Fuel lines for EFI - FFCars.com : Factory Five Racing Discussion Forum
Old 07-16-2012, 07:33 PM   #1 (permalink)
PaulW's Avatar
Fuel lines for EFI
I am about 90% decided to switch from a carb to either the powerjection or ez-efi system. My question relates to the changes required to my fuel lines.
I know I will have to add a return line and I will be using an external pump. I currently have a single 3/8" combination rubber and steel line setup. I used standard 60" teflon coated steel lines with 45 degree flares and a union at the halfway point along the frame rails.
I just want to install a simple plain set of lines and am not concerned with looks as it is all under the car anyway.
Can I use the current hard lines and use proper barbed fittings from them to EFI rated flex hose?
Some of the info I have seen says to stay away from steel lines and use all flex line but IMHO the OEMs all use a combination of steel and flex lines and besides I forsee difficulty in supporting a long run of dlex line horizontally along the frame rails.
Any and all advice would be appreciated.
Paul
FFR Mark IV 7411 Picked up 04/08/11
3-link, SN95 spindles, rear discs
Engine: 302-385hp, T-5, 3.08
First go-cart 08/31/11
Body remounted 10/03/11
Registered as unplated 21/03/12
On the road in gel-coat 27/03/12
"Badges, Badges? We don't need no stinkin' Badges!"
PaulW is offline   Reply With Quote
Old 07-16-2012, 08:32 PM   #2 (permalink)
MPTech's Avatar
I went with the FFR directions and ran flex from the in-tank fuel pump, to the filter, then flex again to the hard-lines (just above the rear axle). Then I ran hard-line all the way to the front of the footbox, then AN fitting and braided fuel lines to the fuel rails.
I like the hard-lines along the frame rails, under the floor pans.
Licensed 4/24/13!! Wahoo!
Old 07-16-2012, 11:17 PM   #3 (permalink)
Paul,
There's a returnless option for the Powerjection III system. It cycles the fuel pump on to maintain fuel pressure. I'm not sure about the EZ-EFI system. Modern fuel systems use this technique rather than a return line.
Good Luck,
Lawrence Perry
FFR Roadster #4227, 302 EFI('88 w/Mass Air Conversion), T-5, 3.73 live axle, rear coilovers
lbperry is online now   Reply With Quote
Old 07-16-2012, 11:34 PM   #4 (permalink)
I think that is completely false, use as little flex line as you can.
Old 07-17-2012, 12:27 AM   #5 (permalink)
PaulW's Avatar
I agree. Flex line to filter and pump, then hard line all the way to the Engine compartment.
Paul
Old 07-17-2012, 01:20 AM   #6 (permalink)
mirose's Avatar
Whoa there cowboy. I used 100% flexible Stainless Braided teflon lines from gas tank to engine and back again. Ridiculously easy to route and install. I only needed a minimum of fittings and it looks great.
I get it that the general feeling is that the hard lines are a bit more resistant to damage from a rock or what not, but the SS hose is VERY strong IMHO. Also, My understanding is the Teflon hose is very resistant to degradation and should last a very , very long time (as long as you use a good brand).
I know there are diverging thoughts on this topic, but I just want to get it out there that running flexible lines the whole way is fine too., at least I think so.
Here is a pic from a zillion years ago when I was mocking up my lines....they are just taped in place with electrical tape but it gives you an idea of how this went in
-Michael
FFR 7386 MK IV Roadster
Build Began 12/6/2010
First Start 11/18/2011
Go Kart 11/24/2011
My Build Project Website
Old 07-17-2012, 08:19 PM   #7 (permalink)
Vroom Vroom
I also ran stainless Teflon line from pump to fuel rails.
MKII non donor
347 stroker with stacks
