Will be using the T5 transmission. May be doing some mild auto-X. I think I may prefer a shifter in a slightly forward position only because that is what I am use to.
Suggestions? Pictures?
Ambition is a dream with a V8 engine
Elvis Aaron Presley
Ordered MKIII Dec 2008 - Canceled Jan 2009
Mk IV Down Payment August '12
Delivered Feb '13
Setup for 302, Complete IRS
347 Stroker - AFR Heads -Mass-Flo - T5
Duel Roll bar
Halibrand 17" Wheels
I switched to a Pro 5.0 shifter from a Hurst shifter that came on my donor car and like it a lot better. Shifts smoother from 2nd to 3rd. With the angled shifter handle it doesn't really feel like it is toward the rear of the console to me and you would get used to very easily. If you really want a mid shift there are options like switching the tailshaft for one from an S10. If you search for "mid shift conversion" I think you would find a lot of info on the subject.
I like the feel and sturdiness of the Steeda shifters. Switched from a PRO-5.0 to a Tri-ax in my Mustang. When I got my MK3, that was a very early change out also. The FFR had a B&M shifter. That shifter is now in the Steeda box the Tri-ax came in.
I'm sure this will be just one of many opinion.................Good luck on your choice.
Front shift on a T5 using an S10 tail shaft. I love it!
Alright, 1st I have heard about this. Tell me more. Is this a direct bolt up?
Elvis Aaron Presley
Delivered Feb '13
Duel Roll bar
I changed mine from stock to Pro 5.0 and didn't feel any difference other than it now pops out of 5th.
Total wate of time and money
Awesome wife, Great Job and cool toys...... God is good!!
Graduated July 2009
331 CID, Twisted wedge heads, E303 cam, 1.7:1 roller rockers, Mass-Flo injection, Aluminium rad, Ceramic coated headers & pipes, Breeze drive shaft, 3 link, powder coated frame, heated sport seats, Motorsport 1.75 turn power rack, power brakes, 295/50R15 rear tires, 235/60R15 fronts with Halibrands from Whitby's, March pulley's, 3.73 rear diff and Motorsport rear diff girdle and much more. http://rides.webshots.com/album/557996496OrYPsL
Just do a search on mid shift or front shift and you should find some good info.
What speedometer did you go with?
Elvis Aaron Presley
Delivered Feb '13
Duel Roll bar
Here's mine, still under construction.
S10 midshift conversion with an MGW shifter. With the offset shifter arm, you can put it just about wherever you want. I think at about 45* (forward and to the drivers side) is preferred.
Licensed 4/24/13!! Wahoo!
I have opened a dialog with Bruce at Modern Drive line and started the ball rolling.
Thank you
Elvis Aaron Presley
Delivered Feb '13
Duel Roll bar
I did the S-10 swap with a Speedhut GPS speedo-Absolutely love it...
Only using the v.s.s. (along with a custom reluctor ring) for cruise control!
Ok Irandell, Tell me about this.
What is the speedhut GPS and v.s.s.?
Elvis Aaron Presley
Delivered Feb '13
Duel Roll bar
Gauges, Custom Gauges, Tachometers, Speedometers, Shift Light, Pod
...like many here I ordered my cobra's gauges from them...quality stuff and you can customize them almost any way you want 'em. They also have a GPS option on their speedos that uses a small satellite-radio type of receiver that eliminates the need of hooking to your vehicle speed sensor (vss) for speed, mileage, etc. along with the ability to record top speed, 1/4 mile times, 0-60 et's.
They also eliminate the need to calibrate the speedo or even re-calibrate after tire size changes, axle ratio changes, etc.
The small magnetic receiver works great even through the fiberglass...mine is stuck to the brake booster and never misses a beat!
I'm a HUGE fan of this shifter and their other products. This company is run by some nice people with great products.
