good!
68390GT is offline   Reply With Quote
Old 08-21-2012, 11:51 PM   #41 (permalink)
68390GT, it always helps to read the posts first, he already realized he had them switched.
Old 08-22-2012, 12:01 AM   #42 (permalink)
BlitzAttack's Avatar
Maybe your calipers are on the wron.........................ahhh just kidding!
Factory Five MK4 #7593- DOD 9/11/2011
First start - 12/8/2012
Ford 306, Aluminum heads, Cam, Carburated
3 Link, 4 wheel discs, 15" FFR Halibrands
Goodyear Billboards
www.wix.com/cdurhamwot/blitzattack-mk4-build
http://s1124.photobucket.com/albums/l571/BlitzAttack65/
BlitzAttack is online now   Reply With Quote
Old 08-22-2012, 03:11 AM   #43 (permalink)
Vroom Vroom
Ok ok my ribs hurt from all the jabs
MKII non donor
