Brake Caliper Guide Pin Bushings?? - FFCars.com : Factory Five Racing Discussion Forum
Old 07-09-2012, 01:08 AM   #1 (permalink)
jvikla's Avatar
Installed remanufactured 94 Mustang GT rear calipers this past winter. Today I noticed a strange chattering noise and discovered the right rear has excessive play where the pins ride in the caliper housing. ( I can grab the half of the caliper which the e brake cable is connected and move it 1/8" or more laterally within the holes. Don't recall this when I installed them but didn't inspect them that close I guess) I Could not find any information regarding whether those pins slide in a BUSHING or just the cast caliper housing.
Any insight on if there is supposed to be a bushing and if so where to buy it would be appreciated. I have not removed it yet as I first tore into the differential in search for the noise and things are not back together yet.
Thanks, Jerry
#6309 delivered 9/17/07.
94 donor Mustang GT,GT-40 Aluminum Heads, FAST EZ-EFI, 3.73 gears, 3 link, FFR/Ron Francis Wiring, Whitby top
jvikla is offline   Reply With Quote
Old 07-09-2012, 02:56 AM   #2 (permalink)
Rich A's Avatar
jvikla,
The caliper bracket cost around $20 including core charge.
The part number is 14-1028.
You can get/order them at any auto parts store.
Rich A is online now   Reply With Quote
Old 07-09-2012, 12:01 PM   #3 (permalink)
I am pretty sure it's just a hole bored in the casting w/o a bushing.
