GM-Style HEI Distributor On Carbed 5.0 - FFCars.com : Factory Five Racing Discussion Forum
Old 07-28-2012, 04:07 AM   #1 (permalink)
Mike D's Avatar
Anyone here use one? Going to put one in tomorrow and was looking for tips/tricks beyond it looks like I'm gonna need a smaller air cleaner.
Mike D is online now   Reply With Quote
Old 07-28-2012, 04:12 AM   #2 (permalink)
Ray
Ray's Avatar
Yep been using one for years. Bought one from Performance Distributors. I have a 14-inch round air cleaner with a 3-inch tall KN filter.
Ray
PS: You can see it here (http://www.facebook.com/photo.php?fb...type=1&theater)
Ray is offline   Reply With Quote
Old 07-28-2012, 04:18 AM   #3 (permalink)
Mike D's Avatar
Thanks ray.
I have one of the 289-style lids, I think it's 15"
The one I bought has a cast iron gear and I was planning on swapping it with the one on the Duraspark I'm using now so I don't have to worry about the compatibility issue.
Can you give me a run-down on the wiring?
Old 07-28-2012, 04:20 AM   #4 (permalink)
Rich A's Avatar
You can look at a Pertronix Distributor.
http://www.pertronix.com/prod/new/details.aspx?ID=144
Old 07-28-2012, 04:22 AM   #5 (permalink)
Mike D's Avatar
Thanks, but I already have the HEI unit.
Old 07-28-2012, 12:43 PM   #6 (permalink)
Master Builder
The good and the Bad
The good is the dizzy is good and virtually maint free. The bad is it limits air cleaner selection. Not to big a problem IF you are using most engines. If running a tall deck 351
the block is so tall that the air cleaner will hit the hood , if you use a taller air cleaner to clear the EFI dizzy. And you can't use a drop base to clear hood because hits the Dizzy.
Had to use a KN 2" and flow top. and modify the base plate to get it all in and still just barely touches hood on hard acceleration. If had to do it again would use a different Dizzy.
But only for that reason.
Kenny
PS thats on a MK 3 body with molded hood/scoop. Other choice would be larger scoop.
first time builder is offline   Reply With Quote
Old 07-28-2012, 03:31 PM   #7 (permalink)
Ray
Ray's Avatar
Originally Posted by Mike D View Post
Thanks ray.
Mike,
The set-up I have has a 12-volt power wire, a wire to the tach and of course the 8-spark plug wires. I added their rev limiter last year so there is an extra wire for that. Do you want some photos? Send me a PM with your e-mail and I'll send you some.
Ray
Old 07-28-2012, 04:11 PM   #8 (permalink)
Mike D's Avatar
Thanks Ray, PM on the way.
Old 07-30-2012, 05:30 AM   #9 (permalink)
Useless's Avatar
There is a plan that uses the module from the hei and puts it in the Durospark was thinking of doing it myself---dave
347 efi 355 gears for now
Useless is offline   Reply With Quote
Old 07-30-2012, 03:21 PM   #10 (permalink)
Mike D's Avatar
That's what I have now, I put it together back when I swapped from EFI to carb. It works OK on the top end and if you have a cam that allows you to idle about 900-950 it's fine but with my small E-cam I should be able to drop the idle down to 750 or so, but with the system I have the spark goes away under 875. Something to do with the Duraspark and Hall Effect.
