Mad Rev Counter - FFCars.com : Factory Five Racing Discussion Forum
Old 07-15-2012, 10:19 PM   #1 (permalink)
Ian Hunter's Avatar
Mad Rev Counter
Just before I order a new one, I thought I had better check.
We were driving through France and I noticed I was doing 6,000 rpm, then 7,000 rpm, then 8,000 rpm - all at a steady 80mph on fifth. Next thing I know it kept going round, past 0 and back to 2,500 or so!
Since when, it has just been all over the place, so I am not really sure what's going on. Sometimes steady and presumably accurate, next minute off the scale again.
Bin it?
Ian
First Mk 111 Roadster in UK and RHD. Ford 351W Edelbrock RPM Performer = 400 bhp. Tremec TKO 500. Rear axle 3.55:1. IRS and Vintage pin-drive wheels. SVA passed, road legal 6th June 2008!!
Ian Hunter is offline   Reply With Quote
Old 07-16-2012, 04:16 PM   #2 (permalink)
Is it a mechanical or electrical gage?
trichardson is offline   Reply With Quote
Old 07-16-2012, 10:53 PM   #3 (permalink)
Ian Hunter's Avatar
8,000 rpm in fifth
Sorry, an electrical Autometer gauge, Vintage look - standard FFR issue!
Ian
Old 07-17-2012, 01:09 AM   #4 (permalink)
Does your tach gets it's signal from the coil or from a designated output on your ignition box. I remember reading somewhere that it's OK to connect it to the coil if you don't have a high powered ignition box but most people do in these cars. I don't know what would happen if you did connect it to the coil under those circumstances, though. I'd try re-calibrating it and if that doesn't work go for a warranty replacement. I'm guessing you'll have to replace it since it seems to work sometimes and not others.
Old 07-17-2012, 07:32 AM   #5 (permalink)
Ian Hunter's Avatar
Red line
The rev counter is connected to the coil. The distributor is a conventional Mallory unit with an electronic something where the points should be, so not full electronic igntion and no box anywhere.
The instruments is a few years old now, so no hope of Warranty!
I'll just order a new one!
Thanks for trying.
Ian
Old 07-17-2012, 01:16 PM   #6 (permalink)
Yeah, sorry. It was worth a shot.
