Watch Your Fuel Lines - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
Old 08-02-2012, 12:18 PM   #31 (permalink)
Bill_VA's Avatar
Originally Posted by Mark Reid View Post
I have a single teflon lined AN hose from the fuel pump filter back by the fuel tank to the driver frame rail by the lower radiator hose.
Same here, I have no hard line, it's all braided hose from the tank to the carb. I just looked at my original invoice from Summit and it appears I have just rubber hose from Aeroquip FCA0615. For $2 more, I could have bought the teflon PTFE lined hose, FCC0615. I guess I didn't know what I didn't know. It does say the rubber liner is "compatible with most fuels, coolants, and oils", I thought that meant it was fine for gasoline, but maybe not for alcohol or some exotic fuel (nitro). After 6 years and 17k miles, I haven't had a hint of a leak, but I think I know what my winter project will be.
Bill_VA is online now   Reply With Quote
Old 08-02-2012, 01:53 PM   #32 (permalink)
G-Pete's Avatar
The ethanol in the full does not only corrode the older fuel lines it also corrodes aluminum tanks.
Here is a link to ethanol free fuel stations in the US and Canada,
Ethanol-free gas stations in the U.S. and Canada
As for me a 55gal drum of Sunoco 260 GTX is waiting for my car. Yes, it is more expensive but so is the car. I have pure gasoline free from additives which harm the performance, gas mileage and on top it has 5 years shelf life (pump gas 4-6 Month).
G-Pete is offline   Reply With Quote
Old 08-02-2012, 02:37 PM   #33 (permalink)
ROADRACER83's Avatar
Some videos on how AN hose and fittings
All:
I think there is still a lot of mis-information on AN hose, fittings, materials, and how to make them. Earl's store has a few vids on the topics. There are some on the WWW if you search Google for them.
http://www.anplumbing.com/page/3
The vid on OEM tubing adapters shows how to adapt to hard lines without flaring the tube. These use a compression ring technique. Flaring is a little more secure though, if you can get a flaring tool and a tube sleeve and nut on the tube. Here's a couple of pages on how to bend hard lines, flaring the ends and using tube sleeves and nuts to connect to AN adapters.
How to Do Custom Hard-Line Bending- Hot Rod Magazine
TUBE-PLUMBING WITH
If you can cut back on the morning donuts and coffee for a few days, use the savings to get this book. It is a bible of many of the skills and information that will come in really handy when you build your car.
HP Books HP1523 : High Performance Fasteners & Plumbing: a Guide to Nuts - Bolts - Fuel - Brake - Oil & Coolant Lines - Hoses - Clamps - Racinghardware and Plumbing Techniques - By Mike Mavrigian
Amazon.com: High Perf. Fasteners & Plumbing HP1523: A Guide to Nuts, Bolts, Fuel, Brake, Oil & Coolant Lines, Hoses, Clamps, RacingHardware and Plumbing Techniques (9781557885234): Mike Mavrigian: Books Amazon.com: High Perf. Fasteners & Plumbing HP1523: A Guide to Nuts, Bolts, Fuel, Brake, Oil & Coolant Lines, Hoses, Clamps, RacingHardware and Plumbing Techniques (9781557885234): Mike Mavrigian: Books
Old 09-11-2012, 09:29 PM   #34 (permalink)
cobracruz's Avatar
After reading about SS fuel line problems, I am planning to switch to hard lines. I do not own a flaring tool, so I plan to use Earl's compression to -6an fitting. Is this the correct one? http://www.summitracing.com/parts/EAR-165006ERL/
Also, should I use 3/8" steel or aluminum tubing? Is either metal not compatible with the earl's fitting above? Aluminum sounds easier to install, but more vulnerable to damage?
Finally, I'll replace the remainder of SS braids with the Aeroquip mentioned in earlier posts.
My car is a carbed 392 with a mechanical pump. It is a low pressure system without a return line (set to 4psi). Assuming proper fit, I should be well within parameters of all components, right? Does anyone foresee issues I haven't? Thanks in advance.
cobracruz is offline   Reply With Quote
Old 09-11-2012, 10:38 PM   #35 (permalink)
johntennyson's Avatar
I too want to go to current-fuel-compatible hoses! Right now I've got, as instructed in my MkII's manual, rubber hoses connecting the tank pipes to hard pipes in the RR wheel well, hard pipes leading to the front of the passenger wheel well where rubber hoses connect them to the hard pipes of the EEC IV fuel rails, with good ol' hose clamps holding it all together.
I'd like to do stuff like CobraCruz says, but with electronic injection, will the flare connectors handle the fuel line pressure? They're rated at 50 psi, which should be more than enough for carb, but does anyone know if this will work with EFI?
Thanks!
Mk II #4437: Reg. 12/06, 345/302 crate, new T-5, IRS w/3.27, Cobra intake, 30# injectors, 65mm TB, RJM inj. Graduated 8/12!
johntennyson is offline   Reply With Quote
Old 09-12-2012, 01:00 AM   #36 (permalink)
These are the type of things we're talking about here, right?
These are on '50s MGs, so their fuel pumps only need to make enough pressure to keep the carbs full.
Old 09-12-2012, 02:02 PM   #37 (permalink)
cobracruz's Avatar
I'm actually converting from braided stainless steel. The Earls AN fitting should allow a pretty painless switch.
I'm leaning towards the 3/8" aluminum solid fuel line. In my mind, it seems like an easier tubing to work, but wonder if SS would be safer. The Earls compression ring seals around either metals equally, right?
Also, its probably wise to use the flares on EFI. I think using the compression ring on such high pressures is a bit risky. However, I'm probably the farthest from an expert. Any advice out there?
Old 09-12-2012, 02:28 PM   #38 (permalink)
John,
I can't tell what kind of hose is under braided stainless sheath just by looking.
Maybe others can. The teflon lines from Aeroquip use different fittings than other stainless covered hose types.
Old 09-12-2012, 07:05 PM   #39 (permalink)
2007 Calendar Cover Car
Redfish's Avatar
This is great info, thanks folks.
So I guess the short rubber lines provided by FFR in 2002 to connect fuel tank to hardline are suspect...?
...and of course, I have a nice braided line from the hardline to the fuel rail & back...suspect!
FFR4462K | MKII | Goin' Carb'd | IRS | 315 Mod | SIA Mod | Konis | 17" FR500s | Nittos | Power Cobra Brakes | Bearclaw Latches | GasN SS Pipes | APE Hardtop
Hit the clutch, hit the gear, hit the gas & I'm gone.
Redfish is online now   Reply With Quote
Old 09-12-2012, 07:09 PM   #40 (permalink)
QSL
Stealth Ninja FFR builder
QSL's Avatar
The second pic is for sure rubber hose under there. The top pic almost looks like teflon hose but the ferrules are wrong. Those are for air hoses and it looks like it was crimped on a dayco crimper.
MK4 delivery 12/17/11
Build thread: HERE
Epic First start video HERE
Build thread: HERE
Old 09-12-2012, 07:55 PM   #41 (permalink)
It's the second picture I'm interested in, and the line on the left in particular. The braided sheath stuff on the right could be rubber underneath, but like brake hoses, you could make one out of teflon.
On the left, it looks like a copper pipe has been flared to take the fitting to connect it to the flex hose-- those are the fittings rated at 50 psi-- will they work at EFI pressure?
I was poking around on various hose sites a couple of months ago and I'll edit in the things I was looking at when I get a better chance later today. (Lunch break is ending!)
