Hi,
I sell a billet aluminum SB Ford thermostatic temp valve now with a temp sensor port. The picture attached has the sensor on the bottom.
Any questions just give me a call or email.
Mike Forte
Forte's Parts Connection
40 Pearl Street
Hi Zoa,
I have several options. Check your PM box.
Mike Forte
40 Pearl Street
Mike,
Is this something that could be sandwiched between the remote mount and the filter, allowing oil to circulate from the engine, through the filter, and back to the engine when the oil is cold, but then route it through an oil cooler when it warms up - or does it need to be mounted to the block?
Thanks!
Later,
Chris
Mk3.1 #7074
Picked-up at FFR - 10/10/09
Hi Chris,
This mounts to the oil filter pad and then the filter screws to the sandwich adapter. The oil temp port is in line to the filter or cooler depending on oil temperature. This position put the oil flow just out of the oil pump so it measures oil sump temp prior to cooling or filtering.
Mike Forte
40 Pearl Street
Mike,
I needed that a week ago. I had to drop the oil pan and weld a bung into the pan for a temp sensor. I have the other temp valve. Oh well nothing like missing a really good innovation and spending more money.
i like that you have the oil temp tapped into it. I just purchased a earls setup a few weeks ago, but this looks like a nice piece, good luck!
MK4 delivery 12/17/11
Build thread: HERE
Epic First start video HERE
Build thread: HERE
It's always good to have a "shill" in the crowd........
How much?
How much?
How much?
How much?
How much?
How much?
How much?
Is that doggie in the window??????????????
Paht time pahts guy!!!!!!!!!!
Your Solution Specialist!
Call 508-875-0016 to order today http://www.facebook.com/album.php?ai...axpipe=1&__a=3
Hi Guys,
The sandwich adapter with the electric sensor port is $155.00.
Mike Forte
40 Pearl Street
Will the sensor location read accurate oil temp even if the sandwich plate ports are plugged? Considering installing as a future provision for oil cooler but also to allow me to hook up oil temp gauge immediatly.
Mike,
I allready have your oil filter adapter kit # FPCOFA1002 and am running a remote oil filter, Do you have a valve that can hold the remote oil filter and when oil gets hot switch the flow to the oil cooler ?
Hi joehonee,
The sandwich adapter flows the oil past the sensor port to the filter and then returns to feed the engine.
Mike Forte
40 Pearl Street
Mike,
Aloha, Troy
As a seperate piece we do have a valve that goes inline. Its $105.00 and a week or so from me!
