Hydraulic clutch fittings - FFCars.com : Factory Five Racing Discussion Forum
Old 07-31-2012, 08:25 PM   #1 (permalink)
Benched
Mikey_P's Avatar
OK, now I have enough fittings but have another question. The fitting to the left of the blue one is fine where the line comes in but seems to be a pipe fitting on the other end.
Does this connection look OK?
FFR5546 morphing into FFR7387
Garage Cam
Mikey_P is offline   Reply With Quote
Old 07-31-2012, 09:16 PM   #2 (permalink)
BigLeo69's Avatar
the double flare is not the same as NPT the pitch is different and the thread per inch too and the blue one is a npt to JIC fitting which is also called a AN @ 37*
your double flares are 45*
becareful some threads are close and going into al it will cross thread, even a compression thread is different.
"Torque is the grunt
MK3.1 #6945 her name is Buffy
p/u 04/04/09 roller 08/27/09
go-cart Memorial Day 2011
body on 11/11/11 Veterans Day
372w handbuilt
Old 07-31-2012, 09:21 PM   #3 (permalink)
BigLeo69's Avatar
may want to go with a flex hose on the slave and not a hard line.
google XRP they have a nice PDF file and you can find a npt 90* to JIC for the hose
372w handbuilt
Old 07-31-2012, 09:38 PM   #4 (permalink)
Benched
Mikey_P's Avatar
The line is flex line except for the last 3" and that is just to make the transition.
The AN side of the blue fitting fits into the flex line. It is a AN fitting also so no issue there.
If I had a fitting like the blue one with a AN on one side and a 45* on the other I would not even need a hard line at all. I just have not been able to fine such a fitting.
Hope that explains it a little better.
Garage Cam
Old 07-31-2012, 09:55 PM   #5 (permalink)
pipe to AN fitting
Do a google search for "AN to pipe adaptor" - they're out there - would make your install much cleaner/simpler...
Derrick
Pedalmasher is online now   Reply With Quote
Old 07-31-2012, 10:02 PM   #6 (permalink)
Benched
Mikey_P's Avatar
The fitting going into the slave is a 45* double flare fitting, so I need a 37* on one side and a 45* on the other side. That way it is just one fitting between the flex line and the slave.
Garage Cam
Old 07-31-2012, 10:17 PM   #7 (permalink)
4.6 SOHC T3650 Telorvek
d42davis's Avatar
Keep it simple. Assuming you flex line is -3:
http://www.summitracing.com/parts/AER-FBM2030/
d42davis is offline   Reply With Quote
Old 07-31-2012, 10:51 PM   #8 (permalink)
Got it - That's a bit trickier - we need a "hose pro" to chime in - I'm sure there's a suitable fitting out there somewhere...
Old 07-31-2012, 11:54 PM   #9 (permalink)
d42davis's Avatar
OK - here is the hose pro analysis: I'm pretty sure the slave has a 1/8" NPT inlet port. (throw the existing 90 ell away) and you have an AN-3 or -4 hose. Use a 1/8" NPT by AN-3 (or AN-4) 90 degree elbow. Screw the 1/8" NPT end of the ELL directly into the slave inlet port. Connect the AN hose directly to the AN end of the ELL. I know this seems very complicated for some but it's not.
http://www.summitracing.com/parts/AER-FBM2030/ for AN-3 hose
http://www.summitracing.com/parts/AER-FBM2031/ for AN-4 hose
Old 08-01-2012, 12:45 AM   #10 (permalink)
Benched
Mikey_P's Avatar
Nope I got it. I think I know where I can get the fitting locally too. Thanks and I'll let you know how it goes.
Garage Cam
Old 08-01-2012, 01:41 AM   #11 (permalink)
QSL
Stealth Ninja FFR builder
QSL's Avatar
any local hose shop should have it. 2501-03-02
MK4 delivery 12/17/11
Build thread: HERE
Epic First start video HERE
Build thread: HERE
Old 08-01-2012, 12:04 PM   #12 (permalink)
Benched
Mikey_P's Avatar
OK I am a dumbass. I never thought about taking off the fitting on the slave cylinder. Guess what, the blue fitting threads right in! With the u-turn fitting supplied with the line I think it will all work out. I hope this helps somebody else.
Thanks everybody for the suggestions, it made me look closer at what I had.
Garage Cam
Old 08-01-2012, 03:41 PM   #13 (permalink)
Ain't it nice when a plan comes together!!
Good job.
DV
