Why I'll never use rope to change valve seals again - FFCars.com : Factory Five Racing Discussion Forum
Old 08-04-2012, 12:54 PM   #1 (permalink)
jdl902's Avatar
I have an oil burning issue that I was hoping some new valve seals would fix. Not having any fittings on hand to pressurize the cylinder I stuffed some rope in the cylinder so I could remove the springs. When I tried to remove the rope I learned that I was better at tying knots than I realized and could do it without even seeing the rope. This picture shows what I got to once I pulled the head to remove this stubborn rope. Fun.
The silver lining is that with the heads off cleaning out all of the burnt oil deposits is a snap.
Mk III 5035, 3-link with 302. Ottawa, ON
jdl902 is offline   Reply With Quote
Old 08-04-2012, 01:01 PM   #2 (permalink)
Nothing wrong with a good nylon rope. That looks like polypropylene.
transio is offline   Reply With Quote
Old 08-04-2012, 01:19 PM   #3 (permalink)
tim-in-oakton's Avatar
wow - neat trick!! I knew a girl growing up in Ottawa that could tie cherry stems in a knot with her tongue.... must be something in the water.
I did valve springs last month, and it took about 15 minutes to grind apart an old sparkplug and to weld an air fitting to it - throw 60 psi on the cylinder at it's TDC with the car in gear and the safety brake on and that valve isn't going anywhere without a lump-hammer to assist it.
Thanks for the picture - that made my morning!
FFR 5736, MKIII, 3 link, PS, PB, 302 w GT40 heads & intake, 3.55, Cobra brakes
tim-in-oakton is online now   Reply With Quote
Old 08-04-2012, 01:26 PM   #4 (permalink)
Big-Foot's Avatar
Wow... First time I have heard of that happening...
Tim - I used to know that girl!!!
Regards - Randy Orbs
Racecar Fab/Support
69 Camaro SS 4spd
Old 08-04-2012, 03:51 PM   #5 (permalink)
Non-whiner
Mark Reid's Avatar
The fitting and a quick disconnect for your compressor are less than $10 (I know, too late for you). New gaskets and all your time, several $100. Lesson learned, but painful. Thanks for sharing with others anyway.
FFR coupe #190 SOLD
1966 Bronco w/289 and 3 speed
Unknown
Mark Reid is offline   Reply With Quote
Old 08-04-2012, 04:12 PM   #6 (permalink)
cwrandolph's Avatar
A soft nylon rope works great. As mentioned above, you used the wrong kind. Don't stuff the entire length into the cylinder - leave the end hanging out of the plug hole. Then gently turn the crank until the piston pushes the rope against the valves. I've never had any problems doing this.
cwrandolph is online now   Reply With Quote
Old 08-04-2012, 04:32 PM   #7 (permalink)
SPeace-ATL's Avatar
That's a great knot!
Have you considered building a ship in a bottle?
1965 Mustang Restomod - 5.0 Coupe /MAF/EFI/B303 Roller Cam
5-Speed Specialist - Atlanta!
SPeace-ATL is online now   Reply With Quote
Old 08-04-2012, 05:22 PM   #8 (permalink)
section 8
I failed basic seamanship but that is a nice knot. To verify your oil use problem take the heads apart and look at the backside of the valves for big goey black deposits , if they are there you have a good shot at solving the problem. If its on the faces you might not be so lucky . Also check the guides by moving the valves up and down 1/2 way out of the guide or just a lttle? if there is a bunch of movement that's bad a little is ok . Be sure to lube everything when re assembled and be sure nothing is sticky .. Bob
Old 08-04-2012, 06:26 PM   #9 (permalink)
tad240's Avatar
OUCH! Sorry to read this story. I'm sure that was an extremely frustrating event.
I just installed new cams & springs in my 4.6 DOHC with the engine in the car. (Not too fun; 32 springs = lots of time) I used small diameter nylon rope fed thru an aluminum tube that would slide thru the spark plug hole. The DOHC plugs are several inches down in the heads so the aluminum tube allowed me to guide the rope down to and thru the plug hole. No issues removing the rope - but it did cross my mind as a concern. I had all my lifters removed and cams out so the rope would not get pinched by a valve closing.
Tad Rhodes
Whitakers, NC
tad240 is offline   Reply With Quote
Old 08-05-2012, 12:15 PM   #10 (permalink)
jdl902's Avatar
I didn't push the whole rope into the cylinder, the frayed end shows where it broke as I tried to pull it out (last resort). By that time I had confirmed there was a knot by sliding some tubing down the rope into the cylinder to try to charm it out. I've used this method in the past with no problems but thanks for all the tips on how "knot" to do it this way; you guys must be soccer players to enjoy kicking a guy when he's down I had never heard of any problems with this trick but did find a few other victims online once it happened to me. And if you think using a different kind of rope makes it knot-proof then good luck to you, but until I come across an example of someone getting air stuck in their cylinder I'm reformed to using an air compressor.
Jason
Old 08-05-2012, 02:05 PM   #11 (permalink)
Big-Foot's Avatar
FWIW Jason, I don't think any of us were trying to kick you while you were down. Just pals commiserating and helping you to laugh at fate if nothing else...
I seem to continuously run into stuff like that..
Okay for $10,000 to win can you -----
Snag that garden hose on a fence picket and puncture it with a hidden nail on the first try?
Can you slip and drop that tool, break it and the work you just completed on the first try?
Can you stuff a rope into a cylinder and tie it in a knot so tight that you could tow the Queen Mary across the Atlantic with it on the first try?
You get the picture....
Racecar Fab/Support
69 Camaro SS 4spd
Old 08-05-2012, 04:01 PM   #12 (permalink)
Joe
Senior Mem / Moderator
Joe's Avatar
LOL!!! I really did laugh out loud.. Good one!
Joe - Texas Cobra Club - DFW
GRADUATION THREAD LINK
BUILD VIDEO!!
Go Cart Video
