Looking for 8.8 brake line bracket - FFCars.com : Factory Five Racing Discussion Forum
Old 08-09-2012, 08:43 PM   #1 (permalink)
David Townsend's Avatar
I'm going to post this over in the buy/sell as well but first I thought I'd see if anyone knows what the heck you call it - the bracket that connects the flex line to the two rear hard lines on an 8.8 live axle. I've scoured the Internet looking for one and can't seem to find it.
Or, if you happen to have the part I'm looking for and want to part with, let me know...but, first, tell what the damn things is called. It's driving me crazy.
"Tonight's forecast is...dark, fading into light early in the morning" - George Carlin as the 'Hippy Dippy Weatherman'
David Townsend is offline   Reply With Quote
Old 08-09-2012, 08:49 PM   #2 (permalink)
Rich A's Avatar
Breeze sells them.
Old 08-09-2012, 08:58 PM   #3 (permalink)
Or one of these
itzdapig is offline   Reply With Quote
Old 08-09-2012, 10:57 PM   #4 (permalink)
Originally Posted by itzdapig View Post
Or one of these
That's it! What the hell is it called?
Old 08-09-2012, 11:28 PM   #5 (permalink)
Rich A's Avatar
The gold bracket (shown below) and fitting that connects to the rubber flex hose is no longer available.
You will have to salvage yard source it.
Old 08-10-2012, 12:34 AM   #6 (permalink)
Found it at Rock Auto. 7 in stock. Bendix part # 77615, $10.48. Simply called a "hydraulic hose". No wonder I couldn't find it with an Internet word search.
Old 08-10-2012, 01:48 AM   #7 (permalink)
Mustang Man's Avatar
That is for JUST the hose, it will not include the upper frame bracket that is normally riveted to the frame, as seen in the above photo.
I HIGHLY recommend the Disc Brakes-R-Us conversion hose, which is what I used. It is longer and doesn't use the funky end fitting at the frame, but instead a standard brake line fitting that works with the universal bolt/rivet on line tabs as shown in the first photo.
It's about half way down the page:discbrakesrus
HTH...
FFR5310RD
Mustang Man is offline   Reply With Quote
Old 08-10-2012, 02:27 AM   #8 (permalink)
Mark Reynolds's Avatar
If you have rear discs why not just run two hoses from the frame to the caliper just like the front? It has been done this way since 1994 on Mustangs.
Mark Reynolds
Breeze Automotive
508 533 6455 Office
508 612 0393 Mobile
Mark Reynolds is offline   Reply With Quote
Old 08-11-2012, 05:42 PM   #9 (permalink)
Scott L's Avatar
I did this as Mark Reynplds suggested. I shamelessly copied this from Marks go-cart. Lines go right from the frame to the caliper. No brakelines on the rear end. Very easy, very clean -
Good luck - Scott
Scott L is offline   Reply With Quote
Old 08-12-2012, 01:23 AM   #10 (permalink)
Sadly, have already set up for the bracket and really just don't want to back track to change it. Bendix part was $25 from my local store. No problem getting it.
Old 08-13-2012, 03:03 PM   #11 (permalink)
VdubJoe's Avatar
Also just picked one up at AdvancedAuto. 14.99. They stock them.
Joe
VdubJoe is offline   Reply With Quote
Old 08-13-2012, 05:44 PM   #12 (permalink)
Lay posi
wibby's Avatar
They wern't done that way on my 94GT, but your suggestion is still a good one. My 94 donor had the single flex line from the body to the axle and then a hard line across the axle then back to flex lines at each disc brake caliper. If anyone is looking in the junk yard for that flex line bracket, they can also include 94 cars in their search. Personally if I didn't already have the donor flex line and bracket, I wouldn't try to get them because the Mustang bracket is too short anyway (at least my 94 one was). I had to make a bracket extension to get my donor bracket to work and allow the rearend to reach full droop. The Disc brakes 'r us is one possible solution if the line is long enough and Mark's suggestion of 2 lines is a good one too.
Wibby
302 Kenne Bell Supercharged, power steering, power brakes
wibby is offline   Reply With Quote
