My ego is shot. Is my transmission? - FFCars.com : Factory Five Racing Discussion Forum
Old 08-18-2012, 02:28 AM   #1 (permalink)
Redshift's Avatar
I have been looking for the source of a clunk when letting the clutch out in first. I worked from the rear suspension to the diff to the U-joints to the transmission. Yep, it's in the tranny. Whoa! The mounting bolt to the bell housing is hanging out an inch! The other three are not tight.
In my mind, I used locktite, torqued all critical fasteners, and marked them with a line. Apparently not.
I am just recently on-the-road with the roadster, with about 500 miles on it. I had noticed a little play from the start, but attributed it to the ring and pinion. The clunk was worse yesterday, so I looked seriously at it today.
So, have I ruined the transmission by allowing it to come slightly loose from the bell housing? I know the alignment is rather critical. This is a Tremec TKO 500 and a McLeod bell housing. It looks like it is a bolt/nut rather than threaded into the bell housing (I did this part five years ago, so I don't remember). So that means having to separate the BH from the engine. Can I do this in the car, or do I have to pull the whole engine/transmission? Are there dowel pins between the transmission and the bell housing?
https://picasaweb.google.com/1024002...26995796472162
https://picasaweb.google.com/1024002...26952295667986
Mk II+, Crate 5.0 w/ E303 Cam, 3-Link, TKO500, Mass-Flo, 9psi Powerdyne, Ford Fun Drop Butt Mod, smooth butt mod, wheel arches mod, roll bar mod, steering rack mod, foot box mod, door latches mod. Self painted. This is why it took so darn long! Go-cart 7/29/2010. Licensed as 1965, insured and on the road 8/12. Former user name David Lindquist.
Redshift is offline   Reply With Quote
Old 08-18-2012, 03:43 AM   #2 (permalink)
Hopefully someone with more experience will chime in, but it's possible you might have an issue with the pilot bearing. Do you know if it's a solid bronze or roller bearing?
If it's a roller bearing, it doesn't take much to make them look like this:
Old 08-18-2012, 04:39 AM   #3 (permalink)
Redshift's Avatar
Unhappy
I don't know about the pilot bearing. That does not look good. I am dreading pulling the engine and transmission. As I recall, it was a tight fit with the body off.
Old 08-18-2012, 03:01 PM   #4 (permalink)
section 8
It is possible . you could just tighten the bolts and try it . You probably have a steel bell with nuts welded to the inside . the pics do not work. If the other 3 bolts were just not tight , not an inch out you might be ok . My favorite saying that I learned when I moved south is " it aint gonna be no worse" if you tighten it up and try it . Yeah aint no worse great.. either way you say it it's kind of funny. Whats the back seal on the trans look like ? Has it bashed the the drive shaft? That would be a determining factor. If its just loose and rocking back and forth and the case of the trans is not cracked. You might be ok . Any more than that I'd want to look at the pilot (shown above) and the collar that the throw out bearing rides on . Happy hunting Bob
Old 08-18-2012, 04:29 PM   #5 (permalink)
ROADRACER83's Avatar
What Bob said
Dave:
I'm with Bob. If the trans only came back a few tenths of an inch, retighen the bolts with more torque and LocTite. You may be able to see on the drive shaft yoke how far it came back. The trans centers in the bellhousing on the front bearing carrier which is about 7/16 or so thick so if the trans didn't come back too far the you may be OK. I wouldn't yank the trans until you really know if there is damage.
Old 08-18-2012, 05:09 PM   #6 (permalink)
Redshift's Avatar
Thanks guys, I'll give that a try.
Old 08-18-2012, 11:20 PM   #7 (permalink)
Cone Basher's Avatar
Lightbulb
Redshift: This sounds to me like a vibration induced problem. Did you index your bell housing to insure that the center line is correct? If the trans input is not excatly centered (within spec) in the pilot bearing it can cause vibration induced failures of the pilot bearing like the pics above. If you have a solid pilot bearing I would recommend the above, loctite the bolts (use blue) and see what happens. Maybe the bolts were not torqued to spec the first time around.
Keep us posted:
Best of luck:
CB
Old 08-19-2012, 10:18 PM   #8 (permalink)
If you find there are non welded nuts inside the bellhousing don't give up. Many times a bunch of short blasts w/ an impact will get things to tighten. Hit the trigger for as short a time as you can and still get a full power shot. You are trying to use the inirtia of the nut to get a tiny bit of bolt tightening before the nut spins so let it come to a complete stop before hitting the trigger again.
Old 08-20-2012, 04:53 AM   #9 (permalink)
Redshift's Avatar
They were the welded, threaded plates, so not a problem. Locktite blue'd and torqued as much as possible. I'll see how it goes.
I tried to do the indexing back when I installed it, but could not ever get a real positive feeling about it. I couldn't set up the dial indicator to get a definite measurement. I should have gotten some help on that issue.
I have a little vibration at 2200 RPM, but smooth above and below that. I still have some play in the transmission, and that coupled with the ring and pinion slop is a little annoying. While rebuilding the clutch pack in the posi, the lash was at maximum (.012"?)
