Stiffer, thicker feeling… :) - FFCars.com : Factory Five Racing Discussion Forum
Old 07-27-2012, 06:04 PM   #1 (permalink)
FFR 7469
PhoneGuy's Avatar
Icon18 Stiffer, thicker feeling… :)
So just checking in to see what others did to give a better more firm feel to the trans tunnel cover. Not that it is going anywhere, but it just doesn’t have that firm stiff feeling.
I was thinking of buying a thicker aluminum panel to attach to the underside of the current tunnel pannel but I wasn't sure if that would make it any better or as good as what I would want.
Any ideas with pictures would be much appreciated.
First Start First Start Video
First Go Cart First Go Cart
Old 07-27-2012, 06:09 PM   #2 (permalink)
Avalanche325's Avatar
How about a couple pieces of AL angle rivited to the inside?
MKIV Roadster....FFR7694
Avalanche325 is offline   Reply With Quote
Old 07-27-2012, 06:19 PM   #3 (permalink)
FFCobra Captain
Dan Babb's Avatar
Do you have it all riveted in and have insulation and carpet on it? Mind feels pretty solid...I have an MK3.
My Current Car
FFR5857
Old 07-27-2012, 06:22 PM   #4 (permalink)
Vroom Vroom
I had a new piece made out of thicker aluminum, coated the bottom and top with insulation and had thicker carpet installed on the interior. I them used 4 screws to hold it into place so I could still remove it.
it feels very secure.
MKII non donor
347 stroker with stacks
Old 07-27-2012, 06:49 PM   #5 (permalink)
FFR Master Craftsman
Greg_M's Avatar
What are you trying to do on it? Sometimes a little bounce is a good thing
Miss August 2007
Miss December 2012
Miss TR6 June 2013
The blues brothers
Greg_M is offline   Reply With Quote
Old 07-27-2012, 07:57 PM   #6 (permalink)
Silverstreak02's Avatar
I put two layers of insulation (Damplifier and EZ-Cool) on it followed by carpet. It is very solid and doesn't move at all. Once the seats are in you won't be putting much weight on it. I don't think it needs to be reinforced.
Old 07-27-2012, 08:19 PM   #7 (permalink)
Junior
03SC's Avatar
Yep, damplifier here as well underneath, felt and vinyl on top.
FF6854 - Completed 7/12/12 SOLD 8/28/2012
Levy 5-link, Levy Billet LCA's, Willwood 6/4's, Levy DA Konis, SAI mod
LR narrowed 8.8, Comp Bumpsteer. Stage 5.5 408W, Super Alloy T-5+, Ron Davis Cooling System, LR Custom Headers and Sidepipes. Performance Automotive Paint.
Build pics below:
http://s239.photobucket.com/albums/ff187/03SC/
03SC is offline   Reply With Quote
Old 07-27-2012, 09:14 PM   #8 (permalink)
FFR 7469
PhoneGuy's Avatar
I have riveted the smaller panel on the tunnel where your elbow will rest and then test fit the full panel (cleco) and it just didn't feel solid and I thought I had read on a thread where someone added to the panel.
I like the idea of placing insulation on both sides. I am using koolmat for the top side and I have some neopreen (spelling) that I used for the trunk area and I can just put that on the underside of the panel.
It sounds like maybe I was worried about something that wasn't an issue - which is a good thing.
Old 07-27-2012, 09:58 PM   #9 (permalink)
I have Lizard Skin on all my interior panels, including the transmission tunnel. At the last minute I decided to add an additional layer of Dynamat on the top and sides of the transmission tunnel, and then all the interior carpet. The final result is rock solid with no impression whatsoever of being thin or tinny. I don't think any additional metal reinforcement is required if well insulated.
Old 07-27-2012, 10:07 PM   #10 (permalink)
steno's Avatar
I have seen a few cars with 3/8" plywood bonded to the top. You can ease the edges and have a softer corner
steno is offline   Reply With Quote
Old 07-28-2012, 05:26 AM   #11 (permalink)
SIZE-O's Avatar
I built mine up with 1/4" aluminum plate to all a deeper cup holder to clear the tranny. Then finished it with carbon fiber.
Perry
FFR #6641, Mk 3.1, 408W Stroker, Dart Block, Edelbrock Victor Jr Heads, Custom Hydraulic Roller Cam, Quick Fuel 750 CFM, Non-Donor, TKO 600, Center Force Clutch, 8.8" Detroit Tru-Trac, 3.73 Gears, S.S. Side Pipes, Polished FR500 Style Wheel, Big Ass Wilwood Brakes, VPM Reinforced 3-Link, Stainless Steel Braid Everything. POM Dec/2010 & Feb/2011.
SIZE-O is offline   Reply With Quote
Old 07-28-2012, 05:43 AM   #12 (permalink)
Master Student
Doug Meldrum's Avatar
Damplifier pro and Luxury liner pro. You don't need any more than that.
FFR #7228, under construction
Doug Meldrum is online now   Reply With Quote
Old 07-28-2012, 04:30 PM   #13 (permalink)
section 8
Yeah what are you doing on it. I've never noticed any problem. All I did was install all the rivets , seam sealed all the seams , dyna mat and carpet . Now next time I drive it I might notice an issue .. bob
Bob Taylor is online now   Reply With Quote
Old 07-28-2012, 05:08 PM   #14 (permalink)
MPTech's Avatar
My tranny cover seems to be a little under-sized, it's very tight to install and doesn't seat all the way down without holding it or a screw. I'm concerned this will only get worse with insulation / carpeting and because I want to keep the cover removeable. So I'm considering fabbing a new one just slightly wider and thicker while I'm at it.
Licensed 4/24/13!! Wahoo!
Old 07-28-2012, 05:16 PM   #15 (permalink)
MKI Owners Club
NHolds's Avatar
I have a MKI, so mine didn't feel stiff at all. I put some alum angle on it and it stiffened up real well
FFR1439 - 9/23/98
NHolds is offline   Reply With Quote
Old 07-28-2012, 11:51 PM   #16 (permalink)
Bill_VA's Avatar
I wanted to make a new cover anyhow since I went with a mid-shift Tremec, so I used thicker aluminum. Nice and solid.
Bill_VA is offline   Reply With Quote
