Best Group 51 Battery for Breeze Battery Box - FFCars.com : Factory Five Racing Discussion Forum
Old 08-03-2012, 11:24 PM   #1 (permalink)
Jethrow's Avatar
Hi everyone,
I am looking for the best battery I can fit into my Breeze front mount battery box. Instructions say it has to be a BCI Group 51 sized battery. I was hoping for a battery with about 550 to 600 CCA but have not been able to locate one as yet.
I need it to start a 430 HP EFI 6.2 litre V8.
Do I actually need this many CCA?
Thanks everyone.
Tim
FFR MkIV #7393 under construction, LS3 / TR6060
HSV Clubsport R8
Jethrow is offline   Reply With Quote
Old 08-03-2012, 11:35 PM   #2 (permalink)
Husband/Father/Son
mrmustang's Avatar
Originally Posted by Jethrow View Post
Hi everyone,
Thanks everyone.
Just installed a new Optima Yellow Top DR51 in my ERA 289FIA
Bill S.
How to buy a used Cobra
mrmustang is online now   Reply With Quote
Old 08-03-2012, 11:58 PM   #3 (permalink)
Jethrow's Avatar
Bill S.
And just to check, you have a 4.6L EFI right? And does the optima start this engine easily?
Tim
HSV Clubsport R8
Old 08-04-2012, 12:29 AM   #4 (permalink)
ClemsonS197's Avatar
I looked for a long time and found the Autocraft Gold from Advance. 500 CCA's and starts my 412hp 5.0L Coyote just fine.
Buy AutoCraft Gold Battery, Group Size 51, 500 CCA 51-2 at Advance Auto Parts
MK3.1 - Under Construction
Coyote 5.0
Tremec 3650
Old 08-04-2012, 12:36 AM   #5 (permalink)
Tatika's Avatar
I got one from Costco for about $60 - 500 CCA seems to be plenty. I have not had any problems starting.
June 07 Build School; FFR #5765 delivered Aug 27/07; Complete May 2009; 347 Levy all forged rotating assembly, Edelbrock E-Street heads, Explorer intake, 70mm TB, BBK 76mm Mass air, 30lb injectors, 255 fuel pump, Gas-N sidepipes, PS with Heidts valve, PB, FF5 heater, Team III wheels & BFG tires ....
Tatika is offline   Reply With Quote
Old 08-04-2012, 12:37 AM   #6 (permalink)
Darren's Avatar
Costco, had it for two years and it is flawless...
www.GarageHobbies.com
Darren is online now   Reply With Quote
Old 08-04-2012, 12:43 AM   #7 (permalink)
Husband/Father/Son
mrmustang's Avatar
Thumbs up
I have a high compression 4.6L 32V DOHC with an Accel Gen 7 ECU (very voltage dependent) and yes, it fires it right up.
Bill S.
Old 08-04-2012, 02:55 AM   #8 (permalink)
MPTech's Avatar
Here's my top-of-the-line Autozone Battery I bought and installed last month.
Duralast Gold/Battery, 51R-DLG, 500 CCA, 8yr warrenty.
Old 08-04-2012, 03:33 AM   #9 (permalink)
Plodding Along
CCRsAC's Avatar
Sixty dollars (US) from the local farm supply store - 500 cca - and a few "Lucas" decals and some fake filler caps.
Later,
Chris
Mk3.1 #7074
Picked-up at FFR - 10/10/09
CCRsAC is online now   Reply With Quote
Old 08-04-2012, 08:20 AM   #10 (permalink)
Jethrow's Avatar
Nice touch with the stickers.
Tim
HSV Clubsport R8
Old 08-04-2012, 12:01 PM   #11 (permalink)
mirose's Avatar
I have the same battery in my 417 HP 347 Stroker and it starts just fine. I think the Optimas are the best, but fairly expensive. Your call.
FFR 7386 MK IV Roadster
Build Began 12/6/2010
First Start 11/18/2011
Go Kart 11/24/2011
Plan for Paint Winter-2012 at Metalmorphous
My Build Project Website
Old 08-04-2012, 12:29 PM   #12 (permalink)
Cobra Cory's Avatar
Do some reading on the Optimas. people are having problems with them since the company was sold. Not the same as they used to be. I also got the top battery from Autozone and it has worked flawlessly since I changed it. I do keep it on a tender while in the garage, to keep it in good condition too.
Cobra Cory is online now   Reply With Quote
Old 08-04-2012, 01:06 PM   #13 (permalink)
CCA's have nearly doubled in output since the 1970's, when the rule was 1 per cubic inch. That was a hard sell up in those days, too. Nobody wanted to spend $40 on a battery when a $24 dollar one would fire up a 12:1 compression 400 cubic inch motor using an old heavy non magnetic copper wound starter. Simply too expensive.
The industry recommendation for high output these days is based on the power consumption of an EFI equipped car with numerous accessories equipped with a 160 amp alternator. Now the marketing is all about the battery being an adequate capacitor for the alternator, and undersizing it might be detrimental.
So, does the roadster have power seats, stereo, a power moonroof, power tailgate, power side doors, GPS, a DVD player with two display screens, and an interactive cell link to summon a mechanic when you have a flat? Probably not.
That brings up how much alternator might be on the car, too. If it's got EFI and a stereo, maybe 120 amps is still more than enough. A Gen3 alternator would do. If carb, then it's a bit big, and you could drop down to less than 100. That brings up another area - don't use underdrive pulleys, they impede that alternator putting out power. If a few hp is that important, rethink how much rotational mass and electrical capacity is needed anyway. Don't forget that an $1,100 set of underdrive pulleys still won't free up more hp than a 6 qt oil change with synthetic. You can buy a lot of 5-20 syn for that cash.
Here's a point of perspective - take a look at what Mazda specs for a Miata. That battery is barely much larger than the one in your riding lawn mower, and the only complaint about them is maintenance based - poor venting in the trunk causes some corrosion.
Bigger isn't necessarily better, and can be detrimental. "Right" size the components in the system, and you won't spend more than needed, consume more than needed, and carry more than needed. It's a matter of performance as much as cost.
Old 08-04-2012, 06:59 PM   #14 (permalink)
Bill Hughes's Avatar
I bought my Optima 9 years ago, and it is still fine. Just replaced the wet cell in my Jeep two years ago, and it is fine today.
Build started 15 Dec. 2002
Old 08-04-2012, 08:05 PM   #15 (permalink)
cobrajj's Avatar
You might consider a 51 series battery instead of a 51R. The positive post is on the RH side so it is not so close to the X brace. Breeze forward battery location and arcing question.
cobrajj is online now   Reply With Quote
Old 08-04-2012, 08:23 PM   #16 (permalink)
Master Student
Doug Meldrum's Avatar
X2
FFR #7228, under construction
Doug Meldrum is offline   Reply With Quote
Old 08-05-2012, 12:44 AM   #17 (permalink)
Husband/Father/Son
mrmustang's Avatar
Yes they did have issues when they were sold as the new owners cut corners to cut costs and maximize profits. When that blew up in their face, they switched back to the original specs. You spend all that money on a kit, engine, suspension, massive amounts of upgrades, then you spend little to nothing on a battery. To each his own, my $169.95 was money well spent.....
Bill S.
Old 08-05-2012, 12:59 AM   #18 (permalink)
Darren's Avatar
Bill S.
... because a $60.00 maintenance free battery starts my engine just as well as a $169.00 pretty yellow or red battery. I have been known to upgrade things because they are pretty, just not the battery.
Old 08-05-2012, 01:34 AM   #19 (permalink)
Steak's Avatar
X2 on Bill's logic. I've used Advance for thirty years and put one in my FFR. They work great and have always been very fair with their warranties.
Chuck
FFR 6624, delivered 05/20/08, Levy Stage 3 (EFI), IRS, 15" PSE GT40 wheels. Whitby paint and finish. Forte's hydraulic clutch activator conversion. Completed and tagged 07/29/2011.
Steak is online now   Reply With Quote
Old 02-12-2013, 12:25 AM   #20 (permalink)
I am Legend's Avatar
Would I be able to use a 500cc amp, group 51 battery, if its mounted in the trunk? I like how small the battery is but will I have enough juice once the power wire is routed to the front of the car? I have 306 EFI
I am Legend is offline   Reply With Quote
Old 02-12-2013, 10:44 AM   #21 (permalink)
Bearhawk Builder's Avatar
I'll put a good word in for Odyssey batteries, the best I've ever had. I have a small pc680 in my 360 cubic inch aircraft and it turns that over fine all winter long and I've never put a charger on it. I'm thinking of using the same in the roadster. These newer tech batteries are amazing.
Dave
Bearhawk Builder is offline   Reply With Quote
Old 02-12-2013, 06:05 PM   #22 (permalink)
canuck1's Avatar
Smartypants!
The model 51 (as opposed to 51R) also makes the positive cable to mini-starter run a hair shorter and simpler in my opinion.
I have been using an Optima yellow top for more than 6 years now. I do maintain it in the winter months with a Batter Tender, but it has never failed to spin up my 9.9:1 compression ratio, 396 c.i. EFI engine at any time. I am pretty sure the A9L computer I am using retards the ignition timing a little while cranking though, so that does help make the battery's job a little easier.
Sean
canuck1 is offline   Reply With Quote
Old 02-14-2013, 11:48 PM   #23 (permalink)
Laser Stan's Avatar
2X on the Duralast Gold from Autozone
Starts my 347 stroker with ease.
Laser Stan is offline   Reply With Quote
