Trying to install Tractionlok brackets, holes don't line up - FFCars.com : Factory Five Racing Discussion Forum
Old 08-16-2012, 05:02 AM   #1 (permalink)
Vroom Vroom
Ok so on the drivers side when I go to install the tractionlok bracket the holes do not line up, I can either get the spring holes or the bracket attachment hole lined up but not both.
Do I drill a bigger hole?
MKII non donor
347 stroker with stacks
Old 08-16-2012, 10:37 AM   #2 (permalink)
I would put a bolt and nut in the rear hole and then get a tapered prybar to try my best to get the side holes lined up. The problem is that these things can move w/ high power and sticky tires so I would avoid if at all possible drilling them out. I have to tighten my bolts 2-3 times per autocross season.
Old 08-16-2012, 01:50 PM   #3 (permalink)
Joe
Senior Mem / Moderator
Joe's Avatar
Wow, really? Not wanting to get this thread too much off topic, but specifically which bolts keep getting loose 2-3 times per autocross?
Joe - Texas Cobra Club - DFW
GRADUATION THREAD LINK
BUILD VIDEO!!
Go Cart Video
Old 08-16-2012, 02:48 PM   #4 (permalink)
Vroom Vroom
I pushed, I pulled I pried but all I have is still 1/4 a hole visible where the shock bolts go through.
MKII non donor
