Outer Tie Rod to Spindle Torque Value - FFCars.com : Factory Five Racing Discussion Forum
Old 08-15-2012, 07:49 PM   #1 (permalink)
ATOLightning's Avatar
Quick Question.
I have installed the spindles and hubs and outer tie rods, but I didn't torque everything down yet. I have a MK4 with the newer setup that doesn't use the cotter pins on the nuts for the outer tie tods (more like a modern car). The book says to torque them to 25lbs, but I'm concerned that value is for the nuts with the cotter pins. Is 25lbs the appropriate value to torque the newer style?
Thoughts?
I did search a little, but couldn't find a definate answer.
ATOLightning is offline   Reply With Quote
Old 08-15-2012, 10:49 PM   #2 (permalink)
The type of nut locking mechanism has no effect on torque.
Old 08-16-2012, 03:08 AM   #3 (permalink)
ROADRACER83's Avatar
Torque?
My copy of the manual says 25-35. I would go on the high end (35 foot pounds).
Old 08-16-2012, 10:51 AM   #4 (permalink)
Someday you will try to remove that tierod end from the spindle and realize why 25-35 is plenty. Those tapers lock up really tight.
Old 08-16-2012, 01:02 PM   #5 (permalink)
That's pretty much true, but I was concerened that since the tie-rod end is a different part that it may require a differnet torque spec.
Looks like in this case that it may be the same either way.
Thanks guys!
