build 7859 - FFCars.com : Factory Five Racing Discussion Forum
Old 08-04-2012, 05:43 AM   #1 (permalink)
ldsman's Avatar
build 7859
i receive my complete kit on july 30th just finished inventory and found i was mission a few parts that were never on my order but got that fixed with ffr. great guys to work with. . i could not be more excited. i got the complete kit with the upgraded aluminum high back seats and the 3 link set up and was able to take advantage of the sale and purchased the polished pipes and 17 hailbrand rims and heater and passanger roll bar. my drive train will be a 2005 4.6 3 valve engine with the 2005+ transmission.
my goal is to build a street car that the family can have fun with. nothing too serious. im expecting about 350 hp to rear wheels. it will be manual steering and brakes. ill try to geep this post updated on my status of the car. i appoligize ahead of time if i have lots of questions along the way.
robert mccabe
Old 08-04-2012, 01:13 PM   #2 (permalink)
luey2009's Avatar
congrats man, dont worry about the questions plenty of great guys here to help answer anything, good luck its soooo much fun!!!-Andy
FFR #7815 mk4 complete kit ordered 4/23/12, kit completion date 5/26/12,delivered 6/3/12,roller w/lights 9/15/12, motor installed 11/3/12,first start 11/24/12,first go cart 3/30/13
Old 10-08-2012, 03:03 AM   #3 (permalink)
ldsman's Avatar
build updatw
robert mccabe
Old 10-08-2012, 03:05 AM   #4 (permalink)
ldsman's Avatar
robert mccabe
Old 10-08-2012, 03:06 AM   #5 (permalink)
ldsman's Avatar
robert mccabe
Old 10-08-2012, 03:14 AM   #6 (permalink)
ldsman's Avatar
the build is coming along. today i was able to finish the engine bay and connected the steering. just need to connect the tie rod ends. its starting to look like a car now.I have started the cockpit aluminum. im really glad i powder coated all the aluminum panels and decided to use black rivets. mt little boy was so excited to sit in the car and be ale to steer it. black is really sharp but ive noticed it does scratch very easy though. im hoping if all goes as planed. i will be installing the engine next weekend. ill try to post pictures again after the motor goes in.
robert mccabe
Old 10-08-2012, 03:18 AM   #7 (permalink)
Did you powder coat before you drilled all the holes?
TheFatKid is offline   Reply With Quote
Old 10-08-2012, 04:15 AM   #8 (permalink)
ldsman's Avatar
Yes I did. But forgot to drill frame. So I had to drill frame
robert mccabe
Old 10-08-2012, 04:46 PM   #9 (permalink)
ldsman's Avatar
Does anyone have any tips on installing a 4.6 engine. We will be installing it on saturday.
robert mccabe
Old 10-08-2012, 07:13 PM   #10 (permalink)
MPTech's Avatar
Interesting, I don't know if there is a right & wrong answer here, but my tranny tunnel aluminum doesn't touch the 3/4" tubing on the sides. If I did try to rivet it, it would distort the side panels.
btw, your black on black on black looks terrific!
Originally Posted by ldsman View Post
Licensed 4/24/13!! Wahoo!
Old 10-08-2012, 10:58 PM   #11 (permalink)
Pls reconsider and do power steering! See this post.
Fast Freddies Power Steering
Ford PS is fine BTW
Old 10-08-2012, 11:38 PM   #12 (permalink)
ldsman's Avatar
It does pull the panels a little on the side walls. But i want a good contact for there is no rattling. It will all be covered anyways.
robert mccabe
Old 10-10-2012, 02:40 PM   #13 (permalink)
Dang you are making good progress.
Are you retired or something?
Old 10-10-2012, 05:11 PM   #14 (permalink)
ldsman's Avatar
Nope. I only work on in a few hours a week.most of my time is with the family. But last weekend i spent a little bit of tiem on it.
robert mccabe
Old 10-10-2012, 05:25 PM   #15 (permalink)
ClemsonS197's Avatar
I assume you're bolting up the motor and trans, and then install.
Put the front end as close to the ground as you can and still get the engine hoist legs below it. Raise the tail end of the car as high as you can. My motor and trans are coming out again this weekend too. Clutch swap.
MK3.1 - Under Construction
Coyote 5.0
Tremec 3650
ClemsonS197 is offline   Reply With Quote
Old 10-25-2012, 05:40 AM   #16 (permalink)
ldsman's Avatar
So tonight I was able to modify the transmission brace. The transmission is now mounted. The cockpit aluminum is next on the list to do. I'm so excited to get this thing to the o cart stage. I'll post more pictures soon.
robert mccabe
